    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    22.5k
    • tekkydaveundefined
      tekkydave
      Another tip if you want to play around with DuetLapse without having to set a print going.
      Temporarily change
              if ('processing' in status):
      to
      #if ('processing' in status):
      if ('M' in status):   # detect simulating instead of processing
      This will make DuetLapse think the Duet is printing when it is simulating. Remember to change it back later 😉
      Maybe a -dry-run option can be added to do this in future?
      ~ tekkydave ~
      D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
      FreeCAD, PrusaSlicer
      • Danalundefined
        Danal
        I've just been starting a print, and then pause/canceling it.
        Of course, it can do whatever we all agree to... and can code... and dry run is dead simple. I would note that it really only applies to -seconds. A dry run with any kind of -detect is never going to detect anything.
        tekkydaveundefined 1 Reply Last reply Reply Quote 0
          tekkydave @Danal
          @Danal said in DuetLapse available for Alpha testing:
          It detects layer changes when running a simulation but, as you say, since nothing is physically moving the video is going to be a bit boring. Useful if you are testing options or trying simple code changes though. I know squat about python so I need all the help I can get. I do find your code very easy to follow though 🙂
          ~ tekkydave ~
          • Danalundefined
            Danal @tekkydave
            @tekkydave said in DuetLapse available for Alpha testing:
            Thank you. I try to balance being "python-esq" with being readable. For me if nought else.
            How about having the "detect printing" detect BOTH processing and simulation? Since we control if the script is running, I see very little downside to this.
              tekkydave @Danal
              That would be the simplest solution I think.
              ~ tekkydave ~
              • chas2706undefined
                chas2706
                Keep the ideas coming!
                In my customised build of Raspbian with duetpi I created a timelapse.desktop entry so that I can access your program from my start menu.
                By default I set it to take a picture upon Z movement.
                So now, when I start a print and the printer is ready all I have to do is click on the program entry in the start menu.
                Thank you again danal for giving us this great program.
                • kingfisherundefined
                  kingfisher
                  I've set it up and it works 🙂
                  I did get an error on a small print doing a quick test though
                  The error was "requests.exceptions.ConnectionError:
                  ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))"
                  My guess (Although I'm not a Python expert) is that the pi couldn't keep up saving the images as the layers were only taking 20sec (And its an old V2 pi)
                  kingfisherundefined 1 Reply Last reply Reply Quote 0
                    kingfisher @kingfisher
                    @kingfisher
                    I actually think it might be my Duet wifi board causing an error. I've also got a duet maestro and running the same python settings on the maestro IP address hasn't resulted in the "('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))" error
                    • Danalundefined
                      Danal
                      Updates based on feedback:
                      • Added -dontwait flag. This causes the script to not wait for a print to start; it captures images immediately. Of course, it will only capture things that happen... Example: If told only to capture on layer changes, well, that won't happen prior to a print...
                      • Added 'camparms -parms' subsection to command line flags. Anything in that subsection is passed to the camera command (whichever for the appropriate camera type, fswebcam, raspistill, or wget)
                      • Removed pallet from fswebcam (USB attached cameras, despite its name). It will automatically attempt to find the best, or you can specify one, example:
                        ./DuetLapse.py -duet 192.168.7.101 -dontwait -seconds 3 camparms -parms -p YUYV
                      • Removed -q from fswebcam. Default is 35. You can override, same as above.
                      • Slightly changed the loop timer, to beat on the printer a little less often.
                      *** IMPORTANT *** Found a bug in DuetWebAPI and fixed it, you must download this as well. Therefore, pull these two things into the same directory. One way to do this would be:
                      wget https://raw.githubusercontent.com/DanalEstes/DuetLapse/master/DuetLapse.py
                      chmod 744 DuetLapse.py
                      wget https://raw.githubusercontent.com/DanalEstes/DuetWebAPI/master/DuetWebAPI.py
                      • Danalundefined
                        Danal
                        Also, added quotes around the wget URL.
                        • Danalundefined
                          Danal
                          Still thinking about overlay of Z, print time, etc.
                            tekkydave @Danal
                            ~ tekkydave ~
                              tekkydave
                              @Danal what ide / dev tools do you use for python development. I'm using Eclipse for c/c++ and Netbeans for Java. Is there a tool for python that will allow local (Ubuntu) testing and remote deployment to the pi?
                              ~ tekkydave ~
                              • Danalundefined
                                Danal
                                For Python, I edit with Sublime on a PC. It could be any editor or IDE that you like that has syntax highlighting or whatever. I interface to the Pi by doing this on the Pi:
                                # If you want to be able to edit files on the Pi from windows, via a netshare (not a mapped drive):
                                sudo apt-get install samba
                                sudo smbpasswd -a pi
                                sudo nano /etc/samba/smb.conf   # and change 'read only = yes' to no.
                                # Then use a UNC like '\\192.168.7.101\pi' in a file open in your favorite editor.
                                # Quite often, you may have to start with just the "\\192.168.7.101" and no subdirectory to get
                                # it to prompt you for userid and password.  Use 'pi' and the password you set above.
                                # You may have to try and retry several times to get connected.  It's worth it.
                                # BE SURE that your editor HONORS UNIX LINE ENDS and that you turn them on in any new files.
                                # For windows users, I suggest notepad++ or atom or Sublime Text (that last one costs money. Worth every penny)
                                The big key is the UNC on Windows. \192.168.7.101\pi This is NOT a drive share... and doesn't behave like SMB shares behave. In sublime, if I do an "open folder" on that UNC, I can then click into \192.168.7.101\pi\DuetLapse (or whatever) and see all the files.
                                Note: This WILL cause your editor to hang if it has files/folders open and the Pi goes away. In sublime, I set it to NOT re-open whatever it had at close...
                                Testing? For python there is no "make" or "build" phase, so I just test directly on the Pi. Either VNC if I need graphics, or Winterm and ssh if not.
                                You can, in theory, test on your desktop distro, by building enough "context" around the thing you are testing. Directories, etc. However, many of the things that I'm testing (not necessarily the stuff you are seeing for Duet) is so tightly related to interfaces or other structures in Raspbian and/or the actual Pi hardware, it is just easier to test there.
                                For cross compile, like binaries for ESP32, or the Atmel chips, or similar, I still edit in Sublime, with the PlatformIO plugin. This makes it a cross-platform IDE. I've come to really like PlatformIO (as vs. the more 'Arduino' like environments). It runs a mini-RTOS and is very well documented and very flexible.
                                If I'm working with stuff developed by others for Atmel, then it is Atmel studio all the way.
                                That covers pretty much everything that fits a pattern. There are, of course, one-off environments for exceptional cases.
                                  tekkydave @Danal
                                  @Danal thanks - very interesting.
                                  ~ tekkydave ~
                                  • Danalundefined
                                    Danal @tekkydave
                                    Just noticed the text handling, OUTSIDE the code block, make double backslashes into single. Use the double, as shown in the code block
                                    • gtj0undefined
                                      gtj0
                                      Just FYI if you need streaming as well as time lapse. I set up ustreamer as the "owner" of the camera and pointed DuetLapse at its "/snapshot" URL. That way I have both a live stream and the time lapse at the same time.
                                      • arhiundefined
                                        arhi
                                        "camparams" error
                                        dunno if this helps
                                        [root@localdev LAPSE]# ./DuetLapse.py -duet http://ender5.local.lan
                                        Traceback (most recent call last):
                                          File "./DuetLapse.py", line 257, in <module>
                                            init()
                                          File "./DuetLapse.py", line 74, in init
                                            camparms = args['camparms']
                                        KeyError: 'camparms'
                                        [root@localdev LAPSE]# ./DuetLapse.py -duet ender5.local.lan
                                            init()
                                        [root@localdev LAPSE]# host ender5.local.lan
                                        ender5.local.lan has address 192.168.89.246
                                        [root@localdev LAPSE]# ./DuetLapse.py -duet 192.168.89.246
                                            init()
                                        [root@localdev LAPSE]# python --version
                                        Python 3.7.6
                                        [root@localdev LAPSE]# fswebcam -d /dev/video0 -F 1 kkk
                                        --- Opening /dev/video0...
                                        Trying source module v4l2...
                                        /dev/video0 opened.
                                        No input was specified, using the first.
                                        Adjusting resolution from 384x288 to 352x288.
                                        --- Capturing frame...
                                        Captured frame in 0.00 seconds.
                                        --- Processing captured image...
                                        Unable to load font 'sans': Problem doing text layout
                                        Disabling the the banner.
                                        Writing JPEG image to 'kkk'.
                                        and here you can see how non python developer try to follow up before giving up 😞
                                        [root@localdev LAPSE]# ./DuetLapse.py camparms -h
                                        usage: DuetLapse.py camparms [-h] [-- ...]
                                        camparm -parms xxx where xxx is passed to fswebcam, raspistill, or wget.
                                        optional arguments:
                                          -h, --help          show this help message and exit
                                          -- ..., -parms ...  Extra parms to pass to fswebcam, raspistill, or wget.
                                        [root@localdev LAPSE]# ./DuetLapse.py -duet 192.168.89.246 -camera usb -parms -d /dev/video0
                                        usage: DuetLapse.py [-h] -duet DUET [-camera {usb,pi,web,dslr}]
                                                            [-seconds SECONDS] [-detect {layer,pause,none}]
                                                            [-pause {yes,no}] [-movehead MOVEHEAD MOVEHEAD]
                                                            [-weburl WEBURL] [-dontwait]
                                                            {camparms} ...
                                        DuetLapse.py: error: invalid choice: '/dev/video0' (choose from 'camparms')
                                        [root@localdev LAPSE]# ./DuetLapse.py -duet 192.168.89.246 -camera usb -parms "-d /dev/video0"
                                                            {camparms} ...
                                        DuetLapse.py: error: invalid choice: '-d /dev/video0' (choose from 'camparms')
                                        [root@localdev LAPSE]# ./DuetLapse.py -duet 192.168.89.246 -camera usb "-d /dev/video0"
                                                            {camparms} ...
                                        • Danalundefined
                                          Danal
                                          Well, drat, I obviously have gaps in my test cases.
                                          Will be fixed and upload in 20 min or so.
                                          • Danalundefined
                                            Danal
                                            OK, now fixed.
                                            While I was there, I added the ability to press Ctrl+C one time, while waiting for pre-start or print running, and it will move directly to making a video. In other words, if you wish to end it before the print ends, and still want the vid, press Ctrl-C once.
