RepRapFirmware 3.01-RC6 released
edit: NOPE, that was not a good idea.
maybe this works better, specifying all the packages to fulfill dependencies for duetsoftwareframework=1.2.5.0
grep duet3d -r /etc/apt | grep unstable && sudo apt install duetcontrolserver=1.2.5.0 duetsd=1.0.5 duettools=1.2.5.0 duetwebserver=1.2.3.1 duetwebcontrol=2.0.7-1 reprapfirmware=1.2.5.0-1 duetruntime=1.2.5.0 duetsoftwareframework=1.2.5.0 || echo Please swtich to unstable list. edit changed to fail if not on unstable list.
Also according to chrishamm switching to instead of adding the unstable list may be the way to go
#comment out stable list sudo sed -i '/ stable/s/^/#/g' /etc/apt/sources.list.d/duet3d.list #add unstable list echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.list
@chas2706 said in RepRapFirmware 3.01-RC6 released:
Ok that's an improvement but for me power cycling, resetting or re-installing made no difference.
I've had to revert to RRF3.01RC3 but now running on the wrong version of DWC because there is no indication anywhere how we SBC users can download a specific version of DWC.As @bearer pointa out, rolling back isn't tricky. Tbh, theres a reason that it's a beta firmware, so it should be obvious that backups are wise when trying a new "upgrade".
I'd still be interested to know the output of you logs for the DCS service.
the start of the log is probably more relevant than the end of it.
@ChrisP said in RepRapFirmware 3.01-RC6 released:
I understand the meaning of beta firmware but if you have Duet3 with SBC and dare to "upgrade" there is no guarantee that if upon failure an older backup will work.
I now have this problem running RRF3.01.RC3 from a backup:So now I will be spending numerous hours starting afresh!
that would imply your backup isn't covering your needs. simply shutting down the pi and cloning or imaging the SD card would take care of all but the RRF firmware on the Duet which can be flashed after restoring an old SD card. (caveat if they changed the iap binary)
@chas2706
You really shouldn't need to start afresh. Even if you do, as long as you have a copy of the sys & macros folders it should take longer to burn a new raspbian image than it does to get that fresh Linux install to a working printer. I can't remember it taking more than about 15 mins following the guide on the wiki.You'll be back up and running in no time
@Marco-Bona said in RepRapFirmware 3.01-RC6 released:
1_ I continue to have the problem with the correct visualization of the Layers (yesterday @droftarts said it would be solved with the new build)
Strange, because this is mentioned specifically in the notes;
Bug fixes:
When printing a file, the first layer time was reported incorrectly, and when the print completed the total print time reported was incorrectHave you updated the firmware AND the DWC?
see my edited post https://forum.duet3d.com/post/143326
apt allows specification of a version after the thing you are installing.
sudo apt install duetsoftwareframework=1.2.4.0
This, plus a few more commands below, gives you total control over the duet installation on the Pi. You can force it into a good (or bad!) state.
You may want to do 'uninstall' in certain circumstances, or use the --reinstall flag (which forces a complete install even if apt thinks that version is already installed) Examples:
sudo apt uninstall duetsoftwareframework
sudo apt install duetsoftwareframework --reinstall
You can list all available versions via:
sudo apt list -a duetsoftwareframework Listing... Done duetsoftwareframework/unstable,now 1.3.0 armhf [installed] duetsoftwareframework/unstable 1.2.5.0 armhf duetsoftwareframework/unstable,stable 1.2.4.0 armhf duetsoftwareframework/unstable 1.2.3.1 armhf duetsoftwareframework/unstable,stable 1.2.3.0 armhf duetsoftwareframework/unstable,stable 1.2.2.1 armhf duetsoftwareframework/unstable 1.2.2.0 armhf duetsoftwareframework/unstable 1.2.1.0 armhf duetsoftwareframework/unstable 1.2.0.0 armhf duetsoftwareframework/unstable,stable 1.1.0.5 armhf duetsoftwareframework/unstable 1.1.0.4 armhf duetsoftwareframework/unstable 1.1.0.3 armhf duetsoftwareframework/unstable 1.1.0.2 armhf duetsoftwareframework/unstable 1.1.0.1 armhf duetsoftwareframework/unstable 1.1.0.0 armhf duetsoftwareframework/unstable,stable 1.0.4.1 armhf duetsoftwareframework/unstable 1.0.4.0 armhf duetsoftwareframework/unstable 1.0.3.5 armhf duetsoftwareframework/unstable 1.0.3.3 armhf duetsoftwareframework/unstable 1.0.3.2 armhf duetsoftwareframework/stable 1.0.3.1 armhf Generally, when doing a simple install, apt will deal properly with dependencies. During uninstalls and reinstalls in often does not. You can list all dependencies via:
apt-cache depends duetsoftwareframework duetsoftwareframework Depends: duetcontrolserver Depends: duetsd Depends: duettools Depends: duetwebserver Depends: duetwebcontrol Depends: reprapfirmware Depends: reprapfirmware -
@Danal said in RepRapFirmware 3.01-RC6 released:
not when downgrading dsf it seems
pi@raspberrypi:~ $ sudo apt install duetsoftwareframework=1.2.4.0 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: duetsoftwareframework : Depends: duetcontrolserver (= 1.2.4.0) but 1.3.0 is to be installed Depends: duettools (= 1.2.4.0) but 1.3.0 is to be installed Depends: reprapfirmware (<= 1.2.4.0-999) but 1.3.0-2 is to be installed E: Unable to correct problems, you have held broken packages. pi@raspberrypi:~ $
thus my post detailing all the verions..
Agreed, during anything but a simple install, it often does not.
That's why I showed the commands that list dependencies and versions.
@bearer said in RepRapFirmware 3.01-RC6 released:
maybe this works better, specifying all the packages to fulfill dependencies for duetsoftwareframework=1.2.5.0Thanks for the suggestion but here's what I got:
pi@Duet3:~ $ sudo apt install duetcontrolserver=1.2.5.0 duetsd=1.0.5 duettools=1.2.5.0 duetwebserver=1.2.3.1 duetwebcontrol=2.0.7-1 reprapfirmware=1.2.5.0-1 duetruntime=1.2.5.0 duetsoftwareframework=1.2.5.0
E: Version '1.2.5.0' for 'duetcontrolserver' was not found
E: Version '1.2.5.0' for 'duettools' was not found
E: Version '1.2.3.1' for 'duetwebserver' was not found
E: Version '2.0.7-1' for 'duetwebcontrol' was not found
E: Version '1.2.5.0-1' for 'reprapfirmware' was not found
E: Version '1.2.5.0' for 'duetruntime' was not found
E: Version '1.2.5.0' for 'duetsoftwareframework' was not found
pi@Duet3:~ $For me there are a number of issues.
After you have installed a beta version and run into difficulties, re-installing a back up can create a number of issues.
Firstly you don't know which specific version of RRF your back up was on unless you were smart enough to include the version number in the backup name (all versions are named " Duet3Firmware_MB6HC.bin")!. So by default your back up will fail because your board is flashed with the latest version.
Secondly, your version of DWC will be the wrong version and for SBC users apparently, this is just tough luck.
Summing it up, a backup will only work if you never upgraded in the first place! -
When running a Pi, there is more to a backup than the binary file loaded into the Duet board (and/or the contents of sys and macros). A lot more.
A backup of the entire SD in the Pi will always work to execute a recovery. After booting from such a full SD card backup, it is necessary to load firmware into the board. That backup of the entire SD card, by definition, has the firmware .bin files that were loaded sometime in the past. No name problems, no downloads, "just works". If the backup is of the entire card.
Maybe this should all be on a dozuki somewhere... and I'd be happy to write it up.
(P.S. For anybody that doesn't know, I have no association with Duet the company. I am just a vocal user)
(P.S. For anybody that doesn't know, I have no association with Duet the company. I am just a vocal user)The backup was of the entire card and I initially realised that there were problems because the firmware on the board was of the new build so I grabbed a copy of Duet3Firmware_MB6HC.bin found in /opt/dsf/sd/sys i.e "Duet3Firmware_MB6HC.bin" and flashed it to the board but still have the above mentioned issues.
If a full backup of the entire SD "always works" how come the DWC does not downgrade to the correct version?
Also, if you want to backup the entire Pi SD card to a windows PC without physically touching the card in the Duet+Pi, here is an outline of how to do that:
One time installation tasks:
#At your windows machine, create a shared drive to receive the backups. Allow user 'guest' read/write access (assuming your home network is physically secure, or you are otherwise comfortable with this) #On the Pi sudo apt-get install pv git clone https://github.com/lzkelley/bkup_rpimage.git #Edit file /etc/fstab, add a line at the end: //windows-machine-name/shared-drive-name /linux-mount-point cifs user=pi,password=raspberry 0 0 mkidir a directory that matches the mount point above Each Time, to run a backup:
sudo mount linux-mount-point sudo sh ./bkup_rpimage/bkup_rpimage.sh start -cz /linux-mount-point/$(uname -n).img NOTE: The running backup WILL disrupt a running print, do not backup while doing anything else.
In a recovery situation, the file deposited on the shared drive is used as an input to balena etcher (or other similar tools) to make a recovery SD for the Pi.
If you put a physically different SD card, that was copied before any upgrades, if you put that card in the Pi and boot, then every file on that card will be at the version it was the moment that backup was taken. Including DWC.
huh, thats odd; you'd have to have the unstabe list to do the upgrade so the old versions should still be on the list; i did try it just before.
if you accept flashing the duet 3 using usb+bossa then backing up the sd card will work as the matching firmware file should be in /opt/dsf/sd/sys
if you hook the duet to the pi with usb this would flash that firmware to the duet without worrying about iap files or anything.
wget https://pastebin.com/raw/Wa1kYf3G -O - | tr -d "\r" | bash
and if dcs happened to be working
echo M997 S0| sudo /opt/dsf/bin/CodeConsole
should achieve the same without having to deal with usb. -
This post is deleted! -
I made the back up by taking out the sd card, inserting it in my pc and then using win32disk manager and I can verify that it works because while I was on the same RRF version I deliberately flashed a different sd card and re-installed using my backup. In the process I made lots of changes, backed them up and re- installed - all with success but when you "upgrade" the result is so different
