    Which crimper to get for JST-VH connectors
    38
    4.4k
      A Former User @arhi
      @arhi said in Which crimper to get for JST-VH connectors:
      the "dual" tools like iwiss are faster.
      iwiss makes both types btw. i did the hastedly VH crimp above with the simple type which is just a tad too small.
      Apart from that very much agree.
        A Former User @DaBit
        @DaBit said in Which crimper to get for JST-VH connectors:
        Maybe PA-21 is a different animal altogether?
        Maybe the recent popularity of the Engineer tool has lead to fakes, or rejects finding its way to eBay? IDK, seems strange that there are so varying experiences if the tools are the same.
        • arhiundefined
          arhi @A Former User
          @bearer said in Which crimper to get for JST-VH connectors:
          Hm, did not know, never tried iwiss of that kind.
          has lead to fakes
          Very possible, but I have never seen them being shipped out of any country but Japan. Also I have 09 and 20 for a while, 21 arrived few months ago, no difference in quality. And the "flimzy" spring few reviewers complain about comparing to other tools I actually like. I don't really want to fight the spring while crimping bunch of pins.
          video that was mentioned where bigclivedotcom is not happy with engineer, and than shows how iwis came with "great manual", very similar, more detailed manual comes with all engineer tools too and he did not follow that manual that's why he got pin stuck in and bent and deformed...
            Since I purchased the PA09, 20 and 21 I've stopped using my old ratchet crimp tool. I do everything with the PA09 and PA21 now. I don't think the PA20 does anything I have that the 09 or the 21 won't.
              Remember how long it took before you got the first one correct?
              can't say i recall those things ever being troublesome except for putting a A on the other end of a cable someone put an B on; which I'm sure was done on purpose to mess with me. mind you that happened a while before youtube so less "alternative facts" abouts.
              • DaBitundefined
                DaBit
                @bearer: then you must be a natural talent 😀
                Oh man, the just post-RG58, pre-youtube era. Hubs instead of switches. RJ45 plugs without much guiding of the individual strands. Crimping tool from the local shop, not the best, and no guide at all. Trying to untwist, straighten and align the wires so they would just nicely slide in the RJ45. Crimp, and find out two of them somehow magically swapped location. Cut, one more. Yay, everything OK. But no network, argl. Third is a charm they say. Oops, good crimp but mirrored, looked at the wrong side of the 'example cable'. Sigh, one more...
                In my opinion crimping those contacts is the same. If you get a good crimp on the very first try ever you are a natural talent. I am not. 😁
                  It most certainly didn't happen with these types of open terminals until I got a proper tool. (That might be the case with the RJ45 except I started off with a proper tool, possibly Krone or Knipex but that was last millennium so can't be sure).
                  Anyways getting OT.
                  • gtj0undefined
                    gtj0
                    Well, here's my contribution to the cause...
                    https://www.youtube.com/watch?v=knfcoCRh1Sc
                    Don't all upvote the production quality at once.
                      A Former User @gtj0
                      @gtj0 said in Which crimper to get for JST-VH connectors:
                      JST PH? You mean Molex KK?
                      (and another time code;)
                      Edit: One thing I would have added was to always crimp the connectors on the wire in the same possition sort of speak. I.e. Wires tend to have a natural coil/helix shape from the spool and if you always say, let the direction of the coil run the same direction (clockwise and anti-clockwise) in adittion to always letting the cable curve down behind the crimper your cables will look so much better once in the shells.
                      • gtj0undefined
                        gtj0 @A Former User
                        @bearer Stupid time codes.
                        Anyway I never thought of that explicitly. I've always seemed to do that naturally. Or maybe it's just 40 years of cable management OCD. 🙂
                          A Former User @gtj0
                          OCD FTW! Just saw one of them were a bit off kilter relative to the other end 😇
                          In any case, I think that one will actually be a good option for many Duet builders who don't care for the flexibility of the more manual tools. 👍
                          • gtj0undefined
                            gtj0 @A Former User
                            Yeah I have great OCD but bad eyesight. 🙂
                            • gtj0undefined
                              gtj0
                              I just remembered that I also forgot to mention the strip length. Maybe I'll do a follow-up on strippers. 🙂
                              Not sure where I found this poster but it's a good guide.
                              https://www.te.com/content/dam/te-com/documents/application-tooling/global/65780-4_Crimp Quality Poster.pdf
                                A Former User @gtj0
                                https://forum.duet3d.com/post/88641😇
                                • gtj0undefined
                                  gtj0 @A Former User
                                  @bearer HA!
