    DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1
    Beta Firmware
    12
    132
    7.3k
    • Danalundefined
      Danal
      Data point: I have not changed the CPU scheduling and I am now about 14 hours into a print, with no issues.
      Running DuetLapse on the same Pi. (Which I was not doing the other day).
      I don't know what changed, if anything, from the point where I couldn't get it to run for 15 minutes at a time.
      gtj0undefined Danalundefined 2 Replies Last reply Reply Quote 0
      • Garfieldundefined
        Garfield
        I've not tried the scheduling - can't get DCS to start and stay running, first time it came up and was fine - until I threw my .g files at it and then BOOM ....
        I need to get the whole thing back to RC6 and stable but right now it is all turned off (day job - that and run out of patience for now).
        Could really do with that 'version compatibility' matrix ....
        gtj0undefined A Former User? Danalundefined 4 Replies Last reply Reply Quote 0
        • gtj0undefined
          gtj0 @Danal
          @Danal When your print is done it's be helpful if you could test without DuetLapse and see if you can reproduce the issue, then try removing the CPUScheduling lines.
          • gtj0undefined
            gtj0 @Garfield
            @Garfield Understood. If you do get a chance, try removing those 2 lines.
              A Former User @Garfield
              @Garfield said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
              back to RC6
              @bearer said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
              RRF3.01-RC10     duetsoftwareframework 2.1.1      reprapfirmware 2.1.1-1
              RRF3.01-RC9      duetsoftwareframework 2.1.0      reprapfirmware 2.1.0-1
              RRF3.01-RC8      duetsoftwareframework 2.0.0      reprapfirmware 2.0.0-1
              RRF3.01-RC7      duetsoftwareframework 1.3.2      reprapfirmware 1.3.2-1
              RRF3.01-RC6      duetsoftwareframework 1.3.1      reprapfirmware 1.3.1-1
              RRF3.01-RC6      duetsoftwareframework 1.3.0      reprapfirmware 1.3.0-1
              RRF3.01-RC4      duetsoftwareframework 1.2.5.0    reprapfirmware 1.2.5.0-1
              RRF3.0           duetsoftwareframework 1.2.4.0    reprapfirmware 1.2.4.0-1
              RRF3.0           duetsoftwareframework 1.2.3.1    reprapfirmware 1.2.3.1-1
              RRF3.0           duetsoftwareframework 1.2.3.0    reprapfirmware 1.2.3.0-1
              RRF3.0           duetsoftwareframework 1.2.2.1    reprapfirmware 1.2.2.1-1
              RRF3.0RC2+1      duetsoftwareframework 1.2.2.0    reprapfirmware 1.2.2.0-1
              RRF3.0RC1        duetsoftwareframework 1.2.1.0    reprapfirmware 1.2.1.0-1
              RRF3.0RC1        duetsoftwareframework 1.2.0.0    reprapfirmware 1.2.0.0-1
              RRF3.0beta11     duetsoftwareframework 1.1.0.5    reprapfirmware 1.1.0.5-1
              RRF3.0beta11     duetsoftwareframework 1.1.0.4    reprapfirmware 1.1.0.4-1
              RRF3.0beta10+2   duetsoftwareframework 1.1.0.3    reprapfirmware 1.1.0.3-1
              RRF3.0beta10+2   duetsoftwareframework 1.1.0.2    reprapfirmware 1.1.0.2-1
              RRF3.0beta10+2   duetsoftwareframework 1.1.0.1    reprapfirmware 1.1.0.1-1
              RRF3.0beta10+2   duetsoftwareframework 1.1.0.0    reprapfirmware 1.1.0.0-1
              RRF3.0beta10+1   duetsoftwareframework 1.0.4.1    reprapfirmware 1.0.4.1-1
              depcheck()
                local NODE=$1
                local VER=$2
                local pattern="\ ([a-z]*)\ \([0-9]+\ ([0-9\.]+-?[0-9]{0,2})\)"
                local IFS=$'\n'
                s=$(apt-cache showpkg $NODE |  grep "^$VER - ." )
                for package in $(echo $s | grep -Eo  $pattern)
                do
                  [[ $package =~ $pattern ]]
                  [ "${BASH_REMATCH[1]}" == "${BASH_REMATCH[2]}" ] || echo -en "  ${BASH_REMATCH[1]}=${BASH_REMATCH[2]} $EOL"
                  [ "${BASH_REMATCH[1]}" == "duetcontrolserver" ] && depcheck ${BASH_REMATCH[1]} ${BASH_REMATCH[2]}
                done
              [ $# -gt 0 ] && {
              V=$1
              PARENT=duetsoftwareframework
              [ $# -gt 1 ] && PARENT=$2
              EOL=""
              [ -t 1 ] && EOL="\\ \n"
              echo  -en "sudo apt install $EOL"
              depcheck $PARENT $V
              [ -t 1 ] && EOL="\n"
              echo  -en "  $PARENT=$V $EOL"
              } ||  echo $0 version ;
              save as dsfdep.sh and run like bash dsfdep.sh 1.3.1 to restore to 3.01-RC6
              copy and paste the suggest command and hope for the best (or put in backticks if braver than most)
              pi@raspberrypi:~ $ bash dsfdep.sh 1.3.1
              sudo apt install \
                duetcontrolserver=1.3.1 \
                duetruntime=1.3.1 \
                duetsd=1.0.6 \
                duettools=1.3.1 \
                duetwebserver=1.3.1 \
                duetwebcontrol=2.1.1 \
                reprapfirmware=1.3.1-1 \
                duetsoftwareframework=1.3.1
              • Danalundefined
                Danal @gtj0
                @gtj0 said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
                Will do.
                May do a different print, this one is running MUCH longer than I anticipated. It is a toolchanger multi-material, and "estimators" do not (yet) account for the time spent changing tools. There are 1045 changes in this print.
                • Danalundefined
                  Danal @Garfield
                  I'm working on a script that generates one. No promises as to when... lots of learning and research on my part.
                  In fact, if anyone else is working on one, I'll stop.
                  • gloomyandyundefined
                    gloomyandy
                    Just as another data point. After my initial crashes I went on to print (for a couple of hours or so) with no problems and things seemed pretty stable. I wonder if forcing a reload of DWC had anything to do with the problem?
                      jay_s_uk @gtj0
                      @Danal said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
                      I believe he's saying, "start a job, and then close DWC".
                      Yes, I tried that. SSH only, no VNC, no DWC. Still locked within a few minutes.
                      Yeah that was it. I wanted to make sure it wasn't DWC related. I've been running RC10 + 2.1.1 and printing fine but I don't use the DWC.
                      Something to try... The systemd service file for the DCS was changed to set
                      CPUSchedulingPolicy=fifo
                      CPUSchedulingPriority=20
                      which may be contributing to the problem.
                      Edit /lib/systemd/system/duetcontrolserver.service and remove those 2 lines, then reboot and see if that helps.
                      @gtj0
                      I've checked the above folder and I don't have a duetcontrolserver.service file to edit
                      • gtj0undefined
                        gtj0 @jay_s_uk
                        @jay_s_uk said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
                        @gtj0
                        See if it's in /usr/lib/systemd/system.
                          jay_s_uk
                          @gtj0
                          Thats where they are. I have commented them out and will report back
                            jay_s_uk
                            @gtj0
                            I have managed a small print without any failures.
                            So far so good.
                              A Former User @Danal
                              gave up on recursion seems all reprapfirmware from 1.0.4.1-1 to 1.2.5.0-1 has a dependency to duetcontrolserver 1.0.3.4 which doesn't exist (which probably means or greater but )
                              • Danalundefined
                                Danal @Danal
                                Data point: I have not changed the CPU scheduling and an approximate 18 hour print just finished.
                                I will try to reproduce, document variances, run without anything else running, etc.
                                • gtj0undefined
                                  gtj0 @Danal
                                  @Danal I wonder if DuetLapse is using just enough time to keep the DCS from hogging it all. 🙂
                                  • ChrisPundefined
                                    ChrisP @gtj0
                                    @Garfield @ChrisP Have you tried my suggestion above to remove the two CPUScheduling lines from /lib/systemd/system/duetcontrolserver.service and rebooting?
                                    I haven't yet, but only because I've not had chance (5 and a half hour Teams meeting today - these really are "special" times). I'll give it a go now.
                                    Do you think the priority is like to have any effect on the cause of the crash though? Certainly if DCS does go nuts and it has a high priority, this will result in the total lock-ups that we're seeing, but is it going to be part of the in initial cause? I guess perhaps if DCS is waiting for something that can get CPU time because it's being blocked by DCS.... but if this were the case, I'd have thought it'd recover at some point?
                                    To be honest, this doesn't entirely surprise me - I've managed to do a couple of decent length prints without issue... indeed, I've never had it crash mid-print. If my system is going to die, it usually does it pretty much immediately on startup and I think it's happened twice when I've opened a new DWC instance, but' I'm not confident to say that that is anything more than coincidence at the moment. My experience has mainly been that if it boots and doesn't crap out in the first few minutes then it'll just keep going.
                                    The one thing that I have noticed that may or may not be related is that I've been noticing that on the DWC instance that running on the Pi, the left hand menu bar frequently becomes totally unresponsive, even after a Ctrl-F5 of the page. DWC otherwise seems to be working as I can see temperature fluctuations and print status progressing but the only way I've found to get the menu bar to respond is to reset DCS.
                                    Anyway, I'll try removing the CPUScheduling since I have no better ideas currently.
                                    • gtj0undefined
                                      gtj0 @ChrisP
                                      @ChrisP I don't think it's the cause of the crashes themselves but I do think that removing the real-time scheduling (fifo) will make it a LOT easier to troubleshoot further.
                                      • Danalundefined
                                        Danal @ChrisP
                                        @ChrisP said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
                                        I believe that fits the behaviors I saw on Sunday evening. I wasn't really "logging", not even mentally, so I am not absolutely certain.
                                          Phaedrux Moderator @deckingman
                                          @deckingman said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
                                          ....................... but right now the learning curve is pretty steep and what I think should be simple tasks seem not to be - and I do this **** for a living !!
                                          My God, what chance do us mere mortals have! As far as I'm concerned, you guys are all talking in some foreign language that I don't understand. I'll be sticking with stand alone operation for quite some time yet methinks.
                                          Best not to tour the sausage factory before the wiener roast.
                                          • Garfieldundefined
                                            Garfield
                                            Just did the scheduling thing - no change, I increased the timeout also but no difference.
                                            I don't mind helping out here but I need some direction from the devs on what to look for - and where to look for it. So if it will be useful I will help work through this - otherwise I really need this printer back in service ....
                                            Apr 27 20:17:09 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                                            Apr 27 20:33:50 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=30s expired, scheduling restart.
                                            Apr 27 20:33:50 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 1.
                                            Apr 27 20:33:50 duet3 systemd[1]: Stopped Duet Control Server.
                                            Apr 27 20:33:50 duet3 systemd[1]: Started Duet Control Server.
                                            Apr 27 20:33:51 duet3 DuetControlServer[763]: Duet Control Server v2.1.1
                                            Apr 27 20:33:51 duet3 DuetControlServer[763]: Written by Christian Hammacher for Duet3D
                                            Apr 27 20:33:51 duet3 DuetControlServer[763]: Licensed under the terms of the GNU Public License Version 3
                                            Apr 27 20:33:51 duet3 DuetControlServer[763]: [info] Settings loaded
                                            Apr 27 20:33:51 duet3 DuetControlServer[763]: [info] Environment initialized
                                            Apr 27 20:33:51 duet3 DuetControlServer[763]: [info] Connection to Duet established
                                            Apr 27 20:33:51 duet3 DuetControlServer[763]: [info] IPC socket created at /var/run/dsf/dcs.sock
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]: [fatal] Abnormal program termination
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]: [fatal] Update task faulted
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    System.ArgumentException: Property set method not found.
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture)
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, Object[] index)
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    at System.Reflection.PropertyInfo.SetValue(Object obj, Object value)
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 237
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    at DuetAPI.Machine.FilamentMonitor.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Sensors/FilamentMonitors/FilamentMoni
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 209
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 149
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]:    at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 182
                                            Apr 27 20:33:53 duet3 DuetControlServer[763]: [info] Application has shut down
                                            Apr 27 20:33:53 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                                            Apr 27 20:34:23 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=30s expired, scheduling restart.
                                            Apr 27 20:34:23 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 2.
                                            Apr 27 20:34:23 duet3 systemd[1]: Stopped Duet Control Server.
                                            Apr 27 20:34:23 duet3 systemd[1]: Started Duet Control Server.
                                            Apr 27 20:34:23 duet3 DuetControlServer[879]: Duet Control Server v2.1.1
                                            Apr 27 20:34:23 duet3 DuetControlServer[879]: Written by Christian Hammacher for Duet3D
                                            Apr 27 20:34:23 duet3 DuetControlServer[879]: Licensed under the terms of the GNU Public License Version 3
                                            Apr 27 20:34:24 duet3 DuetControlServer[879]: [info] Settings loaded
                                            Apr 27 20:34:24 duet3 DuetControlServer[879]: [info] Environment initialized
                                            Apr 27 20:34:24 duet3 DuetControlServer[879]: [info] Connection to Duet established
                                            Apr 27 20:34:24 duet3 DuetControlServer[879]: [info] IPC socket created at /var/run/dsf/dcs.sock
                                            Apr 27 20:34:24 duet3 DuetControlServer[879]: [warn] Daemon: Out-of-order reply: ''
                                            Apr 27 20:34:25 duet3 DuetControlServer[879]: [fatal] Abnormal program termination
