    Smart Effector part cooling
    1.8k
    • bricorundefined
      bricor @FelixH
      @FelixH The Delta values in my config file are the default settings I use based on measurements. I set the tower heights (end stop switches) also based on measured values (that is why they are set to 0 in the config file). I then run auto calibration each time I start the printer. I only need to run auto calibration twice to get the desired result.
      I posted the exact measurements of my printer, you should get the same results for height plus 8.5mm for the V6 compared to the Volcano that I use.
      The thermistor values you posted are correct, I use the same for my other printers that use a standard E3D thermistors.
      • FelixHundefined
        FelixH
        well, then... Everything seems to be accounted for, but still doesn't nail one of the corners of the stern of the Benchy. My last test was with a lower temperature (by 10°C) but no change at all.
        I will try another filament now and wait until tomorrow to get new 40mm fans...
        • bricorundefined
          bricor
          What infill % are you using? I typically use 20%.
          • FelixHundefined
            FelixH
            15% is my default
            bricorundefined 1 Reply Last reply Reply Quote 0
            • bricorundefined
              bricor @FelixH
              @FelixH In case you missed it, I edited my last post and included some pictures of a benchy I ran last night
              • FelixHundefined
                FelixH
                yes, I saw it. Not bad at all.
                mine is not half bad either, only this little bloob of plastic on one corner. I'm printing with a different filament with a different color... let's see...
                • bricorundefined
                  bricor @FelixH
                  @FelixH I recognize my print could be better, but I don't normally print benchys. I fired up the printer, calibrated, sliced the model and printed. I wanted to see what my results would be as a comparison.
                  Try 20% infill, see if that makes a difference.
                  • FelixHundefined
                    FelixH
                    The test with another filament was even worse...
                    @bricor could you send me a picture of your part cooling fan?
                    • bricorundefined
                      bricor @FelixH
                      @FelixH what exactly do you need a picture of, the fan or the label on the fan or the whole assembly?
                      Did you try the print at 20% infill?
                      FelixHundefined 1 Reply Last reply Reply Quote 0
                      • FelixHundefined
                        FelixH @bricor
                        @bricor said in Smart Effector part cooling:
                        Just a picture of the fan would be enough, I guess. I going to try the 20% right now. Stay tunned!
                        • bricorundefined
                          bricor @FelixH
                          • FelixHundefined
                            FelixH
                            Looks exactly like the one I've just installed. 9 blades. I'm printing right now and it looks better than with the other fan, which only had 7 blades...
                            • bricorundefined
                              bricor @FelixH
                              @FelixH are you still printing at 15% infill?
                              The reason I ask is that making multiple changes makes it difficult to diagnose the issue and determining what exactly fixed the issue.
                              • FelixHundefined
                                FelixH @bricor
                                @bricor yeah, that's the scientific method, one step at a time. Today I printed another Benchy with the new cooling fan. I went much better than yesterday, and yes, I'm still at 15%.
                                It still doesn't master that one corner, but it's much better than before. Maybe it prints way too fast, I don't know. I guess that at slower speed, it would have more time to cool down. Right now a Benchy on this printer is 1 hour 7 minutes.
                                Do you have the same duct as I have?
                                • bricorundefined
                                  bricor @FelixH
                                  @FelixH I am using the 270 version of this https://www.thingiverse.com/thing:2808152. I believe you mentioned the same.
                                  For S&Gs you may want to try 20% infill, it may give you a result, worth the try.
                                  My print time is about the same at 20% infill.
                                  FelixHundefined 2 Replies Last reply Reply Quote 0
                                  • FelixHundefined
                                    FelixH @bricor
                                    @bricor I'm on it
                                    • FelixHundefined
                                      FelixH @bricor
                                      @bricor I'll be dammed!
                                      It looks much better in real life, I must say.
                                      At this point, I'm going ahead and hypothesize that the cooling problem is over but there is still retraction tuning to be done...
                                      • bricorundefined
                                        bricor @FelixH
                                        @FelixH if you’re using the stock extruder that may be part of the issue. Extruder calibration may also help. If that’s done you may want to try printing at 95% extrusion (set in DWC).
                                        Slicer settings may also help, like align the seams/layer start point.
                                        • FelixHundefined
                                          FelixH
                                          I'm using the original E3D hotend I ordered from Duet. I came with an all-metal barrel, which I know it is prune to give problems on a Bowden system. I don't know why don't they send the one with a teflon lining, as nearly all deltas are Bowden...
                                          I'll have a look at the retraction settings and I'll try to tune it a bit more, but it's getting close to good-enough-for-me, as I don't print artistic things or figurines. I have a Photon for that...
                                          • bricorundefined
                                            bricor @FelixH
                                            @FelixH My apologies, when I said extruder I meant filament drive.
                                            The hotend assembly you are describing is top notch. I would stay away from any teflon lined hotend (heat break). I only use all metal hotends.
