    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.2k
      A Former User
      the start of the log is probably more relevant than the end of it.
      • chas2706undefined
        chas2706
        @ChrisP said in RepRapFirmware 3.01-RC6 released:
        As @bearer pointa out, rolling back isn't tricky. Tbh, theres a reason that it's a beta firmware, so it should be obvious that backups are wise when trying a new "upgrade".
        I understand the meaning of beta firmware but if you have Duet3 with SBC and dare to "upgrade" there is no guarantee that if upon failure an older backup will work.
        I now have this problem running RRF3.01.RC3 from a backup:
        So now I will be spending numerous hours starting afresh!
        A Former User? ChrisPundefined 3 Replies Last reply Reply Quote 0
          A Former User @chas2706
          @chas2706 said in RepRapFirmware 3.01-RC6 released:
          that would imply your backup isn't covering your needs. simply shutting down the pi and cloning or imaging the SD card would take care of all but the RRF firmware on the Duet which can be flashed after restoring an old SD card. (caveat if they changed the iap binary)
          • ChrisPundefined
            ChrisP @chas2706
            @chas2706
            You really shouldn't need to start afresh. Even if you do, as long as you have a copy of the sys & macros folders it should take longer to burn a new raspbian image than it does to get that fresh Linux install to a working printer. I can't remember it taking more than about 15 mins following the guide on the wiki.
            You'll be back up and running in no time 👍
              droftarts administrators @Marco Bona
              @Marco-Bona said in RepRapFirmware 3.01-RC6 released:
              1_ I continue to have the problem with the correct visualization of the Layers (yesterday @droftarts said it would be solved with the new build)
              Strange, because this is mentioned specifically in the notes;
              Bug fixes:
              When printing a file, the first layer time was reported incorrectly, and when the print completed the total print time reported was incorrect
              Have you updated the firmware AND the DWC?
              Marco Bonaundefined 1 Reply Last reply Reply Quote 0
                see my edited post https://forum.duet3d.com/post/143326
                • Danalundefined
                  Danal
                  because there is no indication anywhere how we SBC users can download a specific version of DWC.
                  apt allows specification of a version after the thing you are installing.
                  sudo apt install duetsoftwareframework=1.2.4.0
                  This, plus a few more commands below, gives you total control over the duet installation on the Pi. You can force it into a good (or bad!) state.
                  You may want to do 'uninstall' in certain circumstances, or use the --reinstall flag (which forces a complete install even if apt thinks that version is already installed) Examples:
                  sudo apt uninstall duetsoftwareframework
                  sudo apt install duetsoftwareframework --reinstall
                  You can list all available versions via:
                  sudo apt list -a duetsoftwareframework
                  Listing... Done
                  duetsoftwareframework/unstable,now 1.3.0 armhf [installed]
                  duetsoftwareframework/unstable 1.2.5.0 armhf
                  duetsoftwareframework/unstable,stable 1.2.4.0 armhf
                  duetsoftwareframework/unstable 1.2.3.1 armhf
                  duetsoftwareframework/unstable,stable 1.2.3.0 armhf
                  duetsoftwareframework/unstable,stable 1.2.2.1 armhf
                  duetsoftwareframework/unstable 1.2.2.0 armhf
                  duetsoftwareframework/unstable 1.2.1.0 armhf
                  duetsoftwareframework/unstable 1.2.0.0 armhf
                  duetsoftwareframework/unstable,stable 1.1.0.5 armhf
                  duetsoftwareframework/unstable 1.1.0.4 armhf
                  duetsoftwareframework/unstable 1.1.0.3 armhf
                  duetsoftwareframework/unstable 1.1.0.2 armhf
                  duetsoftwareframework/unstable 1.1.0.1 armhf
                  duetsoftwareframework/unstable 1.1.0.0 armhf
                  duetsoftwareframework/unstable,stable 1.0.4.1 armhf
                  duetsoftwareframework/unstable 1.0.4.0 armhf
                  duetsoftwareframework/unstable 1.0.3.5 armhf
                  duetsoftwareframework/unstable 1.0.3.3 armhf
                  duetsoftwareframework/unstable 1.0.3.2 armhf
                  duetsoftwareframework/stable 1.0.3.1 armhf
                  Generally, when doing a simple install, apt will deal properly with dependencies. During uninstalls and reinstalls in often does not. You can list all dependencies via:
                  apt-cache depends duetsoftwareframework
                    Depends: duetcontrolserver
                    Depends: duetsd
                    Depends: duettools
                    Depends: duetwebserver
                    Depends: duetwebcontrol
                    Depends: reprapfirmware
                    A Former User @Danal
                    @Danal said in RepRapFirmware 3.01-RC6 released:
                    not when downgrading dsf it seems
                    pi@raspberrypi:~ $ sudo apt install duetsoftwareframework=1.2.4.0
                    Reading package lists... Done
                    Building dependency tree
                    Reading state information... Done
                    Some packages could not be installed. This may mean that you have
                    requested an impossible situation or if you are using the unstable
                    distribution that some required packages have not yet been created
                    or been moved out of Incoming.
                    The following information may help to resolve the situation:
                    The following packages have unmet dependencies:
                     duetsoftwareframework : Depends: duetcontrolserver (= 1.2.4.0) but 1.3.0 is to be installed
                                             Depends: duettools (= 1.2.4.0) but 1.3.0 is to be installed
                                             Depends: reprapfirmware (<= 1.2.4.0-999) but 1.3.0-2 is to be installed
                    E: Unable to correct problems, you have held broken packages.
                    pi@raspberrypi:~ $
                    thus my post detailing all the verions..
                    • Danalundefined
                      Danal @A Former User
                      Agreed, during anything but a simple install, it often does not.
                      That's why I showed the commands that list dependencies and versions.
                      • chas2706undefined
                        chas2706
                        @bearer said in RepRapFirmware 3.01-RC6 released:
                        edit: NOPE, that was not a good idea.
                        maybe this works better, specifying all the packages to fulfill dependencies for duetsoftwareframework=1.2.5.0
                        Thanks for the suggestion but here's what I got:
                        pi@Duet3:~ $ sudo apt install duetcontrolserver=1.2.5.0 duetsd=1.0.5 duettools=1.2.5.0 duetwebserver=1.2.3.1 duetwebcontrol=2.0.7-1 reprapfirmware=1.2.5.0-1 duetruntime=1.2.5.0 duetsoftwareframework=1.2.5.0
                        E: Version '1.2.5.0' for 'duetcontrolserver' was not found
                        E: Version '1.2.5.0' for 'duettools' was not found
                        E: Version '1.2.3.1' for 'duetwebserver' was not found
                        E: Version '2.0.7-1' for 'duetwebcontrol' was not found
                        E: Version '1.2.5.0-1' for 'reprapfirmware' was not found
                        E: Version '1.2.5.0' for 'duetruntime' was not found
                        E: Version '1.2.5.0' for 'duetsoftwareframework' was not found
                        pi@Duet3:~ $
                        For me there are a number of issues.
                        After you have installed a beta version and run into difficulties, re-installing a back up can create a number of issues.
                        Firstly you don't know which specific version of RRF your back up was on unless you were smart enough to include the version number in the backup name (all versions are named " Duet3Firmware_MB6HC.bin")!. So by default your back up will fail because your board is flashed with the latest version.
                        Secondly, your version of DWC will be the wrong version and for SBC users apparently, this is just tough luck.
                        Summing it up, a backup will only work if you never upgraded in the first place!
                        • Danalundefined
                          Danal
                          When running a Pi, there is more to a backup than the binary file loaded into the Duet board (and/or the contents of sys and macros). A lot more.
                          A backup of the entire SD in the Pi will always work to execute a recovery. After booting from such a full SD card backup, it is necessary to load firmware into the board. That backup of the entire SD card, by definition, has the firmware .bin files that were loaded sometime in the past. No name problems, no downloads, "just works". If the backup is of the entire card.
                          Maybe this should all be on a dozuki somewhere... and I'd be happy to write it up.
                          (P.S. For anybody that doesn't know, I have no association with Duet the company. I am just a vocal user)
                          • chas2706undefined
                            chas2706
                            The backup was of the entire card and I initially realised that there were problems because the firmware on the board was of the new build so I grabbed a copy of Duet3Firmware_MB6HC.bin found in /opt/dsf/sd/sys i.e "Duet3Firmware_MB6HC.bin" and flashed it to the board but still have the above mentioned issues.
                            • chas2706undefined
                              chas2706
                              If a full backup of the entire SD "always works" how come the DWC does not downgrade to the correct version?
                              • Danalundefined
                                Danal
                                Also, if you want to backup the entire Pi SD card to a windows PC without physically touching the card in the Duet+Pi, here is an outline of how to do that:
                                One time installation tasks:
                                #At your windows machine, create a shared drive to receive the backups. Allow user 'guest' read/write access (assuming your home network is physically secure, or you are otherwise comfortable with this)
                                #On the Pi
                                sudo apt-get install pv
                                git clone https://github.com/lzkelley/bkup_rpimage.git
                                #Edit file /etc/fstab, add a line at the end:
                                //windows-machine-name/shared-drive-name /linux-mount-point cifs user=pi,password=raspberry 0 0
                                mkidir a directory that matches the mount point above
                                Each Time, to run a backup:
                                sudo mount linux-mount-point
                                sudo sh ./bkup_rpimage/bkup_rpimage.sh start -cz /linux-mount-point/$(uname -n).img
                                NOTE: The running backup WILL disrupt a running print, do not backup while doing anything else.
                                In a recovery situation, the file deposited on the shared drive is used as an input to balena etcher (or other similar tools) to make a recovery SD for the Pi.
                                • Danalundefined
                                  Danal @chas2706
                                  If you put a physically different SD card, that was copied before any upgrades, if you put that card in the Pi and boot, then every file on that card will be at the version it was the moment that backup was taken. Including DWC.
                                    huh, thats odd; you'd have to have the unstabe list to do the upgrade so the old versions should still be on the list; i did try it just before.
                                    if you accept flashing the duet 3 using usb+bossa then backing up the sd card will work as the matching firmware file should be in /opt/dsf/sd/sys
                                    if you hook the duet to the pi with usb this would flash that firmware to the duet without worrying about iap files or anything.
                                    wget https://pastebin.com/raw/Wa1kYf3G -O - | tr -d "\r" | bash
                                    and if dcs happened to be working echo M997 S0| sudo /opt/dsf/bin/CodeConsole should achieve the same without having to deal with usb.
                                    • Danalundefined
                                      Danal @chas2706
                                      This post is deleted!
                                      • chas2706undefined
                                        chas2706
                                        I made the back up by taking out the sd card, inserting it in my pc and then using win32disk manager and I can verify that it works because while I was on the same RRF version I deliberately flashed a different sd card and re-installed using my backup. In the process I made lots of changes, backed them up and re- installed - all with success but when you "upgrade" the result is so different
                                        • Danalundefined
                                          Danal @chas2706
                                          The Duet board has flash that has the running firmware. It absolutely does have to be re-flashed to change the firmware release.
                                          EVERYTHING else is on the SD card. That is the physical setup of a Raspberry Pi. I don't doubt what you are seeing, your symptoms. At the same time, if a backup SD card was taken before the upgrade, and that backup was properly restored (such as a physically different card with the prior copy being put in the Pi), then it is absolutely not possible that the files are somehow at a different level than the backup. Pi hardware does not have any other storage than the SD.
                                          So again, I'm just a fellow user, trying to help improve understanding so that people don't get painted into corners... if DWC didn't regress to the level it was when the backup was taken, the the backup/restore procedure is the thing to fix for next time.
                                          • Danalundefined
                                            Danal
                                            Wait a minute... "Win32 disk manager"??? That won't deal with the Unix partitions on that card. Will it?
