    Duet3D System won't turn on now
    107
    4.9k
    • NexxCatundefined
      NexxCat @Jim46
      @Jim46
      The port name is shown as "BOSSA Program Port" in YAT, I believe that means the Duet is in programming mode, hence why it won't reply to gcode commands.
      Hopefully this helps you to program the firmware onto it: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
        droftarts administrators @NexxCat
        @NexxCat said in Duet3D System won't turn on now:
        @Jim46
        Also, is the DIAG light flashing? (This indicates the firmware is running.) In your pictures earlier, it looks dimly lit (which it would be if there's a jumper on the erase pins, and not flashing). Also, it looks like you have a jumper on the 'erase' pins of the Duet! That's the pin next to the three 5V select pins. Remove it!
        (Edited for clarity)
          A Former User @droftarts
          @droftarts said in Duet3D System won't turn on now:
          🕵 .. how about that ..! 😮
          • Jim46undefined
            Jim46
            Hi Guys, here is a pic of the Duet3d powered by USB 2.0 from the PC It is how it was out of the box. As far as I can tell there is nothing on the erase pins near the Atmel D3M chip. Any place else a concern? I'm trying Nexxcat recommendation, but this is where I started with Tony helping remotely. I'll let you know what happens.
            ![0_1585762105791_IMG_5090.JPG](Uploading 100%)
            I'm getting a server parsing error when I try to upload this photo. What's happening? I'll try to reboot and upload again.
            • Jim46undefined
              Jim46
                A Former User @Jim46
                @Jim46 said in Duet3D System won't turn on now:
                as long as the serial port is called BOSSA you will need to complete the firmware update procedure. If using the Bossa program doesn't help report back and I'll post instructions for using the command line version as that seems to help some struggling with the flashing.
                I'm seeing a lot of that myself; reload the page and trying again usually sufficient.
                • Jim46undefined
                  Jim46
                  Trying the Duet Web Control process doesn't work as it says unable to connect as DCS is unavailable. So back to square one. what happens if you press the reset button?
                    A Former User
                    If you're trying Duet Web Control I presume you sorted out the firmware update issue and sending M115 to the board now gives you a response?
                    • Jim46undefined
                      Jim46
                      Not really, the DWC isn't working. So I.'m dead in the water. The BOSSA is om y RPi, but all the files are empty. I tried to follow this procedure:
                      o update via USB (using a Raspberry Pi host):
                      Part1: Install bossa on the Pi with these commands:
                      sudo apt update && sudo apt install -y libwxgtk3.0-dev libreadline-dev
                      git clone https://github.com/shumatech/BOSSA
                      cd BOSSA
                      make
                      Part 2: Connect the Duet to the Pi.
                      Use a data capable USB cable from any port on the Pi to the Duet.
                      It is OK to power the Duet from only the USB (which implies the Pi has its own power)
                      It is OK to power the Duet with VIN
                      Do one or the other; do not power both ways.
                      If the Pi is part of a Duet 3 with ribbon cable, it is OK to leave this attached.
                      Part 3: Obtain firmware
                      If the Pi is part of a Duet 3, firmware will be in /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
                      The Pi4 screen came back and said, bash /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin there is no such file or directory.
                      Looks like I need a simple and clear way to get past this stumbling block.
                      Jim
                        A Former User
                        DWC isn't going to work until the Duet stops showing up as a BOSSA serial port; so until that is fixed it will not function as this implies the firmware that makes the Duet function has been erased/corrupted.
                        If you now have the Duet connected to your Pi (edit: with the USB cable!) can you please run the command lsusb from the SSH shell on the Pi and confirm it has a line that says something like Bus 001 Device 008: ID 03eb:6124 Atmel Corp. at91sam SAMBA bootloader the first part can vary a little.
                        If, and only if you do, we can proceed to flash the firmware from the Pi. (if you don't please copy paste or take a picture of what you do have)
                          A Former User
                          You can also try to run this command, it could work, but I can't say for sure as I don't have a Duet3 to test it with, but it will not do any harm at least.
                          wget -q https://pastebin.com/raw/wekeLGhS -O - | tr -d '\r' | bash
                          It will download a script I started earlier to automatically detect and recover a Duet connected to a Pi. This is how it looked when recovering a Duet 2 Meastro, it should look similar, but obviously with different filenames for you.
                          pi@raspberrypi:~ $ wget -q https://pastebin.com/raw/wekeLGhS -O - | tr -d '\r' | bash
                          Cloning into '/home/pi/BOSSA'...
                          remote: Enumerating objects: 11, done.
                          remote: Counting objects: 100% (11/11), done.
                          remote: Compressing objects: 100% (10/10), done.
                          remote: Total 1727 (delta 4), reused 5 (delta 1), pack-reused 1716
                          Receiving objects: 100% (1727/1727), 1.15 MiB | 964.00 KiB/s, done.
                          Resolving deltas: 100% (1318/1318), done.
                          make: wx-config: Command not found
                          CPP APPLET src/WordCopyArm.cpp
                          CPP COMMON src/Samba.cpp
                          CPP COMMON src/Flash.cpp
                          CPP COMMON src/D5xNvmFlash.cpp
                          CPP COMMON src/D2xNvmFlash.cpp
                          CPP COMMON src/EfcFlash.cpp
                          CPP COMMON src/EefcFlash.cpp
                          CPP COMMON src/Applet.cpp
                          CPP COMMON src/WordCopyApplet.cpp
                          CPP COMMON src/Flasher.cpp
                          CPP COMMON src/Device.cpp
                          CPP COMMON src/PosixSerialPort.cpp
                          CPP COMMON src/LinuxPortFactory.cpp
                          CPP BOSSAC src/bossac.cpp
                          CPP BOSSAC src/CmdOpts.cpp
                          LD bin/bossac
                          2020-04-02 03:43:22 URL:https://github-production-release-asset-2e65be.s3.amazonaws.com/15792831/8d0ad700-4b31-11ea-9191-66b95646e549?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20200402%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20200402T024223Z&X-Amz-Expires=300&X-Amz-Signature=2a797e70c703b8a93dec6934054f655c9ce980cd6a4bf0baa19e3ed6b6bf13c6&X-Amz-SignedHeaders=host&actor_id=0&response-content-disposition=attachment%3B%20filename%3DDuetMaestroFirmware.bin&response-content-type=application%2Foctet-stream [412148/412148] -> "/home/pi/DuetMaestroFirmware.bin" [1]
                          Erase flash
                          Done in 4.605 seconds
                          Write 412148 bytes to flash (805 pages)
                          [==============================] 100% (805/805 pages)
                          Done in 6.139 seconds
                          Verify 412148 bytes of flash
                          Verify successful
                          Done in 6.172 seconds
                          Set boot flash true
                          FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-02-09b1
                          pi@raspberrypi:~ $
                          • Jim46undefined
                            Jim46
                            Hi Bearer,
                            I've tried to run both suggestions. Here are the results. 1) is from PuTTy on my PC. 2) is from RPi4. The Duet is connected to the Pi with the ribbon cable and the USB cable from the Duet to the Pi. Hope this is useful:
                              A Former User
                              Lets go with the last setup; we should make that work. Try it again.
                              • Jim46undefined
                                Jim46
                                Okay, will do now.. thank you. best way to try use PuTTy or on the Pi?
                                  @Jim46 My bad, either should work (i mistook the first picture). Putty is fine if its easier, both run the commands on the Pi.
                                  (But we're after running the wget blah blah... command again)
                                  • Jim46undefined
                                    Jim46
                                    Okay, I'll rerun the wget line on PuTTy now
                                    • Jim46undefined
                                      Jim46
                                      I ran it and got new results.. I wanted to copy and paste the results to this page, but it acted strange. How did you do the screen above with the scrolling function?
                                      So, I ran wget again and got different results again. I'm post these below here:
                                      what do you think of these?
                                        I'm not sure, but I suspect the Duet3d guys will have some input now as we have a clear fault to address. Maybe you can try another USB cable while waiting for them to catch up to the development.
                                        • Jim46undefined
                                          Jim46
                                          above the Done in 3.467 seconds it said,
                                          bash
                                          bash Duet 3 6HC
                                          erase flash
                                          done in 3.4xxx seonds
                                          • Jim46undefined
                                            Jim46
                                            Okay I switched to a short USB cable
