    Is Duet still open source?
    2.2k
    • arhiundefined
      arhi @A Former User
      @bearer well, converting brd to gerber is 2 clicks, IMHO pdf schematic when PCB silkscreen is properly made is enough for repair too. The Kicad generated pdf's are not as fancy as for e.g. something you can get out of Altium where you can have index of part and click on a part will quickly find it on the schematic ๐Ÿ™‚ but since duet3 is not that big nor complicated this "simple" pdf works ok. And IMHO great that KiCad is used since I no longer have access to Altium ๐Ÿ˜„
        A Former User @arhi
        @arhi said in Is Duet still open source?:
        i was under the impression you could strip most the layout from this and still have it work with https://openboardview.org/
        leaving you with net names, part and pin locations and thats it more or less?
        • arhiundefined
          arhi @A Former User
          @bearer said in Is Duet still open source?:
          I used a lot of PRC services for "reverse engineering" stuff for machines that are old and unsupported but require fix/retrofit, everything from 24 layer PCB to mcu's and fpga's. They will make gerbers out of image of the PCB. They use a cnc grinder to grind away layer by layer, take few images, photoshop macro and convert that into gerber. Takes 2 days for A4 size 8layer PCB (last one I did) if you just want gerbers that will "print". If you want to do the board files, schematic (with netlists parts and other things) that can take few weeks depending on the complexity of the board, they do full reverse engineering then, but for just duplication, 2 days and $300 for 8 layer 210x280mm.
          So if you are showing the layout gerbers are 2 clicks away :D. IMHO if you are open source, you open-source and give it all out. No real point in preventing many regular users from using/learning from it to prevent a few hours of PRC reverse engineering hack. "Mushing" stuff and creating BRD file is IMHO wrong. In that case release PDF of the board, why bother releasing brd file at all ?
          But of course, as I said, I'm happy with schematic only as long as there's clear silkscreen on the PCB and it matches the schematic ๐Ÿ˜„
            A Former User @arhi
            but you're not, or at least that was my understanding.
            anyways, i do agree releasing the design files is much preferred, but as i said, while we wait, .brd file would be convenient - you don't have to agree with that, but saying it makes cloning easier when it still requires a physical sample that could be duplicated without the files in the first place makes no sense to me.
            • zaptaundefined
              zapta @arhi
              .. totally understandable, for 99% of cases pdf schematic is enough
              " source hardware is hardware whose design is made publicly available so that anyone can study, modify, distribute, make, and sell the design or hardware based on that design. The hardwareโ€™s source, the design from which it is made, is available in the preferred format for making modifications to it. "
              https://www.oshwa.org/definition/
              The goal of open source is to make it easy to clone, with or without modifications. I doubt is a PDF, without BOM and CAD files qualifies as OSH.
              In the world of OSH, cloning is a feature, not a bug.
              [This post is about terminology, not on how and when Duet should or should not release their IP]
              MarkHundefined 1 Reply Last reply Reply Quote 1
              • arhiundefined
                arhi
                @zapta yes, I agree, I was talking about repairability part, not about OSH part
                @bearer I don't think there is a way to provide BRD that will make creating printable gerbers impossible unless you remove all the internal layers (but that makes the BRD pretty useless for repair work).
                • zaptaundefined
                  zapta @arhi
                  Yes, you are right, repairability and OSH have different goals and requirements. Reparability doesn't even require an open source license, but does require a schematic and parts list.
                  It was common for commercial electronic manufacturer to provide schematics and parts list. These days it's often discouraged, hence The Right To Repair movement.
                  BTW, this is my favorite repair document. The entire schematic is artfully condensed into a single page ๐Ÿ˜‰
                  http://colinoflynn.com/wp-content/uploads/2012/05/MX-500P-11.pdf
                  • arhiundefined
                    arhi @zapta
                    @zapta I have ton of old tektronix equipment (7106 is what I love the most) ๐Ÿ˜„ that's documentation ppl should learn how to make these days, but back then the idea was to make repairable equipment, today I'd say the idea is completely opposite today ๐Ÿ˜ž so helping OSH projects like duet, smoothie... is really important
                    • zaptaundefined
                      zapta @arhi
                      @arhi, yes, I also appreciate the old repair manuals though I doubt if I would spend the time to read them in this era of TL;DR. ๐Ÿ˜‰
                      Duet uses a different model for reparability. Instead of spending time and money preparing in advance detailed repair documents, they use an 'on demand' approach where users can ask repair question whenever they arise.
                      I think this is a better model for small and fast moving company such as duet.
                      My 2c.
                      • arhiundefined
                        arhi @zapta
                        @zapta I find way duet doing thing great so far, no complaints ๐Ÿ™‚ would not change a thing
                        • MarkHundefined
                          MarkH @zapta
                          @zapta I agree on the OSHW side of things, mainly because Duet3D's website makes a big deal about being open source hardware, software, and an open community.
                          You can't have it both ways, either your hardware is opensource, and design files are released, or it's closed source, and they are not - but perhaps a schematic is provided for assisting with software dev.
                          For my project, I only need the schematic so my needs are covered, but I don't see that as falling under open source hardware.
                          Withholding the hardware design for whatever reason isn't in good faith for open source goals and claims. If the source is withheld, then the open source claim is just marketing fluff for people who think open source is good and want to support open source projects, even if they have no intention of using the source.
                          If you want sole distributorship/manufacturing rights (for whatever reason) and to not have anyone else sell your design or remixes thereof, don't release it as open source, or instead use a restrictive open license. Alternatively, make older versions open source, with the newest version proprietary commercial, but don't claim to be open source if you don't release the source files (which is the very definition of closed source.)
                          This is why I originally questioned whether the project was still open source.
                          • Danalundefined
                            Danal
                            FWIW, I believe Duet should either remove the entire "OPEN" green bar from their website, or, my preference, they should get a lot better about actually releasing things. And perhaps link from that green bar to the repository.
                            Right now, they clearly don't deserve to be representing that they are open.
                            -or-
                            Clearly state something like "hardware files will be released after first hardware shipments to customers" (and then, of course, do that).
                            mwwhitedundefined 1 Reply Last reply Reply Quote 0
                            • mwwhitedundefined
                              mwwhited @Danal
                              @Danal said in Is Duet still open source?:
                              -or-
                              Itโ€™s amazing how many people are so demanding of projects (open and closed).
                              To the entire team of hardware and software devs building these products..Thanks, you are amazing and your work is awesome.
                              To those that are complaining, chill out. This stuff isnโ€™t easy or free to design, build and test. If it is rushed you will just get buggy garbage that catches fire spontaneously.
                              A Former User? Danalundefined 2 Replies Last reply Reply Quote 3
                                A Former User @mwwhited
                                @mwwhited said in Is Duet still open source?:
                                and clones with the same issues with no incentive to fix it; duet have said they'll release it, just not when. idk if the license has any requirements to that regard
                                zaptaundefined 1 Reply Last reply Reply Quote 1
                                • zaptaundefined
                                  zapta @A Former User
                                  ... idk if the license has any requirements to that regard
                                  I think that the concerns are about truthful representation to potential buyers. For example, the Duet's website currently states:
                                  All the hardware designs are licensed under the CERN OHL 1.2. The design files are released on GitHub.
                                  Not all buyers are long time members here and understand the nuances, timeline, and the dilemmas of the Duet team.
                                    A Former User @zapta
                                    @zapta said in Is Duet still open source?:
                                    I would think the simple explanation is the good old "it was true at the time"; and while I feel less strongly about it it would warrant adding an caveat to that statement or simply releasing the files.
                                    Simply changing "are released" to "will be released" should satisfy the current and future debacles?
                                    • Danalundefined
                                      Danal @mwwhited
                                      -or-
                                      Since you directly quoted me all I am really asking is:
                                      "Do what you say; say what you do"
                                      If THAT has somehow become to harsh to say out loud, or is "Demanding", or even worse if the principle itself is debatable... well, I don't even know how to finish that thought.
                                      Search my posts. 99.9% or more are supportive of Duet, and I regularly recommend them to friends and on other forums. At the same time, "Do what you say, say what you do" with regard to being open is a statement that needs to be heard.
                                      • botundefined
                                        bot
                                        Can be interpreted in several ways. One way is of a generalized procedure.
                                        The design files are (routinely) released on GitHub (at the time they are ready to be released).
                                        It's not saying that all the design files are already there. It's saying that's where they are released.
                                        *not actually a robot
                                        • zaptaundefined
                                          zapta @Danal
                                          This is cognitive dissonance, and is not personal. We humans are not good with consolidating opposing views. In this case, "The Duet's people are awesome" (they are) vs. "The Duet website misrepresents the OSH situation" (it does). It creates stress.
                                          https://en.wikipedia.org/wiki/Cognitive_dissonance
                                          • Danalundefined
                                            Danal
                                            Zapta said it very well. I have very positive opinion of Duet the company and the individuals in it. I also believe they can up the degree to which they align the green bar on the web site says with regard to 'open', align that better to actions.
                                            Those two things may seem dissonant to others.
