    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.0k
    • chas2706undefined
      chas2706
      @wilriker said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
      ./execonmcode -help
      I have placed execonmcode in /usr/local/bin and typed the following in the terminal without success:
      pi@Duet3:~ $ cd /usr/local/bin
      pi@Duet3:/usr/local/bin $ ls
      execonmcode listen-for-shutdown.py
      pi@Duet3:/usr/local/bin $ ./execonmcode -help
      bash: ./execonmcode: Permission denied
      pi@Duet3:/usr/local/bin $ sudo ./execonmcode -help
      sudo: ./execonmcode: command not found
      pi@Duet3:/usr/local/bin $ execonmcode -help
      bash: /usr/local/bin/execonmcode: Permission denied
      pi@Duet3:/usr/local/bin $ sudo execonmcode -help
      sudo: execonmcode: command not found
      • wilrikerundefined
        wilriker @chas2706
        @chas2706 Have you made execonmcode executable via sudo chmod +x /usr/local/bin/execonmcode? I think that's missing from the installation instructions.
        Manuel
        My Tool Collection
        • chas2706undefined
          chas2706
          @wilriker
          No I forgot!!
          My silly mistake! It works a treat now.
          Thank you for your help.
          • wilrikerundefined
            wilriker @chas2706
            @chas2706 Thank you for implicitly pointing out a hole in the installation instructions. I amended that to GitHub already and will fix it above in an instant.
            Manuel
            My Tool Collection
            • chas2706undefined
              chas2706
              @wilriker
              No problem, again thanks for your help and for producing a fantastic plugin.
              • wilrikerundefined
                wilriker
                Important Note
                The current version of Exec On MCode is NOT compatible with DSF 1.3.0+. It will connect but fail at a random point in time which might lead to breaking side-effects. I will release a new version tomorrow or Monday. Until then, don't use this tool with DSF 1.3.0+.
                Manuel
                My Tool Collection
                • chas2706undefined
                  chas2706
                  Important Note
                  I plan to temporarily remove this feature can you confirm that all I need to do this is to delete the extension?
                  I did not enable it to run at start up.
                  Many thanks for pointing this out.
                  • wilrikerundefined
                    wilriker @chas2706
                    @chas2706 If you don't start it (automatically or manually) there is no need to do anything. It can sit in the filesystem that won't have any effect until you execute it.
                    Manuel
                    My Tool Collection
                    • wilrikerundefined
                      wilriker
                      Release 4.0
                      This version works with DuetSoftwareFramework 1.3.0 and later.
                      Unfortunately due to breaking changes in the API of DSF this is NOT backwards-compatible with older versions of DuetSoftwareFramework.
                      This release also has a new parameter -trace that will enable output of the underlying requests/responses to/from DuetControlServer.
                      It can be downloaded as usual from GitHub Releases page.
                      Manuel
                      My Tool Collection
                      • wilrikerundefined
                        wilriker
                        Release v5.0
                        This release updates godsfapi to v2 and thus is only compatible with Duet Software Framework 2.1.0 and later.
                        New Features
                        • A new command-line paramter -version to output the version and exit
                        Bug fixes
                        • After a handled code is intercepted and before the assigned command is executed Flush will be called to make sure we are in sync with the machine
                        Manuel
                        My Tool Collection
                        • gtj0undefined
                          gtj0
                          So many possibilities, so little time. I'd like to take a week off from my day job to do all the things that things like this can enable. 🙂
                          • wilrikerundefined
                            wilriker
                            Release 5.1
                            This release makes execonmcode compatible with Duet Software Framework 2.2.0 and later.
                            It can be found at GitHub Releases page as usual.
                            Manuel
                            My Tool Collection
                            • PCRundefined
                              PCR
                              got this error
                               dial unix /var/run/dsf/dcs.sock: connect: no such file or directory
                              any idea?
                              • PCRundefined
                                PCR
                                Sorted it out! The PI has to be connected to the Duet!
                                • PCRundefined
                                  PCR
                                  made a little videos how to install it. Mainly for my own reference later
                                  How to install and test
                                  How to make it as a systemservice
                                  PCRundefined 1 Reply Last reply Reply Quote 2
                                  • oozeBotundefined
                                    oozeBot @wilriker
                                    @wilriker are the parameters capped at 3? If not, what are there limits? Thanks
                                    • wilrikerundefined
                                      wilriker @oozeBot
                                      @oozeBot It should be at least 23 (every upper-case letter except G, M and T). Possibly also every lower-case letter, but I never tried that.
                                      The application itself has no enforced limit.
                                      Manuel
                                      My Tool Collection
                                      • oozeBotundefined
                                        oozeBot
                                        I posted a response a few minutes ago, but deleted it after I finally realized my mistake..
                                        One note on this that's worth mentioning is the % in the service file has to be escaped like %%. Here is an example file:
                                        [Unit]
                                        Description=Duet API listener Test
                                        After=duetcontrolserver.service
                                        Requires=duetcontrolserver.service
                                        [Service]
                                        ExecStart=/usr/local/bin/execonmcode -mCode 4567 -command "./test.sh %%A %%B %%C"
                                        Restart=always
                                        RestartSec=10
                                        [Install]
                                        WantedBy=multi-user.target
                                        wilrikerundefined 1 Reply Last reply Reply Quote 2
                                        • wilrikerundefined
                                          wilriker @oozeBot
                                          @oozeBot I added a note to the README.md. I hope this helps to prevent this trap in the future.
                                          Manuel
                                          My Tool Collection
                                          • docboboundefined
                                            docbobo
                                            Is this compatible with the latest beta?
