Smoke/Scorching
Hi. I have been using the duet wifi for months with no issue, it is a great piece of kit. Today however, I was running through startup when smoke and sparks started to fly through the case. I opened it up and could see scorching on the E1 stepper driver chip. The E1 stepper driver is currently unused on my set up as I don't have dual extrusion. The board is still functioning. I have included pictures. Thoughts on the cause?
I'm not able to answer you about this but if you want a more educated reply from someone with a bit more knowledge I would take photos with details showing the scorching. As close and detailed as you can get them with good lighting.
The burnt patch looks to be right next to the output of the driver - Check for lose bits of metal that might be rattling about in the electronics enclosure, including behind the board.
From the picture I can't tell if the output connector is burnt or if it's just the lighting ?
That does seem very strange. I would indeed appreciate close-up photos of the driver chip. Also, please check whether the back of the board is scorched in that area, and whether there is any way that the output connector pins on the back of the board could have been shorted to or by anything.
thanks yangndrw, The pins are clean, that is just the reflection from the grey case.
I have been using the printer since then with no issues until now, when I have update the firmware to 1.19. I am now getting temperature warnings on this driver. Can I disable these warnings as they are coming through every few seconds?
Currently there is no way to disable the temperature warnings. If it is less than 6 months since you purchased your Duet, please ask your supplier to replace the driver under warranty.
Thanks for the reply. The board is 11 months old. Will they still replace the driver as it burnt out in March (see above)?
As you reported it in March, I would expect it to be covered.
I'll consider providing a way to disable monitoring of specific drivers in firmware 1.20.
Thanks for the advice, ill send them a message.
