    Setting tool offset using USB microscope
    4.4k
    • Danalundefined
      Danal
      If at all possible, start with the image provided by Duet, the "full" not the "lite".
      The install script does not turn off the monitor, it probably just "power saved" out. You may wish to search on "how to keep my screen on" or "how to keep my Pi from powering off".
      tekstyleundefined 1 Reply Last reply Reply Quote 0
      • tekstyleundefined
        tekstyle @Danal
        @Danal said in Setting tool offset using USB microscope:
        The duetpi full and lite doesn't work with duet2. It's designed for the duet3 unfortunately.
        • Danalundefined
          Danal @tekstyle
          @tekstyle said in Setting tool offset using USB microscope:
          True... but... you can still run them. Just turn off the DSF, and you have a regular Pi.
          Having said that, current base raspbian should be OK as well. We just might have to install something that the isntallopencv.sh script doesn't currently get, because I built and tested it on top of the Duet image. No big deal either way.
          Let me know when you have it rebuilt, modified for no sleep, and opencv installed.
          • tekstyleundefined
            tekstyle
            i followed this tutorial to set up duetpi on raspberry pi 3. took out the card and put it into the raspberry pi. powered it up (not connected to the duet2. not sure how i would do it). all i get is an endless list of EXT4-fs error lines after line. been doing this for the past 2 hours. not sure if I did something wrong?
              droftarts administrators @Danal
              Second, it is SLOW.
              Are you doing any post-capture/pre-recognition processing of the image? You can convert colour images to greyscale or black and white (with a threshold level), and even use the black and white version as a mask. This will reduce the amount of image recognition processing massively. I can't say I've tried this myself, just read about it.
              • Danalundefined
                Danal @droftarts
                @droftarts said in Setting tool offset using USB microscope:
                Second, it is SLOW.
                Yeah, that's all very fundamental, always grayscaling, trying different kinds of blur and threshold and mask and... Some do perform better than others, but the best still have highly variable "search" times that are extremely sensitive to the tuning parameters vs. the image.
                • Danalundefined
                  Danal @tekstyle
                  You can't. Don't connect it. It is really a stand-alone PI, just happens to be built with the Duet image as a start.
                  i followed this tutorial to set up duetpi on raspberry pi 3. took out the card and put it into the raspberry pi. powered it up, all i get is an endless list of EXT4-fs error lines after line. been doing this for the past 2 hours. not sure if I did something wrong?
                  Followed the Duet "etch" tutorial? And edited wpasupplicant.conf? And did NOT format when windows complained about the card after etching?
                  That last bit is the most important. The card is partitioned, with a windows readable "boot" partition and a much larger Linux partition. Windows tries to assign a drive letter to that Linux partition, balks, and asks to format it. Which you must always decline,
                  EXT4-fs is the file system that windows doesn't like, and asks to format. That certainly seems to relate to those error messages.
                  • tekstyleundefined
                    tekstyle @Danal
                    Yup. I followed the tutorial on duet exactly. Only thing was inside the boot partition, it already contained a wpasupplicant.conf file. I Openned itnin notepad and editted it with my ssid and PW. Pulled the card out and popped it in to the rpi. Then powered it up. Will try again tonight
                    tekstyleundefined 1 Reply Last reply Reply Quote 1
                    • tekstyleundefined
                      tekstyle @tekstyle
                      you won't believe this. I used my other laptop running windows 8, win32diskimager to load the duetpi image. and that worked. i have no idea why using balena etcher on win 10 doesn't work.
                      Danalundefined 1 Reply Last reply Reply Quote 1
                        dc42 administrators @wilriker
                        @wilriker said in Setting tool offset using USB microscope:
                        @dc42 Would a G10 L10 to set tool offsets relative to current position desirable (making G10 even more complex OTOH)?
                        Not necessary, because you can already do that using the object model.
                        Tool offset with limit switches would be great.
                        Already supported if you can configure the limit switch as a Z probe. See the G30 S-2 command.
                        • Danalundefined
                          Danal @dc42
                          Also, any scripting environment that is complex enough to do multi-tool alignment with "one button" is going to have basic math. And that's all that is needed to produce the final G10 commands. Subtract T0's coordinates from T1s, etc, etc. So, no, G10 does not need any changes.
                          P.S. That's why Python at the moment... a better place might be conditional G-Code, but that does not yet work from the Pi DSF... so having a single script have access to the camera, and the printer, requires something on the attached Pi at the moment. Python seems very suitable for the required image processing.
                          The "Zonly.py" script in the https://github.com/DanalEstes/PythonDSF/ repository is touchplate based. It is still very much experimental 'under development'. Still maybe worth looking at for ideas.
                            dc42 administrators @Danal
                            Expressions within GCode commands do work from the Pi DSF in RRF 3.04. It's meta commands such as 'if' and 'while' that don't yet.
                            • Danalundefined
                              Danal @dc42
                              @dc42 said in Setting tool offset using USB microscope:
                              Good point. Lots of progress being made very quickly. Which is quite exciting!!
                              It is probably more clear to say that touchplate oriented stuff can/could/will be done in Cond G-Code at some point very soon now as that all progresses. On the other hand, Camera based stuff seems like it will be on the Pi for the foreseeable planning horizon.
                              • Danalundefined
                                Danal @tekstyle
                                Good news is you are up and have a reproducable path.
                                Odd thing is I use W10 with Balena for all my SD cards for PIs, and I probably build two a week. Well, maybe one a week. Anyway, it has been trouble free.
                                Anyway, glad to see you have a working SD, feel free to ask other questions, I'm eager for testing of the camera based scripts in particular.
                                Sometime today I'm going to post an entirely new set of "machine vision" scripts... had some breakthroughs in the last 24 hours. Look for a new top-level post in a few hours.
                                • tekstyleundefined
                                  tekstyle @Danal
                                  @Danal
                                  Unopenned terminal typed CD ~/Desktop/Duet
                                  My folder is on the Desktop and I renamed it to Duet. Didn't find the path. So I just right clicked the .sh file and selected open in terminal. I'll see how it goes after work.
                                  • tekstyleundefined
                                    tekstyle
                                    pi@duet3:~/Desktop/Duet $ python3 toolAlignImage.py
                                    Traceback (most recent call last):
                                    File "toolAlignImage.py", line 11, in <module>
                                    import cv2
                                    ModuleNotFoundError: No module named 'cv2'
                                    this is what i am getting when i try to run toolAlignImage.py. i have the camera plugged in as well when I attempt to run the *.py file. it is not connected in any way to the duet2wifi for obvious reasons.
                                    • Danalundefined
                                      Danal
                                      That means that OpenCV is not installed.
                                      You can re-run the installOpenCV.sh any number of times. It is long enough that you may need to ensure your Pi does not go to sleep or otherwise time out. It does produce yellow warnings at various points; it should not produce any red failures.
                                      Important If you re-run it, when it finishes, copy the last dozen or so lines of output and post them here.
                                      Also, see this post: https://forum.duet3d.com/topic/15026/tool-alignment-machine-vision-some-progress
                                      I'd highly, highly recommend switching to the code described in that thread. You will still need OpenCV...
                                      • tekstyleundefined
                                        tekstyle @Danal
                                        How do u turn off sleep in duetpi? I can't seem to find it in any menu unlike the raspbian os.
                                        • Danalundefined
                                          Danal
                                          https://www.google.com/search?q=disable+sleep+raspberry+pi
                                          • tekstyleundefined
                                            tekstyle
                                            i tried to disable sleep. i think it worked. then during the install with the file from https://github.com/DanalEstes/installOpenCV, it was going well for a few hours until it froze. wished i can copy and paste what happened.
                                            i am using a 32gb sandisk. i do not have an original duetpi card and i am using a raspberry pi model 3B
