    No USB port in Paneldue 7 " firmware installation
    Firmware installation
    692
    • aegoundefined
      aego @aego
      @aego and I am using Bossa 1.9
        A Former User
        A different USB cable is always a good idea; but what caused the firmware to stop working?
        aegoundefined 1 Reply Last reply Reply Quote 0
        • aegoundefined
          aego @A Former User
          @bearer I've tried with other cables too (3). The resolution was wrong and the text came out mirrored. So I decided to update the firmware.
            A Former User
            Are you getting any response from the computer when you connect the usb cable?
            Take a look in device manager or dmesg depending on OS?
            • aegoundefined
              aego
              No usb port appears on bossa panel or device manager. It's as if the USB connection with Panel due controller is not recognized.
                A Former User
                Its either the CPU damaged, or a problem in the USB chain i'd recon.
                Given firmware was running, I'd focus on USB unless something happened to suggest damage to the CPU.
                Maybe there is a problem with the port on the board? Share a close up pictue of solder joints?
                • aegoundefined
                  aego @A Former User
                    A Former User
                    most interested in the solder joints on the usb port (red circle)
                    but isn't the 4 pin connector damaged or reversed? (yellow cicle)
                    • aegoundefined
                      aego
                      (white ) from Din (board) to VTX DO ( Duet 2 wifi)
                      (black ) from Dout (board) to VRX DO ( Duet 2 wifi)
                        A Former User
                        looks like the order of the connectors are correct, but the connector looks reversed (but its not likely to be the problem)
                        anyways, a closer picture of the USB port, and better lighting please.
                        • aegoundefined
                          aego
                          • aegoundefined
                            aego @aego
                            @aego
                            the welds seem ok to me
                              A Former User
                              possibly. a little light on solder paste for the socket, but pins look okay at a distance.
                              the 4 pin connector isn't connected to anything when you're trying this right?
                              if so sounds like you should check the warranty terms with your vendor and report back.
                              • aegoundefined
                                aego
                                @bearer said in No USB port in Paneldue 7 " firmware installation:
                                all 4 pins are connected. Should I disconnect the White (Din) or Red (+5v) pin?
                                  A Former User @aego
                                  @aego said in No USB port in Paneldue 7 " firmware installation:
                                  to both the PanelDue and the Duet? if yes, try disconnecting all 4 from one side just to be sure.
                                  • aegoundefined
                                    aego
                                    Now after desconnecting all pins, the USB port appeared.
                                    I triggered the Write button, started the process and was soon interruped with the following error message " Flash command failled"
                                      droftarts administrators @aego
                                      @aego I was going to say you need to disconnect the PanelDue from the Duet, but you seem to have done that now.
                                      See https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update for flashing instructions.
                                      Did you check the Erase all, Lock, and Boot from flash boxes?
                                        A Former User @aego
                                        I followed the instructions at https://miscsolutions.wordpress.com/paneldue/,
                                        no you didn't 🤦
                                        • aegoundefined
                                          aego
                                          Yes, I triggered Erase and Reset buttons. I'll reread the instructions and if I jumped anything, I'm sorry
                                          • aegoundefined
                                            aego @aego
                                            @aego
                                            Anyway there was evolution thanks to bearer
                                            my thanks
