    Oddly shaped holes?
    106
    6.1k
    • Surgikillundefined
      Surgikill @mrehorstdmd
      @mrehorstdmd Pulley mounts and motor mounts don't flex. I already checked the set screws on the motor pulley, they're super tight and I loctited them on when I put them in. The hot end wiggles, but it requires a lot of forces, and ultimately the wiggle is from the x carriage flexing. The belts don't appear to be moving up and down.
      I just got done with the 30mm calibration cube, and they came out fine EXCEPT. Along the X axis it measures 29.17mm and along the Y axis it measures 29.75. I also aligned a cube diagonally, so none of the sides lined up perfectly with any axis. It was offset by 45 degrees. This one is ALSO out of square, with one side measuring 29.5 and the other side measuring 30.25. Not sure what would cause this. I was sure the diagonal one would come out square all around. Could it be a slicer issue?
      Here's some pictures. The only thing I can think of that MIGHT cause an issue is the slight angle on the belt.
      I'm guessing here, but seeing as I printed it on a diagonal, and because of the Corexy kinematics, only one stepper is working depending on the diagonal. So that would lead me to believe that it is an issue with one of my motors/their attachments to the belts?
        Surgikill
        Yea, it could possibly be my slicer as well. Now it won't even launch on my desktop. Not sure what the issue is with prusaslicer 2.2
        • arhiundefined
          arhi
          from my CNC days, this is a backlash issue
          I have zero experience with corexy so have no clue where/what/how but when you see this on a cnc milling machine you have backlash issues
          Surgikillundefined 1 Reply Last reply Reply Quote 0
            Surgikill @arhi
            @arhi That's what I was thinking but I have no idea where it's coming from. I also can't slice anything right now to test it because prusaslicer won't work.
            • arhiundefined
              arhi @Surgikill
              @Surgikill said in Oddly shaped holes?:
              Some real knowledge about corexy required here. I have none so can't say really. The regular things to check, what I'd check first is how tight are the pulleys on the motors. But I'm sure someone mentioned that in the long thread and that you already changed that as it's really kind of bacis first thing to check. On the other hand, pulleys with loose set screw moving on the flat of the shaft would totally explain this.
              What's wrong with prusa slicer? Starts up and freezes on the start? You have multiple monitors? There is a bug in the nvidia driver for multiple monitors if you try to start some GL features on the non-primary promonitor it will fail. Solution for prusa slicer is open
              %APPDATA%\PrusaSlicer\PrusaSlicer.ini
              (in my case that is C:\Users\arhimed\AppData\Roaming\PrusaSlicer\PrusaSlicer.ini )
              and delete the line window_mainframe = -8; -8; 2576; 1416; 1 (it will have of course other numbers there
              then start the prusaslicer, it will work ok.
              If you move it from your primary screen to another one, next time it will try to start from where you left it off and will not work again (so delete window_mainframe line again for it to start on main screen)
                Surgikill @arhi
                @arhi said in Oddly shaped holes?:
                AH HA. Thank you for that. Yea it's off the primary monitor. This is dumb. They need to fix that. I like to keep my CAD on the main monitor and have PrusaSlicer on the secondary.
                I can re-check the pulley on the motors, but all the set screws seem tight as balls. I'm thinking it might just be one motor causing the issue, because of the box I printed on the diagonal being more out of dimensions than the box aligned with the axes. (If you turn only one motor on a corexy, it will move the head along a 45 degree diagonal)
                  Surgikill
                  I just loosened all the belts, re-squared the entire gantry, re-tensioned all the belts and it's still having problems. I've re-designed the Y to X gantry adapters so I can lock the carbon rods into them and see if that fixes it.
                  • arhiundefined
                    arhi @Surgikill
                    You of course have NVidia card and Windows 10 😄 the only combo that have this issue. You will have the same bug with Simplify3D, Netfabb, Craftware, IdeaMaker ... it's a bug in nvidia driver GL
                    short bug description
                    If I have openGL application that want to start on screen that is not primary the application will fail to start (it will get stuck running SwapBuffers() for the first time). If you start the application on the primary screen it will start ok, you can now move it to the other screens and it will run normally, the only issue is initializing the GL canvas inside the application, after it is initialized it will run ok.
                    The issue is with any app trying to initialize GLCanvas on non primary screen. It's there for more than a year and NVidia don't give a #$%^_& about it 😞
                    No clue. Maybe one motor is losing steps, maybe one motor is broken, dunno really, never used corexy so really even my guess here is not very useful. I just chimed in 'cause that image looks like what you can see with heavy backlash on CNC and 'cause the nvidia bug. I'm following up as I'm interested in what's the culprit but can't help.
                      Surgikill @arhi
                      @arhi Yea, I just bought some steel rods and linear bearings to put on the X carriage. If that doesn't fix it, IDK what will.
                        Surgikill
                        Okay @arhi @mrehorstdmd I got new 12mm steel rods in, and regular LM12UU bearings (not bushings). The quality is definitely better. Here are some pics of a small part and a large part. Not sure what the issue still is, but quality has definitely improved. I'm going to try loosening the belts a tad, they might be too tight.
                        Coffeeundefined 1 Reply Last reply Reply Quote 0
                        • Coffeeundefined
                          Coffee @Surgikill
                          @Surgikill At least your cut is healing. LOL
                          Surgikillundefined 1 Reply Last reply Reply Quote 1
                            Surgikill @Coffee
                            @Coffee said in Oddly shaped holes?:
                            I don't even notice them anymore.
                            • arhiundefined
                              arhi
                              One suggestion: Remove extruder and mount technical pen and instead of printing write on paper until you solve the circle issue.
                              Ideally instead of pen using a ballbar would be awesome but who has ballbard these days ( https://resources.renishaw.com/en/download/white-paper-ballbar-testing-with-circle-diamond-square-machining-tests--99016 )
                              look at this: https://sphereinabox.wordpress.com/2014/07/19/delta-actuator-math-notes/
                              see the first picture, looks like your problem
                              write your own g-code and test it with a technical pen, no need to waste plastic and introduce another axis into mix 🙂
                              also check out
                              https://www.thingiverse.com/thing:3060573
                              finally, marlin have support for some backlash testing procedure
                              M425 - Backlash compensation
                              I never used it, maybe RRF have something similar, maybe just reading about what they do help you do it manually yourself..
                              • Coffeeundefined
                                Coffee @Surgikill
                                @Surgikill I hear ya. Tinkering can lead to your hands/fingers lookin' like ya washed 'em with barbed wire.
                                • arhiundefined
                                  arhi @Coffee
                                  100 days tinkering == 1 hour playing with a young cat 😄
                                    Surgikill @arhi
                                    also check out
                                    So, according to that picture, I have backlash in my Y axis, which I thought. I'm pretty sure it's "sticktion", just from watching it and moving the gantry by hand. My options are to either get rid of the igus bushings, or try to re-square the gantry because for some reason it's not square. I'm going to order some LM16UU just in case. Probably the last time I use igus stuff. It's been a nightmare. I just wanted to make the printer quieter.
                                    • arhiundefined
                                      arhi
                                      I had very nice experience with igus, I used their aluminium rods and their bushings that I pressed in printed blocks... used that on some i3 style printer and apart from being quiet all the ringing was gone 😄
                                        Surgikill @arhi
                                        @arhi I pressed them into these blocks. Maybe they're too tight? I'm really not sure.
                                        • arhiundefined
                                          arhi @Surgikill
                                          @Surgikill when they are too tight they slide harder so your motor needs to work harder and can skip steps for a while, then they "ware out" and slide perfectly, no way they can introduce slop if they are too tight in my opinion. Only issue is if they are too loose.
                                            Surgikill @arhi
                                            @arhi Here's the latest test piece. It definitely looks butter, but it's still sticking. Not sure how long these bushings need to "wear in" but I've probably put over 20-25 hours on them so far, so they should be pretty worn in.
                                            I have to do a bunch of BS to remove the extruder. I might be able to tape a pen to the side and then try and manually home it.
                                            I ordered some regular LM16UU bearings. I'd really like to get this figured out with the bushings if possible though. They are definitely quieter and provide smoother operation.
