Simple question: How to read from IO
1.7k
    JBisc
    Sorry for the stupid question (neither google nor the forum search helped me):
    I could not find a Gcode command to read one of my IO? How is it possible? I would assume that there is a gcode command witch returns a json...
    For Marlin I found M43, but for duet it seem to be different....
    My Setup: Duet 3 MB6HC Main Board with attached RPI
      JBisc
      Ok it seems to be easy:
      just call
      M308 S4
      to get the sensor value.
        Use any or all of:
        • M577 to wait for an input pin to be in a particular state
        • M581 (and possibly M582) to cause some action to take place when the state of an input pin changes
        • In RRF 3.01, M409 or conditional GCode to query the value of sensors.inputs[n] for some n
        undefined 1 Reply Last reply 16 Apr 2020, 19:03 Reply Quote 1
          JBisc @dc42
          @dc42 Thanks: I will try
          M409 K"sensors.inputs"
          Maybe some feedback: Does it make sense to include a small example in the gcode documentation, that I will be the last person who is asking? 🙂 Normally the people search for "read io"/ "read voltage" / "get sensor value" and its hard for them/me to find something in the documentation.
          undefined 1 Reply Last reply 16 Apr 2020, 19:15 Reply Quote 0
            dc42 administrators @JBisc
            @JBisc, you will need to create a GPIO port attached to your chosen pin using M950 with the J option, before you can see it in sensors.inputs.
            Yes an example would help. If you tell us what you are trying to achieve, we could use that as an example.
            undefined 2 Replies Last reply 16 Apr 2020, 19:29 Reply Quote 0
              JBisc @dc42
              @dc42 I believe that my scenario is not a very common one. I am working on a complex algorithm to measure the 2D/3D-geometry of my workpiece. The algorithm is to complex to implement it in gcode, therefor I implement a supersiving software layer in python (think about a python-gcode wrapper) which calculates the algorithm. Then, the supervising software optimize the 3dprinter.
                Danal
                Curious side question: Where are you running the Python?
                undefined 1 Reply Last reply 16 Apr 2020, 20:46 Reply Quote 1
                  jens55
                  Visions of automated probing are running through my head .... could be as simple as setting resolution for x and y, setting a range of x and y and telling the printer to measure every point. Might be painfully slow but hey, it could do it. Put every value into a spreadsheet which can then be imported into Fusion360 and presto, the beginnings of a model. Obviously some hand work is required.
                  As a side question, just exactly how accurate is a 3D scanned object? Are the scanned objects dimensionally accurate or could manually probing increase accuracy?
                  In any case, having a probing tool head for quality control of a printed object might be interesting.
                    JBisc @Danal
                    @Danal currently on the RPI. Ohhhh Danal, you are the author of the wrapper which I use. Great to meet you here! Thanks for your amazing work. I started with forking your project (https://github.com/DanalEstes/PythonDSF)
                    undefined 1 Reply Last reply 16 Apr 2020, 21:47 Reply Quote 0
                      Danal @JBisc
                      @JBisc said in Simple question: How to read from IO:
                      There's another choice now as well: DuetWebAPI. Requires network connectivity to the printer (can, but not required to, run on the attached Pi) and also abstracts away V2 to V3 differences.
                        JBisc @dc42
                        @dc42 said in Simple question: How to read from IO:
                        If I use M950 by
                        M950 J4 C"io4.in"
                        I can get only a ditgital input by calling
                        which is not what i want.
                        If I define my sensor by
                        M308 S4 P"io4.in" Y"linear-analog" A"MySensor" F0
                        I don't know a method to return my analog sensor value (to the RPI). Does somebody has an idea?
                        undefined 1 Reply Last reply 19 Apr 2020, 16:25 Reply Quote 0
                          JBisc
                          just call
                          M308 S4
                            Danal @JBisc
                            When you say "return to the Pi", what would happen? Push? Pull? what code reads it or responds or...
                            What do you want to happen?
                              JBisc
                              I implemented in the following way now:
                              My python programm on the RPI sends
                              M308 S4
                              and i parse the response (on the RPI)
                              Sensor 4 (MySensor) type Linear analog using pin io4.in, reading 3.8, last error: success, unfiltered, range 0.0 to 1.0
                                You could also get it by using M409 to request that value from the object model.
                                undefined 1 Reply Last reply 19 Apr 2020, 17:18 Reply Quote 0
                                  JBisc @dc42
                                  M409
                                  I remember that you posted in another post that analog values are not included in the current object model
                                  undefined 1 Reply Last reply 20 Apr 2020, 08:51 Reply Quote 0
                                    M409
                                    Raw analog inputs are not included, but the readings from configured sensors are:
                                    20/04/2020, 09:55:19 m409 k"sensors.analog[0].lastReading"
                                    {"key":"sensors.analog[0].lastReading","flags":"","result":21.5}
                                    • undefined pouic1313 referenced this topic 8 Nov 2022, 15:49
                                    1 out of 16
