    Which crimper to get for JST-VH connectors
    38
    4.3k
    • luckyflyerundefined
      luckyflyer @Danal
      @Danal That would be great.
      • Danalundefined
        Danal @gtj0
        @gtj0 said in Which crimper to get for JST-VH connectors:
        I'll do one as well with the iwiss and we can have a race. 🙂
        Oh, the Iwiss will be faster; I can concede the race without even seeing it.
        I just believe the four step can deal a little better with things like a wire that is too small for the connector, or too large, and/or a broader range of connectors, or etc., because the human controls the tension, and width of each section independently. The price for that is slow speed, and a little more burden on the human to get a given connector 'right'.
        And, having said all of that... for JUST the connector sizes in a Duet connector pack, everything I'm saying is probably not relevant and an iWiss style is probably fine. A really good choice.
        I do a ton of other electronics, with all kinds of connectors. I will say with some confidence that the PA21 covers a lot more ground than a 4 slot with stepped slots (I have several of those as well).
          luckyflyer
          I ordered this crimper for my build https://www.amazon.com/gp/product/B07R1H3Z8X/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 only to discover that it will not crimp the VH terminals. I don't mind saving a buck when I can but when it comes to tools I'll usually pay for the better/more versatile etc tool. Video's of the two tools will go a long way to helping a person decide.
          Thanks
            A Former User
            Bigclivedotcom did a YouTube video recently, covers lots of tools. But I was surprised to see what he said about the PA09, I would guess poor tolerance on the terminals or excessive wear on the tool. I've only experienced that problem with cheap terminals or if using a die too small. (DaBit said basically the same as bigclive, maybe there is more to it?)
            The VH connectors was in the mail today so will test after dinner:)
            (or a quicke before dinner .. I'd say you'd need larger dies than 2.2 to make good crimps on the insulation, but its miles better than no tool. Iwiss does make a larger version of the IWS-2820 that would likely be perfect)
              A Former User @Danal
              I will trade that overhead for what seems like a lot more control, and variety of pin types and sizes.
              Absolutely; unless in a production setting where you'd just buy the manufacturers ridiculously expensive tool because time and quality certifications I'd go with the manual Engineer or Iwiss tools hands down.
              • DaBitundefined
                DaBit
                I think PA-09 is what I use at work also, and the one I don't really like. Maybe PA-21 is a different animal altogether?
                I am mostly using 2mm and 2.54mm terminals (JST, Wurth), and not all that many. Maybe 100 crimps a year or so.
                dc42undefined A Former User? 2 Replies Last reply Reply Quote 0
                  dc42 administrators @DaBit
                  @DaBit said in Which crimper to get for JST-VH connectors:
                  The JST VH terminals as shipped need the PA21 because the wings of the crimp pins that go over the insulation are long, which needs the different shape and larger die of the PA21. But I've heard of users cutting the wings shorter and using a different crimp tool.
                  The PA21 is also OK for the Molex KK connectors, but not for smaller ones such as JST PH (the PA09 does those).
                    A Former User
                    I've used the PA-09 for pretty much everything except some circular amp connectors (where I had the $$$ amp tool) and only time I've had terminals stick is with the cheapest of cheap chinesium terminals where I with the naked eye can see the variance from terminal to terminal. Mine has been through a lot of chinesium terminals, most are just fine.
                    I only got the Iwiss to test as a cheaper alternative to reccomend; and for the value its pretty good, but still prefer the Engineer.
                    I find it faster to just reduce the width of the terminal; if that doesn't work then the wire is too thick for the tool anyway. The VH in the picture above is on a thin insulation 0.75mm2 wire; woudn't have worked with regular 0.75mm as it would have been too wide for the 2.2 die.
                    • DaBitundefined
                      DaBit
                      Most of my contacts come either directly from Wurth, or from Farnell/Digikey/Mouser.
                      But oh well, every crimp tool needs a bit of feeling and a bit of exercise, I am probably just not doing it enough and the Iwiss is simply more idiotproof. I suspect most people here crimped an RJ45 to CAT5 at least once. Remember how long it took before you got the first one correct?
                      A Former User? 1 Reply Last reply Reply Quote 2
                      • arhiundefined
                        arhi
                        I think I have more than 200 different crimping tools/pliers in my drawers, boxes, floor, shelves ... PA09 and PA20 are the only ones "non stop on the table" (recently got PA21 too but not using them that often). When you need to crimp a single pin, especially if that's new - unknown pin, and especially to "not the default size" wire PA09/20/21 are indispensable. Now if I need to do a 100 terminals, all same, all same size wire, the "dual" tools like iwiss are faster. I have some moderate experience (I crimp in average 2-3 pins a day past 35 years let's say) with dual, rachet type tools, in "ideal conditions" (good pins, proper wire size) around 1% of the pins will not be ok (bad crimp - wire falling out or pin bent/destroyed/broken or everything looks secure but bad contact, usually if insulated part goes under wrong part of the pin). On the other hand, I'm yet to have bad crimp with engineer PA## crimpers 😄 They are slower but super precise, and I don't do the 4 step, find no need for it, 2 step is more than adequate if you are using proper wire and proper die the first time. It is only important to select proper width of the die for every crimp.
                          A Former User @arhi
                          @arhi said in Which crimper to get for JST-VH connectors:
                          iwiss makes both types btw. i did the hastedly VH crimp above with the simple type which is just a tad too small.
                          Apart from that very much agree.
                            A Former User @DaBit
                            Maybe the recent popularity of the Engineer tool has lead to fakes, or rejects finding its way to eBay? IDK, seems strange that there are so varying experiences if the tools are the same.
                            • arhiundefined
                              arhi @A Former User
                              @bearer said in Which crimper to get for JST-VH connectors:
                              Hm, did not know, never tried iwiss of that kind.
                              has lead to fakes
                              Very possible, but I have never seen them being shipped out of any country but Japan. Also I have 09 and 20 for a while, 21 arrived few months ago, no difference in quality. And the "flimzy" spring few reviewers complain about comparing to other tools I actually like. I don't really want to fight the spring while crimping bunch of pins.
                              video that was mentioned where bigclivedotcom is not happy with engineer, and than shows how iwis came with "great manual", very similar, more detailed manual comes with all engineer tools too and he did not follow that manual that's why he got pin stuck in and bent and deformed...
                                Since I purchased the PA09, 20 and 21 I've stopped using my old ratchet crimp tool. I do everything with the PA09 and PA21 now. I don't think the PA20 does anything I have that the 09 or the 21 won't.
                                  can't say i recall those things ever being troublesome except for putting a A on the other end of a cable someone put an B on; which I'm sure was done on purpose to mess with me. mind you that happened a while before youtube so less "alternative facts" abouts.
                                  • DaBitundefined
                                    DaBit
                                    @bearer: then you must be a natural talent 😀
                                    Oh man, the just post-RG58, pre-youtube era. Hubs instead of switches. RJ45 plugs without much guiding of the individual strands. Crimping tool from the local shop, not the best, and no guide at all. Trying to untwist, straighten and align the wires so they would just nicely slide in the RJ45. Crimp, and find out two of them somehow magically swapped location. Cut, one more. Yay, everything OK. But no network, argl. Third is a charm they say. Oops, good crimp but mirrored, looked at the wrong side of the 'example cable'. Sigh, one more...
                                    In my opinion crimping those contacts is the same. If you get a good crimp on the very first try ever you are a natural talent. I am not. 😁
                                      It most certainly didn't happen with these types of open terminals until I got a proper tool. (That might be the case with the RJ45 except I started off with a proper tool, possibly Krone or Knipex but that was last millennium so can't be sure).
                                      Anyways getting OT.
                                      • gtj0undefined
                                        gtj0
                                        Well, here's my contribution to the cause...
                                        https://www.youtube.com/watch?v=knfcoCRh1Sc
                                        Don't all upvote the production quality at once.
                                          A Former User @gtj0
                                          JST PH? You mean Molex KK?
                                          (and another time code;)
                                          Edit: One thing I would have added was to always crimp the connectors on the wire in the same possition sort of speak. I.e. Wires tend to have a natural coil/helix shape from the spool and if you always say, let the direction of the coil run the same direction (clockwise and anti-clockwise) in adittion to always letting the cable curve down behind the crimper your cables will look so much better once in the shells.
                                          • gtj0undefined
                                            gtj0 @A Former User
                                            @bearer Stupid time codes.
                                            Anyway I never thought of that explicitly. I've always seemed to do that naturally. Or maybe it's just 40 years of cable management OCD. 🙂
