    Automatic XY skew calibration
    Firmware wishlist
    11
    25
    6.3k
    • boelleundefined
      boelle
      marketing yes… but why does he put that much effort in it if its not needed?
      is it more a feature for those that are not able to assemble a printer?
      if nothing else could it not be seen as a tool to help get the frame right and if you can get it spot on then let the firmware compensate the last bits you can get yourself?
        deckingman
        @boelle:
        In answer to your first question - because if people think it's a really cool thing to have, it'll help sell his printers. Personally I think it's a solution to a problem that either doesn't exist or one that is easily fixed by other means (but that's because I'm a my cynical old man).
        Yes, it's for those who can't assemble a printer, or perhaps those who have a bought a kit consisting of poorly designed or manufactured parts - again, that's my personal opinion.
        We have a tool. M556 axis compensation. Print a test piece, measure the error and enter the values (or correct the error mechanically). It's done once. Why do we need yet another layer of complexity in the firmware? Also, we'd be relying on some sort of sensor to measure the deviation which may itself have calibration issues. Personally, I prefer to use accurate vernier calipers, dial gauges, feeler gauges and the like (but then, I'm old fashioned as well as being cynical).
        • jmjcoke2undefined
          jmjcoke2
          I think it is worth the time and effort to implement and it will be very useful in regards to further CNC development were probing to correct angular error is even more essential, the larger belt driven gantry systems as an example. You could even probe the beds edges and then drive gantry motors independently to physically make the the machine square . I would like to see not just skew but what siemens calls cross error compensation for all axis, as in probe a machinist square in the x axis every 2 mm and correct for angular between points by moving the y axis, also called geometric or sag compensation.
          • Dougal1957undefined
            Dougal1957
            What we seem to be missing here is that the Prusa system does Need a specific Bed with the sensor points in it. It will not work and just any old Bed? That to me severely limits it's appeal.
            As Deckingman points out we already have the tools to be able to compensate for the error using the M556 command and if done that way manually unless you have to strip down the Axis then it is never going to change.
            I to prefer to make sure my Printer is as Accurate as possible have not as yet used Bed Compensation I will however run it on the New Delta to check the bed but hopefully won't need to implement it at all.
            The fewer things the FW Has to contend with whilst printing is IMHO better
            just my two penworth
            Doug
            • boelleundefined
              boelle
              "Prusa system does Need a specific Bed with the sensor points in it"
              Yep or almost yes… it needs a bed with 9 points that triggers the probe, probe must not be triggered outside these points. other than that there is not so much special about it other than it has zoned heating so that the heat is more unitform
              "I to prefer to make sure my Printer is as Accurate as possible" same here, but i might have bad tools or screwing up something so its less precise. having an option to be told you did a bad job on the frame and by this much would help. If i get it right hurra, but if i just cant get it spot on then i might have to bite the dust.
              but as said above it could be a selling point, but as I said it should sit on the bottom of the list
              And if at all possible it should of course be expanded so its dealing with more than just XY skew, and it should of course be possible to totally disable it for those that do not need or want it
              • DjDemonDundefined
                DjDemonD
                I also fall into the build it properly camp now, but I didn't used to. This is a useful feature at the lower end of the market, but that's not where duet users typically are.
                I'd say do it if it's easy to include (which I suspect it's not) or don't use time that could be better spent on more useful features.
                www.precisionpiezo.co.uk
                  Dougal1957
                  @DjDemonD:
                  Agree 100% with this sentiment!
                  • pjr3Dundefined
                    pjr3D
                    I agree that this is a feature that is most useful to new users with specific hardware ( Prussia i3 mk2).
                    But then again, should we not include support for those who most need it rather than just support the experienced and competent users? It seems that this kind of sense/compensate feature has uses in multi-axis/cnc applications and it would be good to support it - but not perhaps at the top of the list!
                    • boelleundefined
                      boelle
                      "with specific hardware ( Prussia i3 mk2)."
                      what about others users with the same bed but not the same printer?
                      agree that it could be placed somewhat down the list and maybe be expanded to compensate for other than XY skew if possible
                        I didn't express my own opinion earlier because I didn't want to bias the discussion. But this thread has been live for a couple of days so I'll express my opinion now.
                        • The only thing that Prusa is offering that we don't do already is automatic (as opposed to manual) compensation for XY skew.
                        • From what I can see, Prusa isn't offering any sort of compensation for XZ or YZ skew, whereas RRF does
                        • If a printer build doesn't have X and Y accurately at right angles to each other, then I suspect it won't have Z accurately at right angles to both X and Y, unless the nature of the design makes it likely that the XY angle will be much less accurate than the XZ and YZ angles. So I don't see much value in automatic XY skew compensation without also having automatic XZ and YZ skew compensation.
                        • Measuring XZ skew and YZ skew automatically would not be easy, because the mechanism of using a bed with markers placed in it restricts you to probing at a height very close to the bed.
                        • That type of bed also restricts you to using only as many mesh bed compensation points as there are markers on the bed, which is 9 in the case of the Prusa i3 Mk2 bed. Whereas the Duet WiFi supports up to 441 bed probe points. 9 points is likely to be sufficient for small Cartesian printers, but not for larger printers.
                        • As far as I know, no firmware other than RRF has supported any form of skew compensation before Prusa added it, and I've never seen anyone raising skew on Cartesian printers as an issue on any of the forums I monitor. So I see no evidence that XY skew is a common issue (or even a rare one).
                        So my gut feeling is that automatic XY skew compensation is a solution to a non-problem. Most people don't have difficulty getting their X and Y axes perpendicular. For those who do, manual skew compensation is available, and if used as instructed it also provides XZ and YZ skew compensation.
                        So I'm inclined to put it waaay down on the priority list. But we're customer-driven at RRF, so your votes are what counts.
                        • kraegarundefined
                          kraegar
                          I saw a couple printers that would have benefited from this compensation at MRRF due to errors induced in transport - some traveled better than others. Or at least on brief inspection, a few looked a bit off. But that's typical for MRRF, people slap their printers down and hit print, any auto-cal is beneficial because no one's wanting to sit around calibrating when they could be talking to others and enjoying the fest. Now whether the issue should have not occured if they'd been build more solidly is a different question, but I was very glad to have full autocalibration on my delta while there.
                          That might be a rather unique use case, though, not sure how often people travel with their printers.
                          • boelleundefined
                            boelle
                            "no firmware other than RRF has supported any form of skew compensation"
                            Repetier does, but also has to be done manual
                            Q…. Would the mini IR board be a batter choice here? and how well would it work on that black matt surface with PEI sheet on?
                              T3P3Tony administrators
                              boelle
                              There could be a way of using an IR sensor, combined with an accurately manufactured "datum" sheet to do the same form of compensation. A pattern (similar to a bar code) can be printed at various points on the datum sheet which the IR sensor, if scanned at the right height, can detect. The sheet would need to be manufactured with cutouts or very varied reflectivity
                              This would be a lot of work to implement and (unlike other forms of auto calibration like delta auto calibration) is not as common an issue.
                              Further more neither of these methods works with a touch probing system like the peizo sensor.
                              My view is it is a low priority in comparison to most other things.
                              • kingfisherundefined
                                kingfisher
                                I'm thinking of signing up to the indiegogo campaign, but have a quick question as I use a Mini height sensor board…
                                Will the Mini height sensor board be be compatible, based on the height sensor instructions:
                                "PEI: this is highly transparent to IR. Paint the underside matt black (see below) before using adhesive sheet to attach it to the bed plate."
                                I assume that as the MK42 heated bed is black and the PEI is applied directly to this, this step wouldn't be required?
                                • boelleundefined
                                  boelle
                                  you are right
                                  the mk42's are matt black and the PEI is put on top
                                  i too will end up with the mini ir, i assume that the duet will make use of the analog output
                                    kingfisher
                                    My heated bed from the indiegogo campaign has arrived
                                    Does anyone know if the Mini height sensor will be able to cope with the matt black PCB and thin PEI or would i be better off getting a sheet of Buildtak instead?
                                    Willing to experiment, but if the PEI is a lost cause I'd rather not put it on to only have to peel it off 30mins later…
                                      PEI placed on top of a matt black surface with no intervening adhesive should be OK, but if there is an intervening adhesive sheet then reflections from the light-coloured adhesive are likely to cause problems.
                                        kingfisher
                                        @dc42:
                                        Thanks for the reply the PEI does have a thin adhesive layer. I might play safe to start with and get in a bigger buildtak sheet as I know that works well with the sensor.
                                        I like the idea of the piezo sensors but I will need to think about how to mount it on a i3 with a Titan Aero…
                                        • DjDemonDundefined
                                          DjDemonD
                                          We have a titan bracket system now not many in use currently but it works. Will work with titan and titan aero. See the site below or search DjDemonD on thingiverse. It's based on the official bracket from e3d.
                                            kingfisher
                                            @DjDemonD:
                                            Thanks, I had a look at that I'll need to redesign it to fit my setup, I see that your bracket has some flex built in the base I'll need to come up with a way to add this to my carriage or make a two part carriage to incorporate your bracket
                                            I've just made this for the IR sensor which is working quite well. (https://www.thingiverse.com/thing:2441400) So I'll stick with this and buildtak in the short term and keep an eye out for Cartesian Piezo carriages/brackets and switch if i need to move over to PEI
