CR10v2 - Duet 3 Connections - Part 2
@droftarts said in CR10v2 - Duet 3 Connections - Part 2:
When commissioning, the sensible thing to do is connect one thing (eg one motor, one temp sensor, one fan) at a time, and test it. Connecting everything, flipping the on switch, then trying to troubleshoot, is asking for trouble.
You got that right!! I'll take a run at the motor phase link
Thanks!
@BearcatTD said in CR10v2 - Duet 3 Connections - Part 2:
How do I do the coding in config.g for my three fans?
Part Cooling Fan out7
Hot end cooling fan out8
Motherboard cooling fan, I would assume out9You can always use the RRF config utility again, either in part (just fill in the bits you need), or in it's entirety (by loading the json file it produced the last time you used it; click 'Use existing configuration' on the start page, and it will prompt you to upload the json file). Using the first method, I get:
; Fans M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency M106 P0 C"Part cooling fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency M106 P1 C"Hot end fan" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency M106 P2 C"CPU fan" S1 H-1 ; set fan 2 name and value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F1 ; define tool 0 The part cooling fan and CPU fan are not thermostatically controlled. You can set the CPU fan to thermostatic control, and then tie that to the temperature monitoring of the CPU (setting this up is not supported in config tool) with:
M308 S2 Y"mcu-temp" A"MCU" ; create sensor for mcu, shows on temp graph M950 F2 C"out9" Q500 ; create fan 2 on pin out9 M106 P2 C"CPU fan" S1 H2 T45 ; set fan 2 name and value, use sensor 2 Not tested, but I think that should work.
do you know if anyone looked at how he ended up with mixed pin names for duet3 and duex5 initially? (from the configurator)
Thanks guys...Fans. Are. Working.
OK. Motor phases. I went through for each driver and phound the two wires that were in phase. Now I'm not quite sure what to do with them!
Thanks again!
connect them ^^
one coil on the 1st and 2nd pin, the other coil on the 3rd and 4th pin. You can start on the left or the right, doesn't matter, if the motor turns the "wrong" way you can swap the coils or invert in config.
Thanks! Just so I'm hearing this right...
I would attach one of the "phase" wires to pin 1 or 2 and the other "phase" wire to pin 3 or 4. Does it matter which pins the other two wires go to ?
I apologize...this is probably maddening to you!
Bearer...I'm pretty thick. OK Here is a pretty picture I drew (my macbook croaked dead away this morning)
I'm not quite sure what constitutes a coil. So in the above image, this is what I originally had. So for attempt 1 I left pin one the same and I swapped pins 2 & 3. I got an error, "motor phase A may be disconected reported by driver(s) 2 3" Then the same error for phase B. For what is's worth, I also got "Failed to enable endstops", but we'll deal with that later.
Second attempt I swapped pins 1 & 3 and got the same errors.
I hope this makes sense... Thanks again for your time. I know you're in England, but I seriously owe you multiple beers!
in England
Lord no! (no offence to our British friends..)
While I'm not sure what you refer to as a phase, lets try to assume we mean the same thing. if you measure a resistance between 1 and 2 on your drawing, it should be correct; the two other wires go on 3 and 4. You should not measure any resistance between 1&3, 1&4 and 2&4, just to eliminate any shorts in the motor.
If thats the case then we can put the two pictures together to try and see how it fits together.
I think we're close. So the two wires labeled phase...This is where / how I found the two wires
https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
So knowing this, does that change the image above. Actually this is how I plugged the motor in which gave all of the "Short to ground" errors which are in the images at the top of the post.
Thanks again,Pat
it shouldn't change it no; as long as those are two wires that gives you the strongest braking effect, and you get the same with the other two.
unfortunately if that doesn't work when connected your options are the crimps are no good, or drivers are damaged (suppose it could be a configuration issue, but hard to say without the specs for the motor)
