Bug or security feature?
364
    drmaestro
    I'd like to ask a question about an observation I made during certain prints. I use BLTouch as Z endstop. If a very short object was printed and then the printer was turned off and then later turned on, the BLTouch's pin may not be completely deployed due to the actual Z hegiht being shorter than its deployement height. In that situation, a home all command doesn't work properly. It can home X and Y axis, but when it is time for homing Z axis, the Z axis raises a few milimeters, instead of going towards the bed, and also the BLTouch flashes and homeing stops. Resetting BLTouch doesn't change the behaviour. If you then shut down the unit and restart it, the problem doesn't happen anymore, because now BLTouch's pin can be deployed. Is this behavior intentional?
    Thanks
      It's a good idea to add something like the following to the end of config.g and/or the start of homeall/homez
      ; BLTOUCH PREP
      G4 S1
      M280 P3 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
      G4 S1
      M402 ; Retract probe just in case it's down
      This makes sure the BLTouch is ready to go and with the addition of raising the Z axis slightly to give the pin enough clearance you should be able to home successfully without the additional power cycle.
        Danal
        Homing is an interesting thing. It should work, always, on every axis, no matter where the machine is when it powers up.
        Writing a sequence of moves that makes that happen, without ever jamming the machine, is often not quite possible. So homing sequences are written to cover the majority of cases, and to be "good enough" for the edge cases.
        Example: On any axis, with any switch or probe, it is possible that the axis will be pressed against the switch before homing starts. Therefore, the first move (probably) should be a very short move, a few mm, in the 'away' direction. Then make the first actual homing move, and so forth. But... what if... that axis is hard up against the OPPOSITE end? That very first small move will physically jam. Maybe that's OK if it is a small/short enough move.
        And on and on... we could type paragraph after paragraph of scenarios.
        So, now, let's bring the BLtouch into the picture. RETRACTING probe. Needs a certain 'clearance' to deploy. Going back to our 'first move should be away' above, an axis with a BLt should probably move AWAY from the BLt about 3 mm BEFORE it even tries to deploy. And that will work 99.9% of the time. It is literally what I would do to resolve your original question.
        But...
        That does leave the possibility that the bed is at the very max part of Z at power up, and that first 'away' move will jam it. Again, I'd still set it up that way, and just know the limitation.
        undefined 1 Reply Last reply 19 Apr 2020, 16:45 Reply Quote 0
          Phaedrux Moderator @Danal
          @Danal said in Bug or security feature?:
          move AWAY from the BLt about 5 to 8 mm BEFORE it even tries to deploy
          That's excessive. It only needs to be equal or slightly more than the trigger height. Same goes for the dive height really. I use 3mm for instance.
          To solve the zmax issue I have my max print height set 3mm shorter than the physical travel actually allows.
          undefined 1 Reply Last reply 19 Apr 2020, 16:46 Reply Quote 0
            Danal @Phaedrux
            @Phaedrux said in Bug or security feature?:
            3mm. Edited... 🙂 Concept still holds.
            However that is set, the switch or BLt has to trigger... so it is still possible that the machine is sitting right at that 'triggered already' at power up. First move should still be 'away'.
            undefined 1 Reply Last reply 19 Apr 2020, 16:52 Reply Quote 0
              IF the BLtouch is triggered when my the bed is at Zmax I have bigger issues.
              Sorry, misread. Coffee still not fully in effect.
                Danal
                No Prob. I'm in the "add coffee get human" set myself.
                  drmaestro
                  The problem with BLTouch is that when the power is turned on, it performs a test/initialization movement by deploying and retracting the probe 2 times. If the Z height at this moment is lower than the deployment height, then you go into the error state I've mentioned and it can't be corrected by resetting BLTouch and also you can't solve it by any gcode because no g code is being used at that moment. In fact, if the behavior I have described in my original post (going up instead of down and not deploying) is the only way the problem is corrected afterwards, as if the Z height didn't increase, the problem would repeat itself, until the Z height is changed by manual intervention. That's why I sometimes miss the older firmwares where you were allowed to move the axes before homing them.
                  undefined undefined undefined undefined 4 Replies Last reply 21 Apr 2020, 10:06 Reply Quote 0
                    jumpedwithbothfeet @drmaestro
                    @drmaestro I’ve had this exact issue myself, I thought maybe adding to the end gcode in the slicer a z move to lower the bed post print might help, I’ve yet to implement it yet mind and it’ll still only be a work around!
                    6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                      deckingman @drmaestro
                      @drmaestro said in Bug or security feature?:
                      .........................That's why I sometimes miss the older firmwares where you were allowed to move the axes before homing them.
                      You can restore that behaviour by adding M564 H0 to your config.g file https://duet3d.dozuki.com/Wiki/Gcode#Section_M564_Limit_axes
                        A Former User
                        can't recall not being able to reset mine, but suppose if you have a spare fan output you could wire the bltouch to that and hard reset it with M42
                          arhi @drmaestro
                          Not sure this is also true for v3.
                          I had the issue of BLTouch going into "error state" during testing mostly cause it was "horizontal" and not "vertical" or sometimes even upside down and it would fail to init during power-on test.
                          M280 P0 S160
                          M280 P0 S120
                          M280 P0 S160
                          would get it running ok. I switched to PP so can't test now, but according to my notes this was the solution for that.
                            Phaedrux Moderator @drmaestro
                            The gcode I posted is exactly for this situation. Placed at the end of config.g for power on, and at the start of homeall/homez it's able to clear any error state. And if your homing file has a G1 H2 Z command to raise the Z by at least the trigger height of the BLTouch you're good to go.
                            2 out of 13
