    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.8k
      A Former User @chas2706
      @chas2706 said in RepRapFirmware 3.01-RC6 released:
      So now I will be spending numerous hours starting afresh!
      see my edited post https://forum.duet3d.com/post/143326
      • Danalundefined
        Danal
        because there is no indication anywhere how we SBC users can download a specific version of DWC.
        apt allows specification of a version after the thing you are installing.
        sudo apt install duetsoftwareframework=1.2.4.0
        This, plus a few more commands below, gives you total control over the duet installation on the Pi. You can force it into a good (or bad!) state.
        You may want to do 'uninstall' in certain circumstances, or use the --reinstall flag (which forces a complete install even if apt thinks that version is already installed) Examples:
        sudo apt uninstall duetsoftwareframework
        sudo apt install duetsoftwareframework --reinstall
        You can list all available versions via:
        sudo apt list -a duetsoftwareframework
        Listing... Done
        duetsoftwareframework/unstable,now 1.3.0 armhf [installed]
        duetsoftwareframework/unstable 1.2.5.0 armhf
        duetsoftwareframework/unstable,stable 1.2.4.0 armhf
        duetsoftwareframework/unstable 1.2.3.1 armhf
        duetsoftwareframework/unstable,stable 1.2.3.0 armhf
        duetsoftwareframework/unstable,stable 1.2.2.1 armhf
        duetsoftwareframework/unstable 1.2.2.0 armhf
        duetsoftwareframework/unstable 1.2.1.0 armhf
        duetsoftwareframework/unstable 1.2.0.0 armhf
        duetsoftwareframework/unstable,stable 1.1.0.5 armhf
        duetsoftwareframework/unstable 1.1.0.4 armhf
        duetsoftwareframework/unstable 1.1.0.3 armhf
        duetsoftwareframework/unstable 1.1.0.2 armhf
        duetsoftwareframework/unstable 1.1.0.1 armhf
        duetsoftwareframework/unstable 1.1.0.0 armhf
        duetsoftwareframework/unstable,stable 1.0.4.1 armhf
        duetsoftwareframework/unstable 1.0.4.0 armhf
        duetsoftwareframework/unstable 1.0.3.5 armhf
        duetsoftwareframework/unstable 1.0.3.3 armhf
        duetsoftwareframework/unstable 1.0.3.2 armhf
        duetsoftwareframework/stable 1.0.3.1 armhf
        Generally, when doing a simple install, apt will deal properly with dependencies. During uninstalls and reinstalls in often does not. You can list all dependencies via:
        apt-cache depends duetsoftwareframework
          Depends: duetcontrolserver
          Depends: duetsd
          Depends: duettools
          Depends: duetwebserver
          Depends: duetwebcontrol
          Depends: reprapfirmware
          A Former User @Danal
          @Danal said in RepRapFirmware 3.01-RC6 released:
          not when downgrading dsf it seems
          pi@raspberrypi:~ $ sudo apt install duetsoftwareframework=1.2.4.0
          Reading package lists... Done
          Building dependency tree
          Reading state information... Done
          Some packages could not be installed. This may mean that you have
          requested an impossible situation or if you are using the unstable
          distribution that some required packages have not yet been created
          or been moved out of Incoming.
          The following information may help to resolve the situation:
          The following packages have unmet dependencies:
           duetsoftwareframework : Depends: duetcontrolserver (= 1.2.4.0) but 1.3.0 is to be installed
                                   Depends: duettools (= 1.2.4.0) but 1.3.0 is to be installed
                                   Depends: reprapfirmware (<= 1.2.4.0-999) but 1.3.0-2 is to be installed
          E: Unable to correct problems, you have held broken packages.
          pi@raspberrypi:~ $
          thus my post detailing all the verions..
          • Danalundefined
            Danal @A Former User
            Agreed, during anything but a simple install, it often does not.
            That's why I showed the commands that list dependencies and versions.
            • chas2706undefined
              chas2706
              @bearer said in RepRapFirmware 3.01-RC6 released:
              edit: NOPE, that was not a good idea.
              maybe this works better, specifying all the packages to fulfill dependencies for duetsoftwareframework=1.2.5.0
              Thanks for the suggestion but here's what I got:
              pi@Duet3:~ $ sudo apt install duetcontrolserver=1.2.5.0 duetsd=1.0.5 duettools=1.2.5.0 duetwebserver=1.2.3.1 duetwebcontrol=2.0.7-1 reprapfirmware=1.2.5.0-1 duetruntime=1.2.5.0 duetsoftwareframework=1.2.5.0
              E: Version '1.2.5.0' for 'duetcontrolserver' was not found
              E: Version '1.2.5.0' for 'duettools' was not found
              E: Version '1.2.3.1' for 'duetwebserver' was not found
              E: Version '2.0.7-1' for 'duetwebcontrol' was not found
              E: Version '1.2.5.0-1' for 'reprapfirmware' was not found
              E: Version '1.2.5.0' for 'duetruntime' was not found
              E: Version '1.2.5.0' for 'duetsoftwareframework' was not found
              pi@Duet3:~ $
              For me there are a number of issues.
              After you have installed a beta version and run into difficulties, re-installing a back up can create a number of issues.
              Firstly you don't know which specific version of RRF your back up was on unless you were smart enough to include the version number in the backup name (all versions are named " Duet3Firmware_MB6HC.bin")!. So by default your back up will fail because your board is flashed with the latest version.
              Secondly, your version of DWC will be the wrong version and for SBC users apparently, this is just tough luck.
              Summing it up, a backup will only work if you never upgraded in the first place!
              • Danalundefined
                Danal
                When running a Pi, there is more to a backup than the binary file loaded into the Duet board (and/or the contents of sys and macros). A lot more.
                A backup of the entire SD in the Pi will always work to execute a recovery. After booting from such a full SD card backup, it is necessary to load firmware into the board. That backup of the entire SD card, by definition, has the firmware .bin files that were loaded sometime in the past. No name problems, no downloads, "just works". If the backup is of the entire card.
                Maybe this should all be on a dozuki somewhere... and I'd be happy to write it up.
                (P.S. For anybody that doesn't know, I have no association with Duet the company. I am just a vocal user)
                • chas2706undefined
                  chas2706
                  The backup was of the entire card and I initially realised that there were problems because the firmware on the board was of the new build so I grabbed a copy of Duet3Firmware_MB6HC.bin found in /opt/dsf/sd/sys i.e "Duet3Firmware_MB6HC.bin" and flashed it to the board but still have the above mentioned issues.
                  • chas2706undefined
                    chas2706
                    If a full backup of the entire SD "always works" how come the DWC does not downgrade to the correct version?
                    • Danalundefined
                      Danal
                      Also, if you want to backup the entire Pi SD card to a windows PC without physically touching the card in the Duet+Pi, here is an outline of how to do that:
                      One time installation tasks:
                      #At your windows machine, create a shared drive to receive the backups. Allow user 'guest' read/write access (assuming your home network is physically secure, or you are otherwise comfortable with this)
                      #On the Pi
                      sudo apt-get install pv
                      git clone https://github.com/lzkelley/bkup_rpimage.git
                      #Edit file /etc/fstab, add a line at the end:
                      //windows-machine-name/shared-drive-name /linux-mount-point cifs user=pi,password=raspberry 0 0
                      mkidir a directory that matches the mount point above
                      Each Time, to run a backup:
                      sudo mount linux-mount-point
                      sudo sh ./bkup_rpimage/bkup_rpimage.sh start -cz /linux-mount-point/$(uname -n).img
                      NOTE: The running backup WILL disrupt a running print, do not backup while doing anything else.
                      In a recovery situation, the file deposited on the shared drive is used as an input to balena etcher (or other similar tools) to make a recovery SD for the Pi.
                      • Danalundefined
                        Danal @chas2706
                        If you put a physically different SD card, that was copied before any upgrades, if you put that card in the Pi and boot, then every file on that card will be at the version it was the moment that backup was taken. Including DWC.
                          huh, thats odd; you'd have to have the unstabe list to do the upgrade so the old versions should still be on the list; i did try it just before.
                          if you accept flashing the duet 3 using usb+bossa then backing up the sd card will work as the matching firmware file should be in /opt/dsf/sd/sys
                          if you hook the duet to the pi with usb this would flash that firmware to the duet without worrying about iap files or anything.
                          wget https://pastebin.com/raw/Wa1kYf3G -O - | tr -d "\r" | bash
                          and if dcs happened to be working echo M997 S0| sudo /opt/dsf/bin/CodeConsole should achieve the same without having to deal with usb.
                          • Danalundefined
                            Danal @chas2706
                            This post is deleted!
                            • chas2706undefined
                              chas2706
                              I made the back up by taking out the sd card, inserting it in my pc and then using win32disk manager and I can verify that it works because while I was on the same RRF version I deliberately flashed a different sd card and re-installed using my backup. In the process I made lots of changes, backed them up and re- installed - all with success but when you "upgrade" the result is so different
                              • Danalundefined
                                Danal @chas2706
                                The Duet board has flash that has the running firmware. It absolutely does have to be re-flashed to change the firmware release.
                                EVERYTHING else is on the SD card. That is the physical setup of a Raspberry Pi. I don't doubt what you are seeing, your symptoms. At the same time, if a backup SD card was taken before the upgrade, and that backup was properly restored (such as a physically different card with the prior copy being put in the Pi), then it is absolutely not possible that the files are somehow at a different level than the backup. Pi hardware does not have any other storage than the SD.
                                So again, I'm just a fellow user, trying to help improve understanding so that people don't get painted into corners... if DWC didn't regress to the level it was when the backup was taken, the the backup/restore procedure is the thing to fix for next time.
                                • Danalundefined
                                  Danal
                                  Wait a minute... "Win32 disk manager"??? That won't deal with the Unix partitions on that card. Will it?
                                    A Former User
                                    This ought be a passing problem for most people as a stable release becomes available that most people can actually use without being recommended to switch to the unstable list where stuff like this so to some degree is acceptable.
                                    And for now; we can try to make the best of it.
                                      indirectly; as in it'll do a bit for bit copy that will work unless you want to restore to a smaller sd card
                                      (not sure if it applies to SD cards as it did with old harddrives, but I always leave a few megabytes unused to allow for X gigabyte from vendor A not being the same as X gigabyte from vendor B)
                                      • Danalundefined
                                        Danal
                                        Are we talking about this:
                                          @Danal yaeh - dd for windows basically
                                          • Danalundefined
                                            Danal
                                            Win32 disk imager has been known to copy portions of a card, and not copy other portions, in certain SD readers. Which makes it very difficult for other people to diagnose.
                                            Personally, I would never use it. Balena etcher or SD Writer or...
                                            Probably not what happened here; but something did happen to that backup. Some confusion.
