Duet Maestro Not Recognized
Firmware installation
435
    IGEN
    I just bought a Duet Maestro Board for my Ender 3. Followed all the wiring steps and updated the firmware from Pronterface. I now cannot get the board to connect to Pronterface and device manager shows an "Unknown USB Device (Device Descriptor Request Failed)" whenever I try to connect it.
    Any help would be greatly appreciated
      poohzaza
      @IGEN said in Duet Maestro Not Recognized:
      have you install the usb comport driver
        Have a look through these detailed getting connected steps.
        https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
        undefined 1 Reply Last reply 15 Mar 2020, 22:58 Reply Quote 0
          IGEN @Phaedrux
          @Phaedrux Sorry for the late response, I just tried following that guide and the board does not show up in the device manager window. Do you have any idea why that might be?
            A Former User
            Please report the status of the LEDs as described in this guide https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
            undefined 1 Reply Last reply 17 Mar 2020, 02:15 Reply Quote 0
              IGEN @A Former User
              @bearer Thanks for the response,
              the red 5V light is on
              the green 3.3V light is on
              the red light between the USB and reset button is on
              the red DIAG light is permanently on after removing the SD card and checking to see if the reset button is stuck
              ? 1 Reply Last reply 17 Mar 2020, 02:30 Reply Quote 0
                A Former User @IGEN
                is an indication that the firmware could be corrupt; but without the board registering as a bossa serial port when connecting via USB there isn't much to do.
                please verify the usb cable is working with both data and power as the next step.
                undefined 1 Reply Last reply 19 Mar 2020, 16:49 Reply Quote 0
                  IGEN @A Former User
                  @bearer The cable does work with data and power, I also tried another cable. No luck
                  undefined undefined undefined 3 Replies Last reply 19 Mar 2020, 16:52 Reply Quote 0
                    Danal @IGEN
                    Try several cables, and several computers, if at all possible.
                      droftarts administrators @IGEN
                      @IGEN Have you installed Bossa https://github.com/shumatech/BOSSA/releases/tag/1.9.1 or the Windows driver? https://github.com/dc42/RepRapFirmware/tree/dev/Driver
                      Either will install the driver for the bossa port and allow programming. Though it's better to install the driver, as Windows will then recognise the Duet when it actually has firmware on it.
                        IGEN @IGEN
                        @Danal @droftarts Sorry for the long overdue reply.
                        Tried on multiple computers will all the cords in my house. No luck.
                        I had the windows driver installed already, unfortunately.
