Duet Maestro 2 stops mid print
2.7k
    massynrt
    Please help - I'm new to 3d printing. My printer stops mid print for now reason. When I log into the web console, I find the duet Restarted. Nothing homed.. How do I find the problem?
    Please help. Where do I start looking for the problem..
    I am running the latest firmware for the Duet 2 Maestro - Release 2.05.1 (Duet 2), 1.26.1 (Duet 06/085)
    Rudi
      PaulHew
      Can you post the results of a M122 please
        massynrt
        Here it is - Does it matter when I run the M122 command. Must it be right after a fail, or is this one good.
        RepRapFirmware for Duet 2 Maestro version 2.05.1 running on Duet Maestro 1.0
        Board ID: 08DJM-9X66L-LG3SN-6J1FD-3SJ6M-9BZAR
        Used output buffers: 3 of 24 (15 max)
        Static ram: 19804
        Dynamic ram: 87320 of which 0 recycled
        Exception stack ram used: 204
        Never used ram: 23744
        Tasks: NETWORK(ready,764) HEAT(blocked,1296) MAIN(running,3896) IDLE(ready,160)
        Owned mutexes:
        Last reset 00:52:32 ago, cause: software
        Last software reset at 2020-03-30 09:34, reason: Unknown, spinning module Platform, available RAM 23288 bytes (slot 1)
        Software reset code 0x40b0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f80f BFAR 0xe000ed38 SP 0x20000fe4 Task 0x5754454e
        Stack: 004042f7 004046a2 a1000000 20008498 00404d97 00000001 00405765 2000849c e000ed01 20001c0c a5a5a5a5 a5a5a5a5 00000001 200083a0 92cb8acf 00000000 004094a5 a5a5a5a5 10000000 e000ed04 20001c0c a5a5a5a5 00409507
        Error status: 0
        Free file entries: 10
        SD card 0 detected, interface speed: 15.0MBytes/sec
        SD card longest block write time: 2.8ms, max retries 0
        MCU temperature: min 32.8, current 33.4, max 33.9
        Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: standstill, read errors 0, write errors 0, ifcount 69, reads 53397, timeouts 0
        Driver 1: standstill, read errors 0, write errors 0, ifcount 63, reads 53397, timeouts 0
        Driver 2: standstill, read errors 0, write errors 0, ifcount 71, reads 53397, timeouts 0
        Driver 3: standstill, read errors 0, write errors 0, ifcount 55, reads 53397, timeouts 0
        Driver 4: standstill, read errors 0, write errors 0, ifcount 36, reads 53397, timeouts 0
        Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 53398
        Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 53397
        Date/time: 2020-03-30 10:26:43
        Slowest loop: 7.74ms; fastest: 0.05ms
        Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
        === DDARing ===
        Bed heaters = 0, chamberHeaters = -1 -1
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        lcd is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 22.11ms; fastest: 0.04ms
        HTTP sessions: 1 of 8
        Interface state 5, link 100Mbps full duplex
          PaulHew
          @massynrt said in Duet Maestro 2 stops mid print:
          I spotted this - Last reset 00:52:32 ago, cause: software, but yes, immediately after a fail would be better.
            massynrt
            m122
            Used output buffers: 12 of 24 (15 max)
            Static ram: 19804
            Dynamic ram: 87356 of which 0 recycled
            Exception stack ram used: 300
            Never used ram: 23612
            Tasks: NETWORK(ready,812) HEAT(blocked,1296) MAIN(running,3896) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:01:24 ago, cause: reset button
            Error status: 0
            MCU temperature: min 37.3, current 37.4, max 37.7
            Supply voltage: min 24.1, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: standstill, read errors 0, write errors 0, ifcount 84, reads 24, timeouts 0
            Driver 1: standstill, read errors 0, write errors 0, ifcount 78, reads 24, timeouts 0
            Driver 2: standstill, read errors 0, write errors 0, ifcount 86, reads 24, timeouts 0
            Driver 3: standstill, read errors 0, write errors 0, ifcount 64, reads 24, timeouts 0
            Driver 4: standstill, read errors 0, write errors 0, ifcount 43, reads 24, timeouts 0
            Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 23
            Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 24
            Slowest loop: 1.06ms; fastest: 0.06ms
            === DDARing ===
            Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
            Segments left: 0
            === Network ===
            Slowest loop: 3.46ms; fastest: 0.05ms
            HTTP sessions: 2 of 8
              Thanks for your report. Unfortunately it's not clear to me what caused the reset. It looks as though the tick interrupt did the reset because the heater management task hadn't indicated it was active for the previous 20 seconds, but it's difficult to be sure. If it happens again, please post another M122 report.
              undefined 3 Replies Last reply 30 Mar 2020, 11:07 Reply Quote 0
                massynrt @dc42
                @dc42 Thank you for the assistance. How can I know for sure. I tried doing a event log, but that did not complete. As if if did not write once the reset happened. What else can I try?
                  Is the Duet connected by USB to a PC? If so then see the wiki page on USB ground loops.
                  undefined 1 Reply Last reply 30 Mar 2020, 11:19 Reply Quote 0
                    massynrt @dc42
                    @dc42 No - Only Ethernet.
                      massynrt @dc42
                      @dc42 m122
                      Used output buffers: 14 of 24 (15 max)
                      Static ram: 19804
                      Owned mutexes:
                      Last reset 00:01:35 ago, cause: reset button
                      Last software reset at 2020-03-30 11:00, reason: User, spinning module GCodes, available RAM 23612 bytes (slot 2)
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04427000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                      Error status: 0
                      MCU temperature: min 37.3, current 37.6, max 37.6
                      Driver 0: standstill, read errors 0, write errors 0, ifcount 21, reads 62, timeouts 0
                      Driver 1: standstill, read errors 0, write errors 0, ifcount 21, reads 62, timeouts 0
                      Driver 2: standstill, read errors 0, write errors 0, ifcount 21, reads 62, timeouts 0
                      Driver 3: standstill, read errors 0, write errors 0, ifcount 15, reads 62, timeouts 0
                      Driver 4: standstill, read errors 0, write errors 0, ifcount 13, reads 62, timeouts 0
                      Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 62
                      Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 62
                      Date/time: 2020-03-30 16:40:13
                      Slowest loop: 0.86ms; fastest: 0.06ms
                      === DDARing ===
                      Segments left: 0
                      === Network ===
                      Slowest loop: 3.40ms; fastest: 0.05ms
                      Error: Could not flush remaining data while finishing upload
                      Error: Uploaded file size is different (0 vs. expected 1112 bytes)
                      Error: Uploaded file size is different (0 vs. expeError: Could not flush remaining data while finishing upload
                        massynrt
                        I see the last reset was done by a reset button- What does that mean?
                          massynrt
                          And.. The diag light stays on. Using a BL Touch
                            massynrt @dc42
                            @dc42 Tasks: NETWORK(ready,900) HEAT(blocked,1296) MAIN(running,3896) IDLE(ready,160)
                            Owned mutexes:
                            Last reset 00:00:55 ago, cause: software
                            Last software reset time unknown, reason: User, spinning module GCodes, available RAM 23804 bytes (slot 0)
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                              massynrt
                              Lets try again - I'm posting 2 M122 Diagnostic files.
                              The first one, was done a few seconds before the machine stopped, the 2nd one right after.. Lets hope you can make something from this..
                              ------------------------------------------FIRST------------------------------------------------------
                              01/04/2020, 09:20:50: M122: === Diagnostics ===
                              RepRapFirmware for Duet 2 Maestro version 3.01-RC5 running on Duet Maestro 1.0
                              Used output buffers: 1 of 24 (17 max)
                              Static ram: 22012
                              Dynamic ram: 88460 of which 20 recycled
                              Exception stack ram used: 368
                              Never used ram: 20212
                              Tasks: NETWORK(ready,976) HEAT(blocked,1328) MAIN(running,2020) IDLE(ready,84)
                              Owned mutexes:
                              Last reset 00:11:01 ago, cause: power up
                              Last software reset at 2020-04-01 07:25, reason: User, spinning module GCodes, available RAM 20632 bytes (slot 1)
                              Error status: 0
                              Free file entries: 9
                              MCU temperature: min 37.0, current 37.6, max 37.8
                              Supply voltage: min 23.9, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: ok, read errors 0, write errors 0, ifcount 12, reads 974, timeouts 0
                              Driver 1: ok, read errors 0, write errors 0, ifcount 12, reads 974, timeouts 0
                              Driver 2: standstill, read errors 0, write errors 0, ifcount 12, reads 974, timeouts 0
                              Driver 3: ok, read errors 0, write errors 0, ifcount 8, reads 974, timeouts 0
                              Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 974, timeouts 0
                              Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 973
                              Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 974
                              Date/time: 2020-04-01 09:20:49
                              Slowest loop: 3.29ms; fastest: 0.12ms
                              Hiccups: 0(0), FreeDm: 166, MinFreeDm: 158, MaxWait: 0ms
                              === MainDDARing ===
                              Scheduled moves: 3938, completed moves: 3917, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
                              === AuxDDARing ===
                              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                              Bed heaters = 0 -1, chamberHeaters = -1 -1
                              Heater 0 is on, I-accum = 0.1
                              Heater 1 is on, I-accum = 0.3
                              Segments left: 1
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is doing "G1 X-4.045 Y5.452 E2.82853" in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              === Network ===
                              Slowest loop: 4.93ms; fastest: 0.04ms
                              Interface state active, link 100Mbps full duplex
                              ------------------------------------------2nd ------------------------------------------------------
                              01/04/2020, 09:21:21: M122: === Diagnostics ===
                              Used output buffers: 3 of 24 (6 max)
                              Static ram: 22012
                              Dynamic ram: 88260 of which 20 recycled
                              Never used ram: 20576
                              Tasks: NETWORK(ready,976) HEAT(blocked,1360) MAIN(running,2020) IDLE(ready,84)
                              Owned mutexes:
                              Last reset 00:00:28 ago, cause: reset button
                              Error status: 0
                              MCU temperature: min 37.1, current 37.4, max 37.9
                              Supply voltage: min 0.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: standstill, read errors 0, write errors 1, ifcount 19, reads 1145, timeouts 0
                              Driver 1: standstill, read errors 0, write errors 1, ifcount 19, reads 1145, timeouts 0
                              Driver 2: standstill, read errors 0, write errors 1, ifcount 19, reads 1145, timeouts 0
                              Driver 3: standstill, read errors 0, write errors 1, ifcount 15, reads 1145, timeouts 0
                              Driver 4: standstill, read errors 0, write errors 1, ifcount 13, reads 1145, timeouts 0
                              Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1151
                              Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 1151
                              Slowest loop: 3.25ms; fastest: 0.11ms
                              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                              === MainDDARing ===
                              === AuxDDARing ===
                              Segments left: 0
                              File is idle in state(s) 0
                              === Network ===
                              Slowest loop: 104.32ms; fastest: 0.02ms
                                massynrt
                                @dc42 I've uploaded 2 M122 files above. Please see if you can spot an issue. This is very frustrating.
                                  A Former User
                                  Presumably you haven't pressed the reset button, maybe some pictures showing the mounting of the board and wires that are run near the reset swtich can help dc42 in his investigation. Understandably its a difficult issue to diagnose.
                                  undefined 1 Reply Last reply 1 Apr 2020, 07:56 Reply Quote 0
                                    massynrt
                                    I know it is rough, but is a work in progress...
                                      massynrt
                                      One more thing I've noticed, not sure if it is an issue... The prints look wrong before the reset... Infill looks wacked!
                                        massynrt @A Former User
                                        @bearer Nope. Not touching the reset button. I did read on the forum that some of them Maestro Reset buttons do get stuck. I did try to release it a bit with tweezers. I must say the reset button is VERY stiff. But not convinced that the button is the problem as yet.. That is why I'm asking.. If that error can only be generated by the button, then I guess it is time for shipping a new board, as this one is new.
                                        ? droftartsundefined 2 Replies Last reply 1 Apr 2020, 08:01 Reply Quote 0
                                          A Former User @massynrt
                                          Afaik, it is, but lets defer to dc42 on that one; with the pictures I'm sure he'll have a clearer idea of what could possibly affect it but to the untrained eye it doesn't look like mechanical forces or electrical noise should be a likely culprit.
                                          5 out of 56
