Heater 0 and Heater 1 reading 2000°C
Funny, I have excactly the same Problem. It is a brand new duet WiFi 2 with external antenna. Everything works perfekt but not the temp reading. It also Shows 2000 on both channels. Here is my config:
M950 H1 C"e0heat" T1 ; create nozzle heater output on !e0heat and map it to sensor 1
M143 H1 S280 ; set temperature limit for heater 1 to 280CHopefully Dave could give us more informations.
@Bakak -273 would indicate a broken wire (open). 2000C indicates a short.
Debugging step: Plug and unplug the sensor wires. It is OK to do this while powered up. (NEVER plug a motor while powered up). Watch for changes on the web console and report back.
Debugging step: Measure the resistance of each sensor Using a DVM or similar
Report that all back here.
@CaiJonas said in Heater 0 and Heater 1 reading 2000°C:
My "standard off the shelf" thermistors that come with E3D V6 hotends are configured like this:
M308 S1 P"1.temp0" Y"thermistor" T100000 B3950 A"HE1"
That beta value in your config, B4138, where did that originate? And where did the thermistor itself, the physical device, where did it originate?
Hi @Danal
I wrote this config a while ago, can't rember where I got the infos from but it works with other duet wifis. I tried your and the following config without any succes:
M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.06e-8 ; define E0 temperature sensor
M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
I tried two different e3d thermistors on e0, e1 and bed connectors for the heatsensor. No succes
I measured the resistant, thermistors and wiring is fine.I think my WiFi board is falty, temp always 2000°C. Never had this proble, before and i build up 6 3D Printer, all with duet boards
Unplug that temp sensor completely. Still read 2000?
Danal said in Heater 0 and Heater 1 reading 2000°C:
Indeed! If they measure about 100kΩ at 20°C they should be ok and then carefully without shorting any pins measure from ground on say the Vin terminal to both pins of the thermistor input and report back readings.
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2019-06-13b2
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sat Oct 12 2019 17:04:55 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Predator" ; set printer name M665 R220 L440.4 B185 H420.607 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet M575 P1 B57600 S1 ;Serial Port for Panel Due ; Drives M569 P0 S0 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 I1 M350 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z160.00 E412; E399 ; set steps per mm M566 X600.00 Y600.00 Z600.00 E160.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E10000.00 ; set maximum speeds (mm/min) M201 X2000.00 Y2000.00 Z2000.00 E1000.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E800 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X2 Y2 Z2 S1 ; set active low and disabled endstops ; Z-Probe M558 P5 R0.4 H20 F1200 T6000 A10 S0.02 ; set Z probe type to effector and the dive height + speeds G31 P100 X0 Y0 Z-0.13 ; set Z probe trigger value, offset and trigger height M557 R180 S18 ; define mesh grid ; Heaters M305 P0 T100000 B4138 C0 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ;M305 P2 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1 ;M143 H2 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 F100 C"Bauteillüfter" ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S0.66 H1 F100 T60 L0.3 X0.75 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M98 P0:/sys/retract.g T0 M501 M572 D0 S0 G29 S1 I'm measuring 120k for the hotend Thermistor and 114k for the Bed thermistor, which should be fine....
I mesaure a Voltage of 3.2V from Thermistor0-pin, Thermistor1-pin and Thermistor2-pin to GND. ---However, the VSSA voltage is slowly crawling from 3.2V to 0V while i measure between VSSA and GND. shouldnt VSSA be GND potential?
edit: i just noticed... there is a resettable fuse F1... how do i reset it?
@Bakak said in Heater 0 and Heater 1 reading 2000°C:
Yes, VSSA should be only a few millivolts above ground unless there is a short circuit between VSSA and a higher voltage. The polyfuse connects VSSA to GND. It is self-resetting.
it should as dc42 said self reset; to test it power off the board and measure resistance F1 it, should probably be in the 0-1 ohm range if working.
Overload... i guess it broke -.-
What type of fuse is this?
I'm confident, that i can replace it -
may sound silly but double check you have a 0 reading when shorting the leads, and make sure to apply some pressure to pierce any oxide layer on the solder joint.
I'm confident, that i can replace itshematic says:
Fuse to protect the SAM from VIN applied to VSSA in error.
Multicomp MC36207, Bel Fuse 0ZCJ0020FF2E -
yep. just measured again in high ohm range, 15M.
thanks for your help, this saves me a ton of money
@droftarts I'm using the latest release of ReprapFirmware 3, upgrading was the first thing I did. All other things works just perfekt.
@Danal with unplugged sensor it also shows 2000
@dc42 what could I do to test, what is the problem?
Thanks to all so far
Bourns MF-MSMF014 is another suitable part number for the VSSA fuse. You can solder the new fuse on top of the old one, which will be easier than trying to remove the old one.
I've never heard of the VSSA polyfuse failing before.
As a temporary workaround, you could connect VSSA on one of the thermistor connectors to GND on one of the endstop connectors. But then you lose the protection against a thermistor short to VIN, which is what the fuse is there to protect against.
haha! finally i'm the first to achieve something
I just ordered some of the fuses. don't want to run the board unprotected
You don't need a poly fuse or even a surface mount one, any odd fast acting 100mA or so fuse could be either wired between VSSA and GND or solderd in parallell with the existing one would provide protection.
