    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    21.9k
    • gtj0undefined
      gtj0 @Danal
      @Danal said in DuetLapse available for Alpha testing:
      Which USB camera?
      Teslong USB "Endoscope". It only supports MJPEG as a palette and I just noticed that you've got YUYV hard coded on the fswebcam command line. Maybe don't specify '-p' and let it default?
      @gtj0 said in DuetLapse available for Alpha testing:
      Just about to try it but noticed that it seems to be opening and closing the unix socket twice a second. Not usually an issue except I run the DCS with debug logging so it's kinda distracting. Any chance of just keeping the socket open or better yet, just getting the model updates as they happen?
      It doesn't touch the unix socket. It is opening and closing a websocket connection, and not persisting it. This was a design choice in startup to not track state. I will look into persisting that connection.
      Ah yeah, the websocket will result in the same messages. It's not critical so don't spend all that much time on it.
      • Danalundefined
        Danal @gtj0
        I think I did that and it required it for some reason. I will try a couple of different things to get it as automatic as possible.
        • kingfisherundefined
          kingfisher
          Thanks for sharing I. I'll try installing this in whilst in lockdown.
          I had an idea to use a pi remotely to control RGB LEDs based on the printer status. (eg red = heating, white = printing, green = finished)
          I might try and learn how to do this based on your code/logic
          • UnderDoneSushiundefined
            UnderDoneSushi
            Would it be possible to use an old iphone as the camera?
            • tekkydaveundefined
              tekkydave
              I noticed that if you have a password set (M551 P"Password") then DuetLapse can't connect to the Duet.
              Attempting to connect to printer at 192.168.1.104
              http://192.168.1.104  does not appear to be a RRF2 or RRF3 printer
              Device at 192.168.1.104 either did not respond or is not a Duet V2 or V3 printer.
              Do you have any plans to add this feature in the future?
              Cheers
              ~ tekkydave ~
              D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
              FreeCAD, PrusaSlicer
              • gtj0undefined
                gtj0 @Danal
                fswebcam doesn't require it at least for my camera. It figured out MJPEG by itself. Maybe it's an issue if the camera supports more than 1 palette. You could check for the existence of ~/.fswebcam and if it's there, add a -c ~/.fswebcam to the options. This way a user can put whatever options they want in it.
                Once I changed the palette, it worked great!
                • Danalundefined
                  Danal @kingfisher
                  @kingfisher said in DuetLapse available for Alpha testing:
                  The "interface" is in a separate library, for just that reason.
                  • Danalundefined
                    Danal @tekkydave
                    @tekkydave said in DuetLapse available for Alpha testing:
                    Cheers
                    I didn't but based on your feedback, I will look into it.
                    • Danalundefined
                      Danal @UnderDoneSushi
                      @UnderDoneSushi said in DuetLapse available for Alpha testing:
                      Yes, if it runs software that will allow a still image to be retrieved via a know URL.
                      • gtj0undefined
                        gtj0
                        HA! Just discovered another reason to use a config file if it exists... To turn off things like auto-focus. 🙂
                        • Danalundefined
                          Danal @gtj0
                          Excellent point.
                            tekkydave
                            Found a solution to an issue I was having using DuetLapse with MotionEye.
                            I have a raspicam which is connected to a Pi3B running Motioneye.
                            MotionEye will allow a single image to retrieved at a URL similar to:
                            http://192.168.1.106:8765/picture/1/current/?_username=admin&_signature=b75e2c8efb0c0694a7a4ac1f48037f90566fbead
                            Using this URL with DuetLapse gives this error every time it tries to get an image
                            Capturing frame     0 at X65.74 Y47.41 Z0.30
                            http://192.168.1.106:8765/picture/1/current/?_username=admin:
                            2020-04-07 15:10:57 ERROR 403: Forbidden.
                            So I amended the following line in the onePhoto() function in DuetLapse.py
                            cmd = 'wget --auth-no-challenge -nv -O '+fn+' '+weburl
                            to
                            cmd = 'wget --auth-no-challenge -nv -O '+fn+' "'+weburl+'"'
                            to put quotes around the url. This seems to fix the problem 🙂
                            ~ tekkydave ~
                            • Danalundefined
                              Danal
                              THANK YOU
                              I will update
                                tekkydave
                                Another tip if you want to play around with DuetLapse without having to set a print going.
                                Temporarily change
                                        if ('processing' in status):
                                to
                                #if ('processing' in status):
                                if ('M' in status):   # detect simulating instead of processing
                                This will make DuetLapse think the Duet is printing when it is simulating. Remember to change it back later 😉
                                Maybe a -dry-run option can be added to do this in future?
                                ~ tekkydave ~
                                • Danalundefined
                                  Danal
                                  I've just been starting a print, and then pause/canceling it.
                                  Of course, it can do whatever we all agree to... and can code... and dry run is dead simple. I would note that it really only applies to -seconds. A dry run with any kind of -detect is never going to detect anything.
                                  tekkydaveundefined 1 Reply Last reply Reply Quote 0
                                    tekkydave @Danal
                                    It detects layer changes when running a simulation but, as you say, since nothing is physically moving the video is going to be a bit boring. Useful if you are testing options or trying simple code changes though. I know squat about python so I need all the help I can get. I do find your code very easy to follow though 🙂
                                    ~ tekkydave ~
                                    • Danalundefined
                                      Danal @tekkydave
                                      Thank you. I try to balance being "python-esq" with being readable. For me if nought else.
                                      How about having the "detect printing" detect BOTH processing and simulation? Since we control if the script is running, I see very little downside to this.
                                        tekkydave @Danal
                                        That would be the simplest solution I think.
                                        ~ tekkydave ~
                                        • chas2706undefined
                                          chas2706
                                          Keep the ideas coming!
                                          In my customised build of Raspbian with duetpi I created a timelapse.desktop entry so that I can access your program from my start menu.
                                          By default I set it to take a picture upon Z movement.
                                          So now, when I start a print and the printer is ready all I have to do is click on the program entry in the start menu.
                                          Thank you again danal for giving us this great program.
                                            kingfisher
                                            I've set it up and it works 🙂
                                            I did get an error on a small print doing a quick test though
                                            The error was "requests.exceptions.ConnectionError:
                                            ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))"
                                            My guess (Although I'm not a Python expert) is that the pi couldn't keep up saving the images as the layers were only taking 20sec (And its an old V2 pi)
                                            kingfisherundefined 1 Reply Last reply Reply Quote 0
