Duet3D System won't turn on now
107
4.9k
    Jim46
    Hi All ,
    Here is what I get processing the two commands requested.
    I'm still not getting the method you sue to capture the screen. So, here's another pic. I hope you can read it. On a side note, you all are world class with this program. I'd like to catch up a little. Where would you suggest I go to learn this rather quickly?
    Cheers,
    Jim
      A Former User
      Doesn't really say why its not starting. But the only thing that should keep it from starting is not finding the Duet3. Maybe its time for a picture of how its connected?
        Jim46
        ![0_1585597426269_IMG_5078.JPG](Uploading 100%) ![0_1585597463081_IMG_5079.JPG](Uploading 100%)
        Here are two shots of my setup. The Duet is powered by the USB from a power strip. The SunFounder is powered by its plug in the same power strip. The Pi4 is powered by a connection to the SF board.
        The latest message from the Duet Web Control 2 is "Failed to connect to IP, Network error".
        Also, this Duet messaging system is not showing the Preview. WError?
        Jim
          Jim46
          Okay here are the shots. I hope they help.
          J
            Jim46
            By any chance is this indicative of a bad Duet board?
              We need to know whether the Duet is running RRF. With the Duet connected via USB to a PC by a suitable cable (one that connects the data pins, not just power), does the USB port show up on the PC? If so, does it respond to sending M115?
                Jim46
                Hi DC. I'm not sure of he answer to your question. This is the cable connected from power strip to the Duet. Perhaps this pic will help?
                Thanks,
                j
                  A Former User
                  Plug it back in the Pi and check if you have a /dev/ttyACM0 device. Connect to it with your serial terminal of choice and send it M115 to see if the Duet board responds.
                  if the above didn't make sense, just copy and paste the commands below and share the results
                  lsusb
                  stty -F /dev/ttyACM0 57600 raw -echo && {
                  cat /dev/ttyACM0 & PID=$!
                  echo "M115" > /dev/ttyACM0
                  sleep 0.5s ; kill $PID ; wait $PID
                  (edit: for those who finds the thread later - the above assumes micro usb of Duet is connected to the Pi)
                    Jim46
                    So sorry Bearer. Don't know how to do the ACM0 M115 line.
                    So I launched PuTTy and tried to execute the 7 lines of code in the black panel. Nothing was understood. I imagine I'm missing a basic understanding on how to start this. What should I do?
                      A Former User
                      Not sure what to tell you man, I specifically tried this with a raspberry pi and a duet board to make it as simple as copy and paste.
                      https://streamable.com/2wq9j
                      video didn't capture right clicking the selected text and choosing copy, nor right clicking once back in the ssh terminal to paste the text, but it works with the default setup (putty behaves in the same way, but the chrome ssh client was just easier to record as it was all in a single window)
                      @Jim46 said in Duet3D System won't turn on now:
                      that also tells me nothing about what went wrong.
                      edit; copy/pasted the ssh session for those who can't view the video (with a slight change to commands)
                      pi@raspberrypi:~ $ lsusb
                      Bus 001 Device 005: ID 1d50:60ed OpenMoko, Inc.
                      Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp.
                      Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
                      Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
                      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                      pi@raspberrypi:~ $ stty -F /dev/ttyACM0 57600 raw -echo && {
                      > echo "M115" > /dev/ttyACM0 &&
                      > sleep 0.5s && kill $PID ; wait $PID
                      [2] 829
                      FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-02-09b1
                      [2]+  Terminated              cat /dev/ttyACM0
                      pi@raspberrypi:~ $
                        A Former User
                        Maybe you can try the documentation for the Duet 2; steps 1 though 5 should be the same for the Duet 3.
                        https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                          Jim46
                          I rebooted my PC and the Pi/Duet. The commands were now accepted. Here is what came back.
                            A Former User
                            And that is with the Duet connected to the Pi with a USB cable?
                            Then you might need to try another cable, the Pi is not seeing the Duet.
                              Jim46
                              Here's is my set up:
                              The Pi and Duet are connected by the ribbon cable. The Pi is connect to the router. The Pi is connected to the SunFounder Touch Screen. The SF runs on 12v. It then powers the Pi. It also powers the Duet via the Pi ribbon cable. The Duet can also be powered directly via USB using the cable above. It makes seems to make no difference to the to the Duet Web Control 2 (on my PC with Firefox) if the Duet is powered via the Pi/SF alone or via USB as far as I can tell. If I run the Duet Web Control off the Pi, I get the same result "Failed to connect to 192.168.1.xxx, DCS Unavailable."
                              With all your amazing help, the Duet still seems to be the issue. Yes? Which brings me back to the same question Is it a bad board? Hope not!
                                A Former User
                                Still not clear how the Duets usb port is connected; either from the micro usb port on the Duet to the Pi and run the little script posted - OR - connect the micro usb port on the Duet to your computer and follow the getting connected guide linked above.
                                (The goal of that is to find out if the board is working, which is also why another usb cable needs to be tested if they do not work as expected)
                                  Jim46
                                  Here is the result of trying the M115 command using YAT. Device Manage (Windows 10) has no Yellow Triangles, The Generic USB showed the drive installed and that it is working. A new USB cable is connect directly to Duet microUSB port and a USB port on my PC. The Duet is no connected to the Pi at this point. There is no response to the YAT command.
                                  I've reconnect the Pi and Duet and left the Duet connect to the PC via USB cable. Ran YAT M115 command again. No reply.
                                  undefined 1 Reply Last reply 31 Mar 2020, 22:28 Reply Quote 0
                                    NexxCat @Jim46
                                    @Jim46
                                    The port name is shown as "BOSSA Program Port" in YAT, I believe that means the Duet is in programming mode, hence why it won't reply to gcode commands.
                                    Hopefully this helps you to program the firmware onto it: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
                                    undefined 1 Reply Last reply 31 Mar 2020, 22:31 Reply Quote 0
                                      droftarts administrators @NexxCat
                                      @NexxCat said in Duet3D System won't turn on now:
                                      @Jim46
                                      Also, is the DIAG light flashing? (This indicates the firmware is running.) In your pictures earlier, it looks dimly lit (which it would be if there's a jumper on the erase pins, and not flashing). Also, it looks like you have a jumper on the 'erase' pins of the Duet! That's the pin next to the three 5V select pins. Remove it!
                                      (Edited for clarity)
                                      ? 1 Reply Last reply 31 Mar 2020, 23:10 Reply Quote 0
                                        A Former User @droftarts
                                        @droftarts said in Duet3D System won't turn on now:
                                        🕵 .. how about that ..! 😮
                                          Jim46
                                          Hi Guys, here is a pic of the Duet3d powered by USB 2.0 from the PC It is how it was out of the box. As far as I can tell there is nothing on the erase pins near the Atmel D3M chip. Any place else a concern? I'm trying Nexxcat recommendation, but this is where I started with Tony helping remotely. I'll let you know what happens.
                                          ![0_1585762105791_IMG_5090.JPG](Uploading 100%)
                                          I'm getting a server parsing error when I try to upload this photo. What's happening? I'll try to reboot and upload again.
                                          ? 1 Reply Last reply 1 Apr 2020, 17:37 Reply Quote 0
                                          46 out of 107
