    Trouble saving a manually probed mesh
    781
    • luckyflyerundefined
      luckyflyer
      I'm doing a manual mesh probe with my duet 3 on a new printer. I have config.G with these, M558 P0 probe set to no probe, M557 setup for where to probe and G31 X0 Y0 Z1. I G28 then run G29 and manually probe the bed. I run G29 S1 to view the map but DWC responds,
      Error: Failed to load height map from file heightmap.csv: Could not find file '/opt/dsf/sd/sys/heightmap.csv'." I'm running DWC 2.07 and 3.01rc4. Is the csv file save on the pi or on the sd card on the duet 3? I have no sd card in the duet , I understood that it was not needed when using a pi.
        Update to the latest 3.01-RC10 and associated DSF and DWC versions.
          luckyflyer
          I've updated to 3.01 RC10 and now get drive not mounted in dwc.
            Did you also update dsf
              luckyflyer
              Dsf 2.1.1 is installed, I have even reran the configurator and uploaded the files but dwc still says drive is unmounted. I have followed Danal's guide and the official duet guide with the same outcome. I've now tried this 3 times carefully following each step.
              Also I've noticed that that when I was doing the update that dwc was updated to 2.1.something but dwc shows its still at 2.0.7.
                luckyflyer
                Amazing, after about 30 to 40 minutes, I refreshed dwc in my web browser and all of the files are now there including an updated to 2.1.5 dwc. I guess my pi is running slow today.
                  luckyflyer
                  Today I've ran another manual mesh probe with 3.01 rc10 and dwc 2.1.5 installed. I ran it as above with G29 and G29 S0 and still I'm unable to view the height map, I get File 0:/sys/heightmap.csv not found. Is this file saved on the pi sd card or the sd card on the duet 3. I have installed a 128mb formatted with fat16 in the duet.
                    If you are running with the Pi connected, the Duet should have no SD card in it at all. Basically, there is a Virtual SD card saved on the Pi SD card which gets sent over to the Duet.
                      luckyflyer
                      I had read that the sd card was not used in the duet with pi but thought I would try it anyway,I've already taken it out. I give up on trying to manually probe, I'll put my bl touch on and use the g code another user with the same printer and duet shared with me and hope it works.
                        luckyflyer
                        So i have now installed a bl touch and it works and does its thing but still this error "G29 S1
                        Error: G29: Failed to load height map from file heightmap.csv: Could not find file '/opt/dsf/sd/sys/heightmap.csv'."
                        Running the latest fw, dsf, and dwc, don't know what else to do.
                        This Sh** is making me crazy, Dc42, Danal et al what do I need to do to get this to work?
                          luckyflyer
                          Here is my config.G if that helps.
                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Apr 28 2020 17:52:48 GMT-0600 (Mountain Daylight Time)
                          M550 P"Duet 3" ; set printer name
                          M667 S1 ; select CoreXY mode
                          M569 P0.2 S0 ; physical drive 0.2 goes backwards
                          M569 P0.3 S0 ; physical drive 0.3 goes backwards
                          M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
                          M92 X200.00 Y200.00 Z1600.00 E420.00 ; set steps per mm
                          M84 S30 ; Set idle timeout
                          M208 X0 Y10 Z0 S1 ; set axis minima
                          M208 X310 Y320 Z325 S0 ; set axis maxima
                          M574 X1 S1 P"!io1.in" ; configure active-high endstop for low end on X via pin io1.in
                          M574 Y1 S1 P"!io2.in" ; configure active-high endstop for low end on Y via pin io2.in
                          M574 Z1 S1 P"io3.in" ; configure active-low endstop for low end on Z via pin io3.in
                          M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
                          M558 P9 C"io4.in" H3 F180 R.250 T10000 ; set Z probe type to bltouch and the dive height + speeds
                          G31 P500 X16.5 Y-74 Z2 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                          M557 X15:290 Y15:290 S55 ; define mesh grid
                          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                          M143 H0 S110 ; set temperature limit for heater 0 to 110C
                          M307 H0 A236.8 C516.8 D3.0 V24.1 B0 ; disable bang-bang mode for the bed heater and set PWM limit
                          M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                          M143 H1 S260 ; set temperature limit for heater 1 to 260C
                          M307 H1 A445.5 C173.0 D5.5 V24.1 B0 ; disable bang-bang mode for heater and set PWM limit
                          M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                          M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                          M563 P0 S"E3D-V6" D0 H1 F0 ; define tool 0
                            Can you try this for me?
                            Go to the system folder in DWC and delete any heightmap file that exists.
                            Then home the printer as usualy.
                            Then in the Gcode console send M561 to clear any loaded bed transforms, then send G29 to generate a new heightmap.
                            luckyflyerundefined 1 Reply Last reply Reply Quote 0
                            • chrishammundefined
                              chrishamm administrators
                              The error message indicates that you never created a heightmap, so it cannot be loaded. That makes sense if any of the permissions of the virtual SD card (at /opt/dsf/sd) were messed up. The safest way for you to get going with the latest RC again is by downloading and flashing the latest experimental DuetPi image which can be found here: https://pkg.duet3d.com/testing/ Save you sys files (you can ZIP them all at once) and flash the image file via Win32DiskImager or Etcher. Once there, please upgrade to the latest DSF version on the Pi via
                              sudo apt-get update
                              sudo apt-get upgrade
                              Then restore your sys backup, reboot your system, run G29 without any arguments, and it should give you a heightmap file in 0:/sys. If it doesn't, post the output of G29 here.
                              Duet software engineer
                                Also post an M122 please.
                                  luckyflyer @Phaedrux
                                  @Phaedrux said in Trouble saving a manually probed mesh:
                                  Then home the printer as usual.
                                  When I click on sys folder nothing happens other than the sys folder disappearing and the words above which did say "System Directory" to now saying "System Directory > sys" Clicking on system directory brings the sys folder back into view and just "System Directory" above.
                                  I have ran M561 from dwc and got the confirmation that M561 was received. I then homed and ran G29 from the console in paneldue. G29 completed and I go to height map and this is what I get.
                                    luckyflyer
                                    So Now I'll do chrishamm's procedure.
                                      luckyflyer
                                      Hate to ask but how would I post the output of G29?
                                        A screen shot of the result?
                                        Or if it successfully made a heightmap.csv post that?
                                          luckyflyer
                                          Ok,thanks.
                                            luckyflyer
                                            Ok so I've downloaded Image_2020-04-28-DuetPi. I wrote it to the sd card with Win32Disk. I followed chrishamm's instructions exactly. Uploaded my saved files with dwc. ran g28 and g29 from paneldue came back to the pc and clicked on Height Map and got this.
                                            M122
                                            4/29/2020, 4:20:51 PM M122
                                            RepRapFirmware for Duet 3 MB6HC version 3.01-RC10 running on Duet 3 MB6HC v0.6 or 1.0
                                            Board ID: 08DJM-956L2-G43S8-6JTDA-3SN6M-1V0LGUsed output buffers: 1 of 40 (28 max)
                                            Static ram: 154572
                                            Dynamic ram: 161960 of which 52 recycled
                                            Exception stack ram used: 528
                                            Never used ram: 76104
                                            Tasks: NETWORK(ready,2076) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1424) CanClock(blocked,1432) TMC(blocked,72) MAIN(running,4468) IDLE(ready,80)
                                            Owned mutexes:
                                            Last reset 00:17:01 ago, cause: software
                                            Last software reset at 2020-04-29 23:03, reason: User, spinning module LinuxInterface, available RAM 76368 bytes (slot 3)
                                            Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                                            Error status: 0
                                            Free file entries: 10
                                            MCU temperature: min 45.7, current 45.9, max 46.0
                                            Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                            12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                                            Driver 0: standstill, reads 32691, writes 0 timeouts 0, SG min/max not available
                                            Driver 1: standstill, reads 32691, writes 0 timeouts 0, SG min/max not available
                                            Driver 2: standstill, reads 32691, writes 0 timeouts 0, SG min/max not available
                                            Driver 3: standstill, reads 32690, writes 0 timeouts 0, SG min/max not available
                                            Driver 4: standstill, reads 32690, writes 0 timeouts 0, SG min/max not available
                                            Driver 5: standstill, reads 32691, writes 0 timeouts 0, SG min/max not available
                                            Date/time: 2020-04-29 23:20:49
                                            Slowest loop: 3.62ms; fastest: 0.21ms
                                            === MainDDARing ===
                                            Scheduled moves: 56, completed moves: 56, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                            === AuxDDARing ===
                                            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                            Segments left: 0
                                            Movement lock held by null
                                            HTTP* is ready with "M122" in state(s) 0
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is idle in state(s) 0
                                            Aux is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            LCD is idle in state(s) 0
                                            SBC is idle in state(s) 0
                                            Daemon* is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 0.47ms; fastest: 0.01ms
                                            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                            HTTP sessions: 0 of 8
                                            • Ethernet -
                                              State: disabled
                                              Error counts: 0 0 0 0 0
                                              === CAN ===
                                              Messages sent 27, longest wait 0ms for type 0
                                              === Linux interface ===
                                              State: 0, failed transfers: 0
                                              Last transfer: 17ms ago
                                              RX/TX seq numbers: 33066/33068
                                              SPI underruns 0, overruns 0
                                              Number of disconnects: 1
                                              Buffer RX/TX: 0/0-0
                                            === Duet Control Server ===
                                            Duet Control Server v2.1.2.0
                                            Trigger:
                                            Finishing macro config.g, started by system
                                            Next stack level
                                            Code buffer space: 4096
                                            Full transfers per second: 33.04
