DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1
@gtj0 said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
@Danal said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
I believe he's saying, "start a job, and then close DWC".
Yes, I tried that. SSH only, no VNC, no DWC. Still locked within a few minutes.
Yeah that was it. I wanted to make sure it wasn't DWC related. I've been running RC10 + 2.1.1 and printing fine but I don't use the DWC.
Something to try... The systemd service file for the DCS was changed to set
CPUSchedulingPolicy=fifo CPUSchedulingPriority=20 which may be contributing to the problem.
Edit
/lib/systemd/system/duetcontrolserver.service
and remove those 2 lines, then reboot and see if that helps.I've checked the above folder and I don't have a duetcontrolserver.service file to edit
@jay_s_uk said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
Edit
See if it's in /usr/lib/systemd/system.
Thats where they are. I have commented them out and will report back
I have managed a small print without any failures.
So far so good. -
In fact, if anyone else is working on one, I'll stop.
gave up on recursion seems all reprapfirmware from 1.0.4.1-1 to 1.2.5.0-1 has a dependency to duetcontrolserver 1.0.3.4 which doesn't exist (which probably means or greater but )
Data point: I have not changed the CPU scheduling and an approximate 18 hour print just finished.
Running DuetLapse on the same Pi. (Which I was not doing the other day).
I will try to reproduce, document variances, run without anything else running, etc.
@Danal I wonder if DuetLapse is using just enough time to keep the DCS from hogging it all.
@Garfield @ChrisP Have you tried my suggestion above to remove the two CPUScheduling lines from /lib/systemd/system/duetcontrolserver.service and rebooting?
I haven't yet, but only because I've not had chance (5 and a half hour Teams meeting today - these really are "special" times). I'll give it a go now.
Do you think the priority is like to have any effect on the cause of the crash though? Certainly if DCS does go nuts and it has a high priority, this will result in the total lock-ups that we're seeing, but is it going to be part of the in initial cause? I guess perhaps if DCS is waiting for something that can get CPU time because it's being blocked by DCS.... but if this were the case, I'd have thought it'd recover at some point?
To be honest, this doesn't entirely surprise me - I've managed to do a couple of decent length prints without issue... indeed, I've never had it crash mid-print. If my system is going to die, it usually does it pretty much immediately on startup and I think it's happened twice when I've opened a new DWC instance, but' I'm not confident to say that that is anything more than coincidence at the moment. My experience has mainly been that if it boots and doesn't crap out in the first few minutes then it'll just keep going.
The one thing that I have noticed that may or may not be related is that I've been noticing that on the DWC instance that running on the Pi, the left hand menu bar frequently becomes totally unresponsive, even after a Ctrl-F5 of the page. DWC otherwise seems to be working as I can see temperature fluctuations and print status progressing but the only way I've found to get the menu bar to respond is to reset DCS.
Anyway, I'll try removing the CPUScheduling since I have no better ideas currently.
@ChrisP I don't think it's the cause of the crashes themselves but I do think that removing the real-time scheduling (fifo) will make it a LOT easier to troubleshoot further.
@ChrisP said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
I believe that fits the behaviors I saw on Sunday evening. I wasn't really "logging", not even mentally, so I am not absolutely certain.
@deckingman said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
@Garfield said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
....................... but right now the learning curve is pretty steep and what I think should be simple tasks seem not to be - and I do this **** for a living !!
My God, what chance do us mere mortals have! As far as I'm concerned, you guys are all talking in some foreign language that I don't understand. I'll be sticking with stand alone operation for quite some time yet methinks.
Best not to tour the sausage factory before the wiener roast.
Just did the scheduling thing - no change, I increased the timeout also but no difference.
I don't mind helping out here but I need some direction from the devs on what to look for - and where to look for it. So if it will be useful I will help work through this - otherwise I really need this printer back in service ....
Apr 27 20:17:09 duet3 systemd[1]: duetcontrolserver.service: Succeeded. Apr 27 20:33:50 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=30s expired, scheduling restart. Apr 27 20:33:50 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 1. Apr 27 20:33:50 duet3 systemd[1]: Stopped Duet Control Server. Apr 27 20:33:50 duet3 systemd[1]: Started Duet Control Server. Apr 27 20:33:51 duet3 DuetControlServer[763]: Duet Control Server v2.1.1 Apr 27 20:33:51 duet3 DuetControlServer[763]: Written by Christian Hammacher for Duet3D Apr 27 20:33:51 duet3 DuetControlServer[763]: Licensed under the terms of the GNU Public License Version 3 Apr 27 20:33:51 duet3 DuetControlServer[763]: [info] Settings loaded Apr 27 20:33:51 duet3 DuetControlServer[763]: [info] Environment initialized Apr 27 20:33:51 duet3 DuetControlServer[763]: [info] Connection to Duet established Apr 27 20:33:51 duet3 DuetControlServer[763]: [info] IPC socket created at /var/run/dsf/dcs.sock Apr 27 20:33:53 duet3 DuetControlServer[763]: [fatal] Abnormal program termination Apr 27 20:33:53 duet3 DuetControlServer[763]: [fatal] Update task faulted Apr 27 20:33:53 duet3 DuetControlServer[763]: System.ArgumentException: Property set method not found. Apr 27 20:33:53 duet3 DuetControlServer[763]: at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture) Apr 27 20:33:53 duet3 DuetControlServer[763]: at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, Object[] index) Apr 27 20:33:53 duet3 DuetControlServer[763]: at System.Reflection.PropertyInfo.SetValue(Object obj, Object value) Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 237 Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.FilamentMonitor.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Sensors/FilamentMonitors/FilamentMoni Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 209 Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.FilamentMonitor.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Sensors/FilamentMonitors/FilamentMoni Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264 Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 149 Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 182 Apr 27 20:33:53 duet3 DuetControlServer[763]: [fatal] Update task faulted Apr 27 20:33:53 duet3 DuetControlServer[763]: System.ArgumentException: Property set method not found. Apr 27 20:33:53 duet3 DuetControlServer[763]: at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture) Apr 27 20:33:53 duet3 DuetControlServer[763]: at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, Object[] index) Apr 27 20:33:53 duet3 DuetControlServer[763]: at System.Reflection.PropertyInfo.SetValue(Object obj, Object value) Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 237 Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.FilamentMonitor.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Sensors/FilamentMonitors/FilamentMoni Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 209 Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.FilamentMonitor.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Sensors/FilamentMonitors/FilamentMoni Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264 Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 149 Apr 27 20:33:53 duet3 DuetControlServer[763]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 182 Apr 27 20:33:53 duet3 DuetControlServer[763]: [info] Application has shut down Apr 27 20:33:53 duet3 systemd[1]: duetcontrolserver.service: Succeeded. Apr 27 20:34:23 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=30s expired, scheduling restart. Apr 27 20:34:23 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 2. Apr 27 20:34:23 duet3 systemd[1]: Stopped Duet Control Server. Apr 27 20:34:23 duet3 systemd[1]: Started Duet Control Server. Apr 27 20:34:23 duet3 DuetControlServer[879]: Duet Control Server v2.1.1 Apr 27 20:34:23 duet3 DuetControlServer[879]: Written by Christian Hammacher for Duet3D Apr 27 20:34:23 duet3 DuetControlServer[879]: Licensed under the terms of the GNU Public License Version 3 Apr 27 20:34:24 duet3 DuetControlServer[879]: [info] Settings loaded Apr 27 20:34:24 duet3 DuetControlServer[879]: [info] Environment initialized Apr 27 20:34:24 duet3 DuetControlServer[879]: [info] Connection to Duet established Apr 27 20:34:24 duet3 DuetControlServer[879]: [info] IPC socket created at /var/run/dsf/dcs.sock Apr 27 20:34:24 duet3 DuetControlServer[879]: [warn] Daemon: Out-of-order reply: '' Apr 27 20:34:25 duet3 DuetControlServer[879]: [fatal] Abnormal program termination -
I now have DCS up and running - this is something in config.g that it doesn't like and is bombing out. I looked at line 182 in updater.cs and it is immediately after it parses the fans. I have one fan defined as an output to enable a relay for lighting, this fan is not associated with anything - nor will it ever be - needed an on off output I could fire at will and this fitted the bill, I wonder if this is the trigger for the failure - it can't associate it with anything ???
Q : Is it possible to add an 'output' type that is neither a heater nor a fan to RRF3
I have almost my entire config.g commented out and will enable stuff line by line until it breaks again ..
My system.g is below
After uncommenting a line the reset takes an eternity, it works but it is a cause for concern - way too slow resetting
look at M42
So here is a 'partial' result.
DCS does not fail gracefully if it encounters something in .g files that it can't parse for whatever reason - it crashes and doesn't recover.
Sorry boys - needs to be a whole lot more friendly than this, errors should be reported and ignored, error trapping needs work.
Loss of DCS should not prevent the web server functioning - or how can you fix whatever the problem is. The web portal should report the loss of DCS, should report problems encountered parsing .g files - including the line concerned but should remain accessible to allow .g file edits / fixes. If you need DCS to make the edits then sort out the error trapping but might want to review the architecture in that case.
My config-override.g is currently empty .... this too blows DCS up ...
Apr 27 21:22:57 duet3 DuetControlServer[5864]: [info] Settings loaded Apr 27 21:22:58 duet3 DuetControlServer[5864]: [info] Environment initialized Apr 27 21:22:58 duet3 DuetControlServer[5864]: [info] Connection to Duet established Apr 27 21:22:58 duet3 DuetControlServer[5864]: [info] IPC socket created at /var/run/dsf/dcs.sock Apr 27 21:22:58 duet3 DuetControlServer[5864]: [info] Starting macro file config.g on channel Trigger Apr 27 21:22:58 duet3 DuetControlServer[5864]: [warn] M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 875C Apr 27 21:22:59 duet3 DuetControlServer[5864]: [info] Starting macro file config-override.g on channel Trigger Apr 27 21:22:59 duet3 DuetControlServer[5864]: [info] Finished macro file config-override.g Apr 27 21:23:00 duet3 DuetControlServer[5864]: [fatal] Abnormal program termination -
@Garfield Wow. There is somehting going on in your environment. I can't reproduce either the M950 or config-override.g issues.
Probably a good idea to just go back to a "stable" build and wait for things to shake out a bit more. Thanks for trying anyway.
@gtj0 I wish I knew how to just get back to a base I can trust at this stage, was fine at RC6 but it seems that even that is busted now on my box.
I've firmware erased and tried all manner of 'stuff' now, if I comment out certain lines in config.g things keep running ...
Going to blow this back to the stable release but it has problems that I couldn't live with (some of which centred on the PINDA), I also had homing issues - hence I was into the RC's - seems like something is buried in there that erase and re-imaging isn't clearing ...
@Garfield Yeah it's frustrating I know. You may want to create an issue in the DSF GitHub repo with that crash anyway. If not, would you mind if I opened an issue on your behalf?
Absolutely no issue at all with you adding - I suppose I should create a GIT account .... even then though I need to be sure my own incompetence isn't the cause before logging anything - so I'll still run it by here.
@Garfield https://github.com/chrishamm/DuetSoftwareFramework/issues/128
It looks like that crash is in filament monitor code. With your config.g, maybe I can reproduce it later today.
