    CR10 S5 upgrade to Duet 2 Wifi
    2.5k
    • GT1Zaundefined
      GT1Za
      @NexxCat
      I have just checked the wiring diagram:
      Pin 1: To Red
      Pin 2: To Blue/Brown
      Pin 8: To Orange/Yellow
      This is as per: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
      This is how I have it wired
      I have added the I1 to both, but still not deploying
      NB: This is not deploying on HOMING the Z as I cant run the mesh bed before homing.
      NexxCatundefined 1 Reply Last reply Reply Quote 0
      • NexxCatundefined
        NexxCat @GT1Za
        @GT1Za
        Hmm, and you still have the config.g M307 set to H3?
        Looks like the BLTouch isn't receiving the servo signal. The "I" parameter in the deploy and retract is needed because we're wired directly into the expansion connector, if you had a Duex, it wouldn't be required, but with the correct heater configured (heater 3), and the inversion, it should work 😕
        Edit: Can you post your homez.g and homeall.g please?
        • GT1Zaundefined
          GT1Za
          in the config.g:
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 20 2020 11:57:17 GMT+0200 (South Africa Standard Time)
          G91 ; relative positioning
          G1 H1 X-515 Y-515 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000 ; go back a few mm
          G1 H1 X-515 Y-515 F240 ; move slowly to X and Y axis endstops once more (second pass)
          G1 H1 Z-505 F240 ; move Z down stopping at the endstop
          G90 ; absolute positioning
          G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 20 2020 11:57:18 GMT+0200 (South Africa Standard Time)
          G1 H1 Z-505 F3000 ; move Z down until the endstop is triggered
          • NexxCatundefined
            NexxCat @GT1Za
            @GT1Za
            Ok, the home macros aren't configured for a z-probe. Here are mine:
            ; homez.g
            M290 R0 S0	; Reset babystepping
            G1 Z5 F6000 S2  ; lift Z relative to current position
            G1 X118 Y148 F6000      ; go to the bed centre and home Z
            G30             ; home Z by probing the bed
            ; homeall.g
            G1 S1 X-305 Y-305 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 X5 Y5 F6000          ; go back a few mm
            G1 S1 X-305 Y-305 F360  ; move slowly to X and Y axis endstops once more (second pass)
            M98 Pdeployprobe.g      ; deploy mechanical Z probe
            M98 Pretractprobe.g     ; retract mechanical Z probe
            You'll need to adjust X and Y in both for your printer because you are 500x500.
            • GT1Zaundefined
              GT1Za
              wow ok a whole new issue
              in homez.g
              I changed to:
              G1 X250 Y250 F6000 ; go to the bed centre and home Z
              this should be the center of the bed. but it tried to send it way off and I had to hit stop.
              The Y steps dont seem to be right as 150 is taking me just short of center. 250 basically made it travel off and I had to hit stop.
              The good news is the probe worked!
              • NexxCatundefined
                NexxCat @GT1Za
                @GT1Za
                Did you also adjust:
                to
                G1 S1 X-515 Y-515 F3600
                and
                to
                • GT1Zaundefined
                  GT1Za
                  Yes I did.
                  The Y is just going too far. Everything else is as its meant to be
                  • NexxCatundefined
                    NexxCat @GT1Za
                    @GT1Za
                    What happens if you manually home X and Y in the web UI, then use the jog controls to move them. Do they move the expected distance?
                    • GT1Zaundefined
                      GT1Za
                      No, Y is only moving to roughly 220 before it maxes
                      • NexxCatundefined
                        NexxCat @GT1Za
                        @GT1Za
                        When it hits the maximum distance, what does the web UI say for the Y co-ordinate? You've got 80 steps/mm in the config, so that would be right for a 1.8 degree stepper with a 20 tooth GT2 pulley.
                        • GT1Zaundefined
                          GT1Za
                          @NexxCat
                          coords show the Y at 220, and you could here it slipping for like a second.
                          • NexxCatundefined
                            NexxCat @GT1Za
                            @GT1Za
                            I'm assuming when you home Y, it does home correctly and the Y co-ordinate is reported as 0?
                            • GT1Zaundefined
                              GT1Za
                              @NexxCat yes the homing works fine and reports 0
                              • NexxCatundefined
                                NexxCat @GT1Za
                                @GT1Za
                                and just so I've got this right in my head. Starting from Y home, you move the bed using the jog controls and when Y is reported at 220, the bed is actually at the end of it's travel (IE, at 510)?
                                • GT1Zaundefined
                                  GT1Za
                                  @NexxCat
                                  thats correct
                                  I havent homed the other axis so they are reporting 0 here.
                                  • NexxCatundefined
                                    NexxCat @GT1Za
                                    @GT1Za
                                    The only explanation I have for that is that the Y axis steps/mm aren't correct. Can you take a photo of the Y axis motor and pulley? I'll see if I can tell whether it's a 20T or not.
                                    GT1Zaundefined 1 Reply Last reply Reply Quote 0
                                    • GT1Zaundefined
                                      GT1Za @NexxCat
                                      @NexxCat
                                      not sure if that helps. Pretty tough getting to the back of this printer.
                                      The motor is about double the height of the normal ones, but its the standard S5 motor.
                                      https://3dprinting.stackexchange.com/questions/7692/stepper-motor-for-cr10-s5-y-axis
                                      NexxCatundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                      • NexxCatundefined
                                        NexxCat @GT1Za
                                        @GT1Za
                                        I'm afraid I'm stumped on this one. That looks like a normal 20 tooth pulley and I've checked the Marlin source for the CR10 S5. It definitely uses 80 steps/mm.
                                        If the bed was moving an insufficient distance, I'd say maybe the stepper was skipping, or the belt was loose, but it's moving too much which doesn't make sense.
                                        Probably a stupid question, but have you tried powering the Duet off and on again, letting it re-load config.g?
                                        • GT1Zaundefined
                                          GT1Za @NexxCat
                                          @NexxCat Ill give it a shot now
                                          • GT1Zaundefined
                                            GT1Za
                                            @NexxCat Restart made no difference.
