    Show me your duet 3 enclosures!
    duet3 enclosure
    19
    36
    3.5k
    • oozeBotundefined
      oozeBot
      Still working on this, but here is my v1 mock-up..!
      • Chasedogundefined
        Chasedog
        Got this one done and I left the STEP file: https://www.thingiverse.com/thing:4231655
        • mwwhitedundefined
          mwwhited
          I was thinking about designing and printing brackets and then I remembered I had a pile of acrylic glass left over from another project. The cover for the high voltage connections is my first hand formed acrylic... took several tries and isn't very sexy but it gets the job done.
          I have alot more upgrades planned... sucks that this world wide lock-in has caused the majority of my part orders to be canceled or delayed.
          • Psylenceoundefined
            Psylenceo
            I feel the need to add cooling I just haven't figured how I want to do it though. I also have not printed it yet.
            • jumpedwithbothfeetundefined
              jumpedwithbothfeet
              Finally posted my enclosure on Thingiverse, Iโ€™ll be making further refinements but itโ€™s mostly there, Iโ€™m really happy how the logo came out, any suggestions Iโ€™m happy to hear them ๐Ÿ™‚
              https://www.thingiverse.com/thing:4307535
              #edit I have unfortunately had to close my account on thingiverse due to the recent hacking etc Iโ€™ll attach the latest STLs to this post soon for those who want them ๐Ÿ™‚
              335A3CCF-9F2A-4B73-8F14-A9DB29940A1E.jpeg 3075DBE0-8EC4-4102-A72F-AC3A41D112B2.jpeg 1129D221-9A16-42B6-9D2B-DBF33ABFA64E.jpeg
              6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
              jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 1
              • CCS86undefined
                CCS86
                DocTruckerundefined mwwhitedundefined matej1006undefined 4 Replies Last reply Reply Quote 1
                • DocTruckerundefined
                  DocTrucker @CCS86
                  @CCS86 I presume that PSU is heavily modified? The fans tend to exhaust in that location and you've got the fan blowing in?
                  CCS86undefined 1 Reply Last reply Reply Quote 0
                    DocTrucker @CCS86
                    @CCS86 ...but since you suck ( ๐Ÿ˜ฎ ) you could consider adding fan filters so dust doesn't clog up the back side of the duet. Nice fan ducting though, food for thought! ๐Ÿ™‚
                    • mwwhitedundefined
                      mwwhited @CCS86
                      That's not a duet3 ๐Ÿ˜‰ ... pretty nice looking enclosure anyway. I was debating between plywood and acrylic for my baseplate.
                      • CCS86undefined
                        CCS86 @DocTrucker
                        @DocTrucker said in Show me your duet 3 enclosures!:
                        It isn't modified besides the fan replacement. The original fan also blew into the power supply like this, but it was loud. Most axial fans are setup to blow through, not pull.
                        I could, but I'm not too worried about it. There is nothing to "clog up" on the back side of that PCB.
                        @mwwhited said in Show me your duet 3 enclosures!:
                        Whoops, it's too early!
                        But the same concept applies, regardless of the board.
                          DocTrucker @CCS86
                          @CCS86 there's no pattern to it. I've got your power supply and indeed it does suck in.
                          The 500W meanwell has a fan on the top edge that sucks out, and a 200W meanwell as well as a 350W no name suck in.
                          • Danalundefined
                            Danal
                            Not strictly speaking an enclosure, this is the back of a "Jubilee" tool changing printer:
                            • mwolterundefined
                              mwolter
                              Remixed a case for the Duet 2 that I found quite good. It provides ample natural cooling, cable access and the lid swings out of the way. Also includes mounts for a 92mm and 40mm fan, even though fans are not necessary if using typical NEMA 17 steppers.
                              https://www.thingiverse.com/thing:4308292
                              • CCS86undefined
                                CCS86 @DocTrucker
                                You can't "suck in". It is "blowing in" regardless of whether the fan is mounted flush to the inside or outside of the enclosure.
                                DocTruckerundefined 1 Reply Last reply Reply Quote 1
                                  DocTrucker @CCS86
                                  @CCS86 you're being pedantic, I am merely indicating direction.
                                  Anyhow whats the problem? I was merely saying even with one manufacturer the airflow direction isn't consistent. Hence my original confusion with the direction of your fan.
                                  • gtj0undefined
                                    gtj0
                                    From https://forum.duet3d.com/topic/14883/black-beauty-arises
                                    • mwolterundefined
                                      mwolter
                                      @gtj0 Impressive! Shielded stepper cables?
                                      Planning to install a Pi once DSF is a little more stable. Curious what pins you connected from the D3 to the Pi. Interested in only using whatโ€™s necessary and leaving the rest for future GPIO.
                                      PS Your bearing block on the Z lead screw is a great idea. Might have to steal that one ๐Ÿ˜‰
                                      DocTruckerundefined gtj0undefined 2 Replies Last reply Reply Quote 0
                                        DocTrucker @mwolter
                                        @mwolter check out the schematics. The required connections are listed there. If you supply an isolated external 5v (negating need for the +5V cores) to the Pi I'm not sure if it would be possible to save on a few of the negative connections too.
                                        Edit: if you do use an external supply for the pi ensure the dc negative isn't directly linked to earth as you could set up an earth loop with considerable current if your main psu is earth tied.
                                          A Former User @DocTrucker
                                          earth loop
                                          drew up an isolator (back in January) but haven't had a chance to test it (nor decided weather to add a 3.3v ldo instead of a 3.3v header)
                                          suppose could create a new topic to discuss if there is interest. (edit, changed to ADuM1200BR to allow 10mbps, ISO7721DR seems to be pin compatible and i'll do a test with that)
                                          Moved it to a a less personal EasyEDA account, https://easyeda.com/bearer/duet36hc-isolator
                                          DocTruckerundefined arhiundefined 2 Replies Last reply Reply Quote 2
                                            DocTrucker @A Former User
                                            @bearer nice work!
