    PanelDue firware
    Firmware installation
    8
    21
    3.5k
    • Miasmictruthundefined
      Miasmictruth
      From the PanelDue Page
      "you should already have the bossac program and associated device drivers on your PC"
      When I get back home, are there drivers I need because there are no drivers just bossac when you travel the given link.
        You can get the Windows build of bossac from here https://github.com/dc42/RepRapFirmware/tree/dev/Tools/Windows.
        • elmoretundefined
          elmoret
          If you hate the command line, an alternative is BOSSA - that's what I use. But it is probably best to follow dc42's instructions to the letter the first time through.
            Miasmictruth
            Instructions followed, firmware update successful.
            Unfortunately the touch part of the touch screen still doesn't seem to work (I was hoping the firmware would fix it so I didn't mention it before), I took the screen out of the enclosure to make sure it wasn't interfering. I reseated the touch the ribbon coming off the screen to the back of the LCD but still cant seem to press the first dot.
              Miasmictruth
              Scratch that it works, I but a 5 inch piece of ribbon cable between the PanelDue and the screen. I have seen it done before… Anyway after removing the ribbon cable the calibration went fine.
              • PDBealundefined
                PDBeal
                I had issues finding a true 40-pin ribbon cable. All of the ones I ended up ordering were 40-pin, but 1 pin was not installed/used which I believe was the pin that's used for the touchscreen because without the ribbon cable it worked just fine.
                  Miasmictruth
                  @PDBeal:
                  Yeah that is what I figured out too, I thought maybe the pin came loose some how, didn't realize it just didn't exsist at all.
                  Do you know a sounce for an appropriate cable?
                  • Fickertundefined
                    Fickert
                    So my question is I cannot get the Panel Due to connect to my pc and be recognized. I have looked for a bossa driver or something without any luck. I have downloaded the github bossa command prompt stuff too.
                    I guess I am missing a driver but not sure where to get it from? The bossa website contains binaries I cannot open. what do I need to open those?
                    Dustin
                    • elmoretundefined
                      elmoret
                      In the "Testing the board and updating the firmware" section,
                      https://miscsolutions.wordpress.com/paneldue/
                      Which step of the instructions are you stuck on?
                      • Fickertundefined
                        Fickert
                        I am stuck on getting my pc (windows 10) to recognize the panel due in the device manager.
                        It shows up as an unsupported driver with an ! in the device manager.
                          Looks like you need the Bossa port device driver. One way of getting this is to install Arduino.
                          I'll look at adding Bossa port support to the Duet device driver.
                          • pogo1213undefined
                            pogo1213
                            I have erased and reset my panelDue and my computer recognizes it as a bossa programming port I have attempted to run the command line and it stated bossac.exe is not recognized as and internal or external command…
                            I went to http://www.shumatech.com/web/products/bossa and downloaded bossac-1.7.0-mingw32.tar.gz due to running windows 10 but the file wont run
                            I also downloaded the bossac.exe and attempted the command line again with the same "bossac.exe is not recognized"
                            Is there something Im missing?
                            • chojn1undefined
                              chojn1
                              I went through the same process last week.
                              In the CMD prompt, you need to specify where your bossac.exe program is located.
                              Don't just type bossac.exe.
                              You need something like c:/users/user/Downloads/bossac.exe
                              • pogo1213undefined
                                pogo1213
                                Thanks I'll try this
                                @chojn1:
                                • Fickertundefined
                                  Fickert
                                  So new issue has arised after I had let my panel sit on my desk (I get distracted easily) and upon trying to connect my panel due to my pc, it will now not have the standard white background and backlight but just the backlight (Only if I flipped the jumper to 5v). Additionally while connected to my pc, it does not come up in the device manager (or hardware connected chime). So my pc does not register the due at all. I think I may have messed up something here ha.
                                  I will try restarting my pc after this post and see if it is an issue.
