    Duet won't boot problem
    673
      A Former User @mkrsjak
      @mkrsjak said in Duet won't boot problem:
      I took a microscope and the u3 is indeed damaged.
      could be worth noting it may be covered by the manufacturers warranty if the board is less than 6 months; unless its caused by a short in wiring or other external factors.
      mkrsjakundefined 1 Reply Last reply Reply Quote 0
      • mkrsjakundefined
        mkrsjak @A Former User
        @bearer The board is more than 1 year old. I thought we have EU warranty 2 years,but apparently not.
          that could be something to ask your vendor about; I would have consumer protection rights if purchased locally even if the manufacturer says 6 months but I can't speak to your local rules; and it would be a matter for the vendor, not the manufacturer.
          • mkrsjakundefined
            @bearer said in Duet won't boot problem:
            A4403GEUTR
            I found this one, seems to be within fast shipping reach.
            https://www.tme.eu/at/en/details/a4403geutr-t/voltage-regulators-dc-dc-circuits/allegro-microsystems/
              A Former User
              Looks like the correct one. (but you will need a hot air station, a preheater/hotplate and some good flux as well)
              mkrsjakundefined 2 Replies Last reply Reply Quote 0
              • mkrsjakundefined
                Have hotair, no preheat and really doing this the first time.
                • mkrsjakundefined
                  @bearer are the other 2 numbers important? 4403T XXXX YYYL ? cause there are many versions with different X and Y
                    T3P3Tony administrators
                    4403T XXXX YYYL
                    The A4403 datasheet is here:https://www.allegromicro.com/~/media/Files/Datasheets/A4403-Datasheet.ashx
                    The part numbering specifically
                    • mkrsjakundefined
                      mkrsjak
                      ok, will buy and hopefully fix it, will post the result. thank you all for the outstanding help!
                        just be carefull with the surrounding parts, shield with kapton or alu tape (don't take the paper backing off the alu tape, it makes a mess (when very hot))
                          to add on Tonys reply; usually the last few numbers/letters refer to packageing, both in terms of which package it is (qnf, qft, bga sop etc) and how its packaged, tape, tray, tube etc; and the details are usually in the datasheets. (I posted the variant that is commonly available as "cut tape" in low quantity)
                          • mkrsjakundefined
                            mkrsjak
                            QNF
                            I was something else wrong with the board. The U3 gets fried again, even with no connections except the power IN.
                            I will buy a replacement, but really not see a point buy from duet with only 6months of warranty. This should be fixed in general.
                            Even shoes and heavily wearing products have 2 years. Shame.
                              Sorry to hear you've had an unfortunate hardware failure and were unable to resolve it. The warranty provided can be reviewed here: https://www.duet3d.com/warranty
                              Unfortunately you're out of the warranty period it would seem. However, we may be able to provide you with a refurbished board at a reduced price on exchange. Please contact roland@duet3d.com to inquire about current availability.
