    CR10 S5 upgrade to Duet 2 Wifi
    2.5k
    • GT1Zaundefined
      GT1Za
      @NexxCat
      Ill try it now. Ive always liked the idea of keeping the z stop incase the BLtouch fails. Is there no way to keep both?
      NexxCatundefined 1 Reply Last reply Reply Quote 0
      • NexxCatundefined
        NexxCat @GT1Za
        @GT1Za
        I have no experience with that I'm afraid, so I can't help, but people here are really friendly and knowledgeable, so someone else may know 🙂
        • GT1Zaundefined
          GT1Za
          ok, Z probe still didnt deploy when trying to home the Z. I had to hit the stop button.
          • NexxCatundefined
            NexxCat @GT1Za
            @GT1Za
            Just to double check. The brown wire from the BLTouch is definitely plugged into Pin 8 of the expansion connector?
            • GT1Zaundefined
              GT1Za
              definitely into pin 8
              • NexxCatundefined
                NexxCat @GT1Za
                @GT1Za
                DOH! I know what I missed.
                In both deployprobe.g and retractprobe.g, add I1 to the end of the parameters:
                deployprobe.g
                M280 P3 S10 I1
                retractprobe.g
                M280 P3 S90 I1
                • GT1Zaundefined
                  GT1Za
                  @NexxCat
                  I have just checked the wiring diagram:
                  Pin 1: To Red
                  Pin 2: To Blue/Brown
                  Pin 8: To Orange/Yellow
                  This is as per: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
                  This is how I have it wired
                  I have added the I1 to both, but still not deploying
                  NB: This is not deploying on HOMING the Z as I cant run the mesh bed before homing.
                  • NexxCatundefined
                    NexxCat @GT1Za
                    @GT1Za
                    Hmm, and you still have the config.g M307 set to H3?
                    Looks like the BLTouch isn't receiving the servo signal. The "I" parameter in the deploy and retract is needed because we're wired directly into the expansion connector, if you had a Duex, it wouldn't be required, but with the correct heater configured (heater 3), and the inversion, it should work 😕
                    Edit: Can you post your homez.g and homeall.g please?
                    • GT1Zaundefined
                      GT1Za
                      in the config.g:
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 20 2020 11:57:17 GMT+0200 (South Africa Standard Time)
                      G91 ; relative positioning
                      G1 H1 X-515 Y-515 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H2 X5 Y5 F6000 ; go back a few mm
                      G1 H1 X-515 Y-515 F240 ; move slowly to X and Y axis endstops once more (second pass)
                      G1 H1 Z-505 F240 ; move Z down stopping at the endstop
                      G90 ; absolute positioning
                      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                      ;G91 ; relative positioning
                      ;G90 ; absolute positioning
                      ; homez.g
                      ; called to home the Z axis
                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 20 2020 11:57:18 GMT+0200 (South Africa Standard Time)
                      G1 H1 Z-505 F3000 ; move Z down until the endstop is triggered
                      • NexxCatundefined
                        NexxCat @GT1Za
                        @GT1Za
                        Ok, the home macros aren't configured for a z-probe. Here are mine:
                        ; homez.g
                        M290 R0 S0	; Reset babystepping
                        G1 Z5 F6000 S2  ; lift Z relative to current position
                        G1 X118 Y148 F6000      ; go to the bed centre and home Z
                        G30             ; home Z by probing the bed
                        ; homeall.g
                        G1 S1 X-305 Y-305 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 X5 Y5 F6000          ; go back a few mm
                        G1 S1 X-305 Y-305 F360  ; move slowly to X and Y axis endstops once more (second pass)
                        M98 Pdeployprobe.g      ; deploy mechanical Z probe
                        M98 Pretractprobe.g     ; retract mechanical Z probe
                        You'll need to adjust X and Y in both for your printer because you are 500x500.
                        • GT1Zaundefined
                          GT1Za
                          wow ok a whole new issue
                          in homez.g
                          I changed to:
                          G1 X250 Y250 F6000 ; go to the bed centre and home Z
                          this should be the center of the bed. but it tried to send it way off and I had to hit stop.
                          The Y steps dont seem to be right as 150 is taking me just short of center. 250 basically made it travel off and I had to hit stop.
                          The good news is the probe worked!
                          • NexxCatundefined
                            NexxCat @GT1Za
                            @GT1Za
                            Did you also adjust:
                            to
                            G1 S1 X-515 Y-515 F3600
                            and
                            to
                            • GT1Zaundefined
                              GT1Za
                              Yes I did.
                              The Y is just going too far. Everything else is as its meant to be
                              • NexxCatundefined
                                NexxCat @GT1Za
                                @GT1Za
                                What happens if you manually home X and Y in the web UI, then use the jog controls to move them. Do they move the expected distance?
                                • GT1Zaundefined
                                  GT1Za
                                  No, Y is only moving to roughly 220 before it maxes
                                  • NexxCatundefined
                                    NexxCat @GT1Za
                                    @GT1Za
                                    When it hits the maximum distance, what does the web UI say for the Y co-ordinate? You've got 80 steps/mm in the config, so that would be right for a 1.8 degree stepper with a 20 tooth GT2 pulley.
                                    • GT1Zaundefined
                                      GT1Za
                                      @NexxCat
                                      coords show the Y at 220, and you could here it slipping for like a second.
                                      • NexxCatundefined
                                        NexxCat @GT1Za
                                        @GT1Za
                                        I'm assuming when you home Y, it does home correctly and the Y co-ordinate is reported as 0?
                                        • GT1Zaundefined
                                          GT1Za
                                          @NexxCat yes the homing works fine and reports 0
                                          • NexxCatundefined
                                            NexxCat @GT1Za
                                            @GT1Za
                                            and just so I've got this right in my head. Starting from Y home, you move the bed using the jog controls and when Y is reported at 220, the bed is actually at the end of it's travel (IE, at 510)?
