Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3
This is the deploy Macro
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 18 2020 19:50:27 GMT-0400 (Eastern Daylight Time)
M280 P0 S10 ; deploy BLTouch -
This is the retractprobe macro
; retractprobe.g
; called to retract a physical Z probe
M280 P0 S90 ; retract BLTouch -
@Phaedrux
This is the home all macro; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-225 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X60 Y12 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
In my brain, Standing in front of the printer, the 0 x and 0 y is where the end of the run switches are. Meaning, back right corner. When those switches are closed, the lights in the motherboard turn red.
When the printer turns on, the Bl touch goes up and down 2 times and then the light remains red and the prob is retracted. -
M401 and M402 work fine deploying and retracting the probe.
@Daniel said in Ender 5 Pro Hemera Bltouch upgrade to Duet Wifi Firmware 3:
Ok, this is fine. We'll roll with that mental model. Technically this is a 180 degree rotation of the "normal" way of doing it, but it's all relative.
Your config is currently setup to work this way, but the one thing we need to verify is the direction of the motors so that when you send a negative movement command they move to the right and rear towards the endstops.
So can you do a test for me?
With the printer powered off, manually move the print head to the center in X and Y.
When the printer is freshly powered on, go to the gcode console.
Send these commands:
G92 X100 Y100
G91
G1 X-10
G1 Y-10Does the print head move towards the endstops in both cases?
That's good. Did you also remove the +zprobe.mod from the M558 command in config.g?
@Phaedrux
This is the last config file matching all the other files you see above.
I promise not to touch anything else until you return to me.; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 18 2020 19:50:27 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Daniel Ender 5" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z800.00 E409.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z50.00 E5000.00 ; set accelerations (mm/s^2)
M208 X220 Y220 Z300 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-45 Y3 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:160 Y15:200 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
Also we should test that your z axis steps per mm is correct at 800. In addition to the test above in the console, send the following making sure that your bed is safely away from your nozzle.
G92 Z0
G91
G1 Z10This should move the bed 10mm down away from the nozzle. If it does anything else, kill the power.
Measure how far it actually moves.
@Phaedrux
From me standing in front of the printerG1 X-10 moved right
G1 Y-10 moved back -
Ok, now what happens if you test the endstops as described here: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39#s145
The G1 Z10 moved the bed exactly 10.27mm downwards
Before I moved anything, with the head in the center of the bed (approx) the endstops look like this
What it is basically wrong. They are opened.
@Phaedrux
When I close the circuit by pushing the trigger, both Circuits change to "No"This is really confusing, Triggered means closed or open?
@Phaedrux
What would be the right switch to choose between all this?
xstop,
Xstop inverted
xstop pull up
xstop inverted pull upor should I changed in the next page?
You also said my logic was inverted 180 degrees. How should I look at all this (I am left handed and brain washed)
I believe we should choose in this last screen, Active low, High end to reverse the screen and finally change the direction of the motors by selecting reverse direction in X and Y.
What say you? I am going to give it a try....
Then - X would be with the motor moving to the left and -Y would be with the motor moving towards the front....and it will match the deviation of the bltouch probe in -x (45 and 3) +y -
Sorry for the delay.
For the endstops we can change them in config.g
M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
Change the S1 to S2 for both. Then test the endstops again.
Doing high end for both would give you the 180 degree rotation we discussed earlier.
This is normally how the coordinate system would appear when looking at your printer from the front. The homing location is irrelevant. Instead of homing to 0 it would home to 280 or whatever.
@Phaedrux
Ok, I tried changing the configuration without success on the RRF to try to get those S2 values to show. I finally changed it on the config and we are like this; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 18 2020 22:46:43 GMT-0400 (Eastern Daylight Time); General preferences
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z779.00 E409.00 ; set steps per mm
M203 X18000.00 Y18000.00 Z900.00 E1200.00 ; set maximum speeds (mm/min)
M574 X2 S2 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S2 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M143 H1 S300 ; set temperature limit for heater 1 to 300C
M563 P0 S"E3D V6 Nozzle X" D0 H1 F0 ; define tool 0
