    slicer setting g-code type
    1.8k
    • Zerobloodundefined
      Zeroblood
      a little pee noises that were not there before which happens every second from the extruder motor and think it is not good sound but I do not know
        Zeroblood
        link to youtude video https://www.youtube.com/watch?v=roXHd-qJF8c
          that is an interesting sound, but without any other info to go on I'm not sure what to say.
          Add some details for us please: https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
            Zeroblood
            20200418_230439.jpg blot.gcode
              Zeroblood
              3d printer ender 3 pro
              and this is the whole file for confik.g
              ; generated by RepRapFirmware Configuration Tool v2 on Mon Jan 07 2019 23:53:31 GMT+0200 (Eastern European Standard Time)
              M550 PEnder3 ; Set machine name
              M552 S1 ; Enable network
              ;M587 S"FiberSwag_IoT" P"SonosErGud123" I10.0.1.9 J10.0.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M569 P0 S0 ; Drive 0 goes backwards
              M569 P1 S0 ; Drive 1 goes backwards
              M569 P3 S0 ; Drive 3 goes backwards
              M92 X80.00 Y79.892 Z400.00 E94.50 ; Set steps per mm
              M566 X900.00 Y900.00 Z12.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
              M203 X18000.00 Y18000.00 Z300.00 E18000.00 ; Set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
              M906 X600.00 Y600.00 Z600.00 E800.00 I50 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S60 ; Set idle timeout
              M208 X235 Y235 Z250 S0 ; Set axis maxima
              ; M574 X1 Y1 S1 ; Set active high endstops
              M574 X1 Y1 S1 ; X home to min. Y home to max. Normally Closed limit switches.
              M574 Z1 S2 ; Set endstops controlled by probe
              M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
              M558 P9 H5 F120 T6000 X0 Y0 Z1 ; Set Z probe type to bltouch and the dive height + speeds
              G31 P25 X48 Y-2 Z1.19 ; Set Z probe trigger value, offset and trigger height
              M557 X50:230 Y50:230 S10 ; Define mesh grid
              M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
              M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
              M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
              M106 P0 S255 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 S255 I0 F500 H1 T45 ; Set fan 1 to turn on full speed when Hotend reaches 45
              M106 P2 T45:65 H100:101:102 ; Set fan 2 to turn on when MCU reaches 45 and reach full speed when MCU reaches 65 or any TMC2660 report over-temperature
              M563 P0 D0 H1 ; Define tool 0
              T0 ; Select first tool
                Zeroblood
                slicer fil CE3_X_1_layer_test_bed_leveling.gcode
                  Your first gcode posted (blot.gcode) was using marlin flavour and included some speed commands in the start gcode. The second one you posted is in Reprap flavor, which is correct, and those commands are no longer present.
                  Other than the noise, what is actually happening?
                  When does the noise occur? During a print? Just sitting there?
                  Your config file looks ok.
                    Zeroblood
                    @Phaedrux it's just the sound.
                    As far as I know
                      Does it extrude properly?
                      Zerobloodundefined 1 Reply Last reply Reply Quote 0
                        Zeroblood @Phaedrux
                        @Phaedrux
                        the extrusion properly I think. trying to get 3d printer running properly and try me to get it printed in good quality, but you can see that the z axis is doing poor quality I just found out. so I can't say if it extrudes properly. but try to fix it
                        but thanks for the help
