    Duet Wifi + Raspberry Octoprint Power Problem
    275
    • Davundefined
      Dav
      Hi
      I connected today my duet to my octoprint to use my Palette in connected mode but if the printer is off and the raspberry is on I see the bltouch on and the paneldue blinking, why?
      How can I fix this problem?
        A Former User
        https://lb.raspberrypi.org/forums/viewtopic.php?t=162539
        see if that leads you anywhere. I honestly don't recall if it worked or not when i tried.
        • Davundefined
          Dav
          I tried the command but it disconnect all ports and i'm not able to see devices.
            A Former User
            Ah, more than one USB device connected to the Pi? Yeah, I do seem to recall there being an issue with loosing 5v on all the ports; if it was just the Duet then it should have worked better.
            Davundefined 1 Reply Last reply Reply Quote 0
              A Former User
              Which firmware are you running? if it supports marlin mode on the paneldue port you might be able to use that instead of usb between the pi and the duet.
              • Davundefined
                Dav @A Former User
                @bearer
                On duet I have 2.0.7, and on palette the latest
                • Davundefined
                  Dav @A Former User
                  @bearer Yes I use octoprint only to print in connected mode with palette2, on my octoprint I have duet and palette connected
                    A Former User @Dav
                    @Dav said in Duet Wifi + Raspberry Octoprint Power Problem:
                    You might find thats not immediately obvious to everyone how its all connected; maybe adding a diagram or picture will illicit more input from the rest of the clever people here.
