    No USB port in Paneldue 7 " firmware installation
    Firmware installation
    692
    • aegoundefined
      aego
      No usb port appears on bossa panel or device manager. It's as if the USB connection with Panel due controller is not recognized.
        A Former User
        Its either the CPU damaged, or a problem in the USB chain i'd recon.
        Given firmware was running, I'd focus on USB unless something happened to suggest damage to the CPU.
        Maybe there is a problem with the port on the board? Share a close up pictue of solder joints?
        aegoundefined 1 Reply Last reply Reply Quote 0
        • aegoundefined
          aego @A Former User
            A Former User
            most interested in the solder joints on the usb port (red circle)
            but isn't the 4 pin connector damaged or reversed? (yellow cicle)
            • aegoundefined
              aego
              (white ) from Din (board) to VTX DO ( Duet 2 wifi)
              (black ) from Dout (board) to VRX DO ( Duet 2 wifi)
                A Former User
                looks like the order of the connectors are correct, but the connector looks reversed (but its not likely to be the problem)
                anyways, a closer picture of the USB port, and better lighting please.
                • aegoundefined
                  aego
                  • aegoundefined
                    aego @aego
                    @aego
                    the welds seem ok to me
                      A Former User
                      possibly. a little light on solder paste for the socket, but pins look okay at a distance.
                      the 4 pin connector isn't connected to anything when you're trying this right?
                      if so sounds like you should check the warranty terms with your vendor and report back.
                      • aegoundefined
                        aego
                        @bearer said in No USB port in Paneldue 7 " firmware installation:
                        all 4 pins are connected. Should I disconnect the White (Din) or Red (+5v) pin?
                          A Former User @aego
                          @aego said in No USB port in Paneldue 7 " firmware installation:
                          to both the PanelDue and the Duet? if yes, try disconnecting all 4 from one side just to be sure.
                          • aegoundefined
                            aego
                            Now after desconnecting all pins, the USB port appeared.
                            I triggered the Write button, started the process and was soon interruped with the following error message " Flash command failled"
                              droftarts administrators @aego
                              @aego I was going to say you need to disconnect the PanelDue from the Duet, but you seem to have done that now.
                              See https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update for flashing instructions.
                              Did you check the Erase all, Lock, and Boot from flash boxes?
                                A Former User @aego
                                I followed the instructions at https://miscsolutions.wordpress.com/paneldue/,
                                no you didn't 🤦
                                • aegoundefined
                                  aego
                                  Yes, I triggered Erase and Reset buttons. I'll reread the instructions and if I jumped anything, I'm sorry
                                  • aegoundefined
                                    aego @aego
                                    @aego
                                    Anyway there was evolution thanks to bearer
                                    my thanks
                                    • aegoundefined
                                      aego @aego
                                      @aego
                                      Bearer you are right, I did not check the Erase all, Lock, and Boot from flash boxes. My failure to read the instructions quickly. Again sorry and thank you, thank you very much
