    Toolboard Extruder Motor Stutters (most of the time)
    751
    • wescundefined
      wesc
      Board: Duet 3 MB6HC v0.6 or 1.0 (MB6HC)
      DSF Version: 1.2.5.0
      Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC4 (2020-03-16b1)
      Board TOOL1LC firmware 3.01-RC4 (2020-03-16b1)
      After doing a 5mm extruder move:
      M122 B20
      Diagnostics for board 20:
      Never used RAM 8.2Kb, max stack 604b
      HEAT 1132 CanAsync 1460 CanRecv 1392 TMC 212 AIN 532 MAIN 2304
      Last reset 00:00:57 ago, cause: software
      Driver 0: short-to-ground standstill, SG min/max 0/302, read errors 0, write errors 0, ifcount 44, reads 28602, writes 2, timeouts 0, DMA errors 0, failedOp 0xff
      Moves scheduled 4, completed 4, hiccups 0
      VIN: 24.0V
      MCU temperature: min 33.3C, current 35.8C, max 35.8C
      Ticks since heat task active 55, ADC conversions started 57796, completed 57795, timed out 0
      Last sensors broadcast 00000002 found 1 59 ticks ago
      Free CAN buffers: 36
      NVM user row b1d088a9 fffff8bb 20003b9c 20003ba8
      TSENS 000ddf GAIN 016461 OFFS 002a69 CAL 1f2f
      3/18/2020, 8:29:45 PM
      CroXY - Crossed Gantry Printer, Ultibots D300VS+, Custom CoreXYU
      • timcurtis67undefined
        timcurtis67
        Sounds like a bad wire or crimp in one of the connections. Assuming the A&B coils are wired correctly in the connectors of course.
        wescundefined 1 Reply Last reply Reply Quote 0
        • wescundefined
          wesc @timcurtis67
          @timcurtis67
          I tried two different connector harnesses. No crimping done by me because one side done by ldo the other is the pigtail supplied with the toolboard. The solder connections I made are more than sound. However to test the bad connector theory I made up a 2nd cable. Same problem. I also measured resistance across the a+/a- and b+/b- on the toolboard and they are correct - 2 ohms as expected with no shorts to ground.
          Also, ran the hemera with the cover off so the bare pinion gear was free to turn. Still stutters.
          I think the driver is bad or bad toolboard connection . The solder on the tmc2209 pins is less than perfect. There might be an unintentional solder bridge between 2 of the pins on the atmel chip. Hard to tell.
          • Danalundefined
            Danal @wesc
            @wesc said in Toolboard Extruder Motor Stutters (most of the time):
            Can you post a good photo? IIRC, TMC chips have some dual pins to a common pad for total current carrying ability; these often look like solder bridges, but are actually OK.
              Hi @wesc, your M122 report is reporting short-to-ground, which explains the lack of proper movement. Please verify with a multimeter (and power off) that you still have:
              • 2 ohms between pins 1 and 2 of the motor output (measured on the underside of the tool board)
              • 2 ohms between pins 3 and 4
              • No continuity between any other pair of pins (e.g. 1 and 3)
              • No continuity between any of those pins and the frame of the motor
              If the board is mounted on the Hemera, also make sure there is no possibility that any part of the back of the tool board is shorting against the Hemera frame.
              • wescundefined
                wesc
                1-2: 2.2 ohms
                3-4: 2.2 ohms
                All other pairs are 2.5 megaohms or more
                Board was on Hemera, but i used extra standoffs in addition to the plastic ones and clipped the protruding part leads to shorten them. Happens with the board off the Hemera as well.
                Attached pics from the world's finest $15 USB microscope. Solder on the leads looks a little blobby.
                  droftarts administrators @wesc
                  @wesc The M584 command for your extruder needs to come BEFORE the motor settings. Currently you have:
                  M569 P2 S0 ; physical drive 2 goes backwards
                  M569 P4 S0 ; physical drive 3 goes backwards
                  M569 P5 S0 ; physical drive 3 goes forwards
                  M569 P20.0 S0
                  M584 X0.5 Y0.1 Z0.2:0.3:0.4 ; set drive mapping. 0.0 reports short to ground
                  M92 X160.00 Y160.00 Z1600.00 E409.00 ; set steps per mm
                  M203 X18000.00 Y18000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min)
                  M201 X3500.00 Y3500.00 Z420.00 E250.00 ; set accelerations (mm/s^2)
                  M906 X2500 Y2500 Z1500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  ;Z config
                  ; Temperature Sensors
                  ; Hemera - Reconfigured via M952 B121 A20 to be at address 20
                  ; Hemera motors
                  M569 P20.0 S0 ; set tool extruder direction
                  M584 E20.0 ; set extruder drives
                  ; Hemera sensors and heaters
                  etc
                  Move the Hemera section up to below the M584 that defines the other axes (ie under line number 10 above), otherwise it's using the default motor settings. Remove one of the M569 P20.0 S0 commands.
                  • wescundefined
                    wesc
                    Ugggh, so this is weird. I updated the firmware thinking it could have been a firmware issue (long shot, I know).
                    M997 B20
                    After waiting many miinutes with no response, I power cycled.
                    Now the Duet3 isn't communicating with my Toolboard - tons of CAN response timeouts. No slow red flash, just the solid blue and solid red leds. The heater and fan turned on (I see the warning about that in the docs), so i removed all connections to the board except CAN and power and stepper.
                    I tried a double button power on to reset.
                    M115 B121 (or 10 or 20, the address i previously programmed) also error.
                    M409 K"boards" yields this:
                    {"key":"boards","flags":"","result":[{"canAddress":0,"firmwareDate":"2020-03-16b1","firmwareFileName":"Duet3Firmware_MB6HC.bin","firmwareName":"RepRapFirmware for Duet 3 MB6HC","firmwareVersion":"3.01-RC4","iapFileNameSBC":"Duet3_SBCiap_MB6HC.bin","iapFileNameSD":"Duet3_SDiap_MB6HC.bin","mcuTemp":{"current":29.4,"max":29.5,"min":18.3},"name":"Duet 3 MB6HC","shortName":"MB6HC","supports12864":false,"v12":{"current":12.2,"max":12.3,"min":12.2},"vIn":{"current":23.9,"max":24.0,"min":23.9}}]}
                    Seems the bootloader got corrupted.
                    Is there a bossa solution to reprogram the bootloader on a Toolboard?
                      Ian has identified the root cause of the original problem: your M906 command that sets the extruder current was earlier in config.g than the M584 command that defined the extruder driver. So the motor current wasn't being set, which would result in less than 100mA current.
                      I'm not sure why the firmware update failed. Did you notice any flashing of the red LED during the update process? If the firmware file you tried to install did not have a valid CRC then it would have repeatedly tried to fetch and install the firmware, and the LED would flash at intervals. If you turned the power off while it was writing to flash memory, perhaps that corrupted the bootloader (it's not clear from the datasheet whether the bootloader protection provides adequate protection if power is removed while another part of the flash memory is being written).
                      What I would like you to do now is to disconnect the CAN connector from the tool board, and once again power the board up while both buttons are held down (then release them after powering up). If the red LED between the two buttons show no activity at all, I will authorize a warranty replacement, because re-installing the bootloader requires an Atmel ICE or similar SWD programming tool. If you do get any activity from that LED, please report what flashes you see.
                      • wescundefined
                        wesc
                        @dc42 said in Toolboard Extruder Motor Stutters (most of the time):
                        In original post: "Increasing current to 1500 with M906 just makes it louder.", so Ian's theory isn't correct. (wasn't totally obvious that I did that with the console)
                        • wescundefined
                          wesc
                          The .bin file was the same one I originally flashed to the Toolboard that was uploaded to /sys
                          Just tried a reboot with CAN disconnected and buttons pressed. No LEDs on between the buttons, and no bootloader/CAN connection.
                            @wesc It's not just the current, it's all the motor settings. From M584:
                            Order dependence
                            M584 must come earlier in config.g than any M350 and M906 commands. If it creates new axes, it must also be earlier than any M92, M201, M203, M208, M350, M566, M574, M667 and M669 commands.
                            • wescundefined
                              wesc
                              Ah. Wish i could try the different order. 😞
                                I authorise a warranty replacement for your tool board.
