    No output from G32 on DSF 1.2.4 / DWC 2.07
    Duet Web Control
    14
    64
    3.3k
    • chas2706undefined
      chas2706
      @dc42 said in No output from G32 on DSF 1.2.4 / DWC 2.07:
      As a temporary workaround until this is fixed, you can display the G32 deviation by running M409 K"move.calibration". tested using RRF 3.01-RC4 (recommended DSF version for this release is 1.2.5).
      Ok thanks for that.
      • richardmckennaundefined
        richardmckenna
        Has development stopped on DSF? Not seen any commits on the repo since January. Is @chrishamm ok?
        • Danalundefined
          Danal @richardmckenna
          @richardmckenna said in No output from G32 on DSF 1.2.4 / DWC 2.07:
          The Dev branch of https://github.com/chrishamm/DuetSoftwareFramework contains commits by chrishamm made 7 days ago. They were not packaged into a release on github; however, they do seem to have been used to build the 1.2.5 DSF release that is currently on the package server.
          So he is around somewhere.
          At the same time, may I make a plea for Duet to be more transparent about the roadmap? DC42 is doing an excellent job of communicating "next steps" for the firmware on the boards. However, the D3+Pi roadmap still seems vague.
          • chrishammundefined
            chrishamm administrators
            Hi everyone, I am sorry for being unavailable for so long. Primarily this is because I've been designing a new machine which will be based on the Duet 3. That will allow me to replicate different operation modes and to replicate certain configurations and/or issues that have been very tricky to test.
            As you may suspect I have prepared a new DWC version, which adopts David's new object model from RRF and likewise DSF has been improved, too. I'll release a new DSF version later this week which will also feature conditional G-code. Once these new versions are out, I'll be happy to provide support again.
            Again, sorry for the inconvenience!
            Duet software engineer
            Danalundefined mvieleersundefined 3 Replies Last reply Reply Quote 3
            • Danalundefined
              Danal @chrishamm
              @chrishamm said in No output from G32 on DSF 1.2.4 / DWC 2.07:
              We are just very glad to hear that you are OK, and very glad to have you back!
              • mvieleersundefined
                mvieleers @chrishamm
                No worries! I (and probably most others) understand that this is not your day job. Appreciate everything you're doing.
                Looking forward to try the new release, when it's available.
                • chas2706undefined
                  chas2706
                  @Danal said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                  Where is it then?
                    A Former User @chas2706
                    @chas2706 said in No output from G32 on DSF 1.2.4 / DWC 2.07:
                    Where is it then?
                    you can track the development on github while waiting for the packages to show up in the feed for apt.
                    https://github.com/chrishamm/DuetSoftwareFramework/commits/dev
                      @chrishamm Thanks a lot for the hard work. Installed DSF 1.3.0 and DWC 2.1.0 and RRF3.01-RC6. This issue with no output on the G32 command still persists, unfortunately.
                        chrishamm administrators @mvieleers
                        @mvieleers Thanks for letting me know, I'll have a look.
                        mvieleersundefined 1 Reply Last reply Reply Quote 0
                          @chrishamm Brilliant. Quick question, sorry to polute this topic, but were you able to implement conditional gcode in this version of dsf?
                          • PaulHewundefined
                            PaulHew
                            Just updated to 2.1.0. Think I have found an issue.
                            I cannot load my Height Map.
                            I have check the file is there and there are numbers in it but it tells me height map not available.
                            Have rebooted my Maestro and it still is not displaying.
                            Regards,
                            Paul
                              chrishamm administrators @PaulHew
                              @mvieleers I hope I can get conditional G-code working in DSF next week.
                              @PaulHew Load the heightmap and it should be automatically displayed. I'll add a file list next to the 3D viewer at some point to avoid confusion.
                              mvieleersundefined 2 Replies Last reply Reply Quote 0
                              • PaulHewundefined
                                PaulHew
                                Have pressed the 'Reload height map' button and it will not load.
                                I will rename the current heightmap.csv and run another.
                                Regards,
                                Paul
                                  Cool!
                                    mvieleers @PaulHew
                                    @PaulHew I have the same issue. After I ran a G29, it displays correctly.
                                    • PaulHewundefined
                                      PaulHew
                                      Re-ran Mesh Compensation and still will not display height map.
                                      File is there
                                      • PaulHewundefined
                                        PaulHew
                                        @chrishamm
                                        Update, put DWC2.0.7 back on and height map is displayed.
                                        Regards,
                                        Paul
                                        PaulHewundefined 1 Reply Last reply Reply Quote 0
                                        • PaulHewundefined
                                          PaulHew @PaulHew
                                          @chrishamm
                                          All fixed with 2.1.1 Thank you.
                                            Glad it's working now. The issue with G32 not showing any output should be fixed in DSF 1.3.1, too.
                                            mvieleersundefined 1 Reply Last reply Reply Quote 1
