    Heater 0 and Heater 1 reading 2000°C
    1.7k
    • Bakakundefined
      Bakak
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2019-06-13b2
      ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sat Oct 12 2019 17:04:55 GMT+0200 (Mitteleuropäische Sommerzeit)
      G90                                         ; send absolute coordinates...
      M83                                         ; ...but relative extruder moves
      M550 P"Predator"                            ; set printer name
      M665 R220 L440.4 B185 H420.607                  ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0                               ; put your endstop adjustments here, or let auto calibration find them
      M552 S1                                     ; enable network
      M586 P0 S1                                  ; enable HTTP
      M586 P1 S0                                  ; disable FTP
      M586 P2 S0                                  ; disable Telnet
      M575 P1 B57600 S1				;Serial Port for Panel Due
      M569 P0 S0                                  ; physical drive 0 goes forwards
      M569 P1 S0                                  ; physical drive 1 goes forwards
      M569 P2 S0                                  ; physical drive 2 goes forwards
      M569 P3 S1                                  ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                            ; set drive mapping
      M350 X16 Y16 Z16 I1
      M350 E16 I1                     ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z160.00 E412;  E399	    ; set steps per mm
      M566 X600.00 Y600.00 Z600.00 E160.00  ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E10000.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z2000.00 E1000.00    ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I50             ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                     ; Set idle timeout
      M208 Z0 S1                                  ; set minimum Z
      M574 X2 Y2 Z2 S1                            ; set active low and disabled endstops
      M558 P5 R0.4 H20 F1200 T6000 A10 S0.02                 ; set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.13                           ; set Z probe trigger value, offset and trigger height
      M557 R180 S18                               ; define mesh grid
      M305 P0 T100000 B4138 C0 R4700                 ; set thermistor + ADC parameters for heater 0
      M143 H0 S120                                ; set temperature limit for heater 0 to 120C
      M305 P1 B4725 C7.060000e-8 R4700                ; set thermistor + ADC parameters for heater 1
      M143 H1 S280
      ;M305 P2 B4725 C7.060000e-8 R4700                ; set thermistor + ADC parameters for heater 1
      ;M143 H2 S280                                ; set temperature limit for heater 1 to 280C
      M106 P0 S0 F100  C"Bauteillüfter"                    ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S0.66 H1 F100 T60 L0.3 X0.75              ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 F0                            ; define tool 0
      G10 P0 X0 Y0 Z0                             ; set tool 0 axis offsets
      G10 P0 R0 S0                                ; set initial tool 0 active and standby temperatures to 0C
      M98 P0:/sys/retract.g
      T0
      M501
      M572 D0 S0
      G29 S1
      I'm measuring 120k for the hotend Thermistor and 114k for the Bed thermistor, which should be fine....
      I mesaure a Voltage of 3.2V from Thermistor0-pin, Thermistor1-pin and Thermistor2-pin to GND. ---However, the VSSA voltage is slowly crawling from 3.2V to 0V while i measure between VSSA and GND. shouldnt VSSA be GND potential?
      edit: i just noticed... there is a resettable fuse F1... how do i reset it?
      dc42undefined A Former User? 2 Replies Last reply Reply Quote 0
        dc42 administrators @Bakak
        @Bakak said in Heater 0 and Heater 1 reading 2000°C:
        Yes, VSSA should be only a few millivolts above ground unless there is a short circuit between VSSA and a higher voltage. The polyfuse connects VSSA to GND. It is self-resetting.
          A Former User @Bakak
          it should as dc42 said self reset; to test it power off the board and measure resistance F1 it, should probably be in the 0-1 ohm range if working.
          • Bakakundefined
            Bakak
            Overload... i guess it broke -.-
            • Bakakundefined
              Bakak
              What type of fuse is this?
              I'm confident, that i can replace it
                may sound silly but double check you have a 0 reading when shorting the leads, and make sure to apply some pressure to pierce any oxide layer on the solder joint.
                shematic says:
                Fuse to protect the SAM from VIN applied to VSSA in error.
                Multicomp MC36207, Bel Fuse 0ZCJ0020FF2E
                • Bakakundefined
                  Bakak
                  yep. just measured again in high ohm range, 15M.
                  thanks for your help, this saves me a ton of money 😉
                  • CaiJonasundefined
                    CaiJonas @droftarts
                    @droftarts I'm using the latest release of ReprapFirmware 3, upgrading was the first thing I did. All other things works just perfekt.
                    @Danal with unplugged sensor it also shows 2000
                    @dc42 what could I do to test, what is the problem?
                    Thanks to all so far
                      Bourns MF-MSMF014 is another suitable part number for the VSSA fuse. You can solder the new fuse on top of the old one, which will be easier than trying to remove the old one.
                      I've never heard of the VSSA polyfuse failing before.
                      As a temporary workaround, you could connect VSSA on one of the thermistor connectors to GND on one of the endstop connectors. But then you lose the protection against a thermistor short to VIN, which is what the fuse is there to protect against.
                      • Bakakundefined
                        Bakak
                        haha! finally i'm the first to achieve something 😜
                        I just ordered some of the fuses. don't want to run the board unprotected
                          A Former User
                          You don't need a poly fuse or even a surface mount one, any odd fast acting 100mA or so fuse could be either wired between VSSA and GND or solderd in parallell with the existing one would provide protection.
                          • CaiJonasundefined
                            CaiJonas
                            @Bakak @dc42 I don't get it, what fuse can I measure and what should the value be?
                            • Bakakundefined
                              Bakak
                              this one.
                                dc42 administrators @CaiJonas
                                @CaiJonas said in Heater 0 and Heater 1 reading 2000°C:
                                What revision is your Duet WiFi?
                                • If it's 1.0 or 1.01 then see https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_VSSA_fuse.
                                • If it's 1.02 or later then the polyfuse is the green component between the processor and the WiFi module.
                                Please check that you are still getting 2000C readings even with just USB power applied (no VIN power).
                                • CaiJonasundefined
                                  CaiJonas
                                  @dc42 I measured a value of 1.1-1.2 ohm and I still get 2000°C readings with just USB power applied. 😞
                                    If you disconnect the thermistors completely and use your multimeter to measure the voltage between the two pins of one of the thermistor connectors, with USB power applied, what voltage does it read? Does it still read 2000C or does it change to -273C ?
                                    CaiJonasundefined 1 Reply Last reply Reply Quote 0
                                    • CaiJonasundefined
                                      CaiJonas @dc42
                                      @dc42 I measure excactly 3.3V on all three channels and temp stay on 2000C. Do you have a presumtion what the Problem could be?
                                        It sounds like either a failure of the main processor (but this type of failure would be very unusual) or a configuration problem. Please post your config.g file.
                                        • CaiJonasundefined
                                          CaiJonas @dc42
                                          @dc42 ```
                                          ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
                                          ; generated by RepRapFirmware Configuration Tool on Sun Jul 15 2018 19:42:49 GMT+0200 (Mitteleuropäische Sommerzeit)
                                          M555 P1 ; Set firmware compatibility to look like native output
                                          M665 X-0.406 Y-0.805 Z0.000 R113.116 L236 B110 H233.000 ; Set delta radius, diagonal rod length, printableradius and homed heigth
                                          M666 X0.280 Y-0.620 Z0.340 ; Endstop calibration
                                          M550 Cai's Delta ; Set machine name
                                          M552 S1 ; Enable network
                                          M587 S"FRITZ!WLAN Repeater 1750E" P"12041990" I192.168.2.112 ; Configure access point. You can delete this line once connected
                                          M586 P0 S1 ; Enable HTTP
                                          M586 P1 S0 ; Disable FTP
                                          M586 P2 S0 ; Disable Telnet
                                          M569 P0 S0 ; Drive 0 goes forwards
                                          M569 P1 S0 ; Drive 1 goes forwards
                                          M569 P2 S0 ; Drive 2 goes forwards
                                          M569 P3 S1 ; Drive 3 goes forwards Extruder
                                          M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation for axis
                                          M350 E16 I1 ; Configure microstepping with interpolation for extruder
                                          M92 X200 Y200 Z200 ; Set steps per mm for axis 160
                                          M92 E830 ; Set steps per mm for extruder 830
                                          M203 X18000 Y18000 Z18000 E3500 ; Set maximum speeds (mm/min)
                                          M566 X900 Y900 Z900 E3500 P1 ; Set maximum instantaneous speed changes (mm/min)
                                          M201 X1800 Y1800 Z1800 E3500 ; Set print acceleations (mm/s^2) E3600
                                          M906 X1400 Y1400 Z1400 E1200 I10 ; Set motor currents (mA) and motor idle factor in per cent
                                          M84 S25 ; Set idle timeout
                                          M208 Z0 S1 ; Set minimum Z
                                          M574 X2 S1 P"xstop" ; X min active high endstop switch
                                          M574 Y2 S1 P"ystop" ; Y min active high endstop switch
                                          M574 Z2 S1 P"zstop" ; Z min active high endstop switch
                                          M558 P5 C"zprobe.in" H2 I1 F600 R0.2 T18000 A5 S0.05 ; Set Z probe type to modulated and the dive height + speeds
                                          G31 P1000 X0 Y0 Z-0.050 ; Set Z probe trigger value, offset and trigger height G31 P0 X0 Y0 Z0
                                          M557 R90 S30 ; Define mesh grid
                                          M950 F0 C"fan0" ;
                                          M950 F1 C"fan1" ;
                                          M950 F2 C"fan2" ;
                                          M106 P0 S0 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                          M106 P1 S1 H1 T45 C"Heastsink" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                          M106 P2 S1 H0 T45 C"PCB" ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                          M308 S0 P"bed_temp" Y"thermistor" T100000 B4725 C7.06e-8 ; define bed temperature sensor B4138
                                          M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
                                          M143 H0 S120 ; Set temperature limit for heated bed to 120°C
                                          M307 H0 A230.8 C823.2 D4.2 B0 ; Set PID Bed
                                          M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.06e-8 ; define E0 temperature sensor
                                          M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
                                          M143 H1 S280 ; Set temperature limit for heater 1 to 280°C
                                          M307 H1 A545 C200 D5 B0 ; Set PID Nozzle
                                          M302 S100 R100 ; Set minimal extrude/retract temperature
                                          M563 P0 F0 D0 H1 L0 ; Define tool 0
                                          G10 P0 X0 Y0 Z0 R0 S0 ; Set tool 0 axis offsets, Set initial tool 0 active and standby temperatures to 0C
                                            1. When you send command M98 P"config.g" are there any error messages?
                                            2. What response do you get when you send each of the following commands?
                                            M115
                                            M308 S0
                                            M308 S1
                                            M950 H0
                                            M950 H1
