    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    24.6k
    • Danalundefined
      Danal
      Sure,
      http://danalspub.com/wp-content/uploads/2020/04/DuetLapse0427201124.mp4
      Also, note it is at a horrible angle to show a print... the head blocks it. Camera power cord was very short, and I didn't really care about the content of the vid, just did the script work or not.
        That's great. Can't wait to start using it.
        • Adrian52undefined
          Adrian52
          Great program, but I still have not got it quite right. I am currently using. /DuetLapse - duet 192.168.1.16 -camera pi -detect pause, with M25 and M400 added to each layer in gcode (easy to do in kisslicer). The problem is that two frames are taken, one when the head is moved away by pause.g, the second a bit later, when the print has resumed. I also get an error message on the console 'm24: cannot print because no file is selected'. It looks as though the m24 is being sent twice.
          I have edited my pause.g so that there is no z shift.
          • Danalundefined
            Danal
            I will take a look. Could you post a section of gcode that includes a pause, and the content of your pause.g and resume.g files, please?
            Adrian52undefined 1 Reply Last reply Reply Quote 0
            • Adrian52undefined
              Adrian52 @Danal
              @Danal Thanks. This is the gcode transition from layer 1 to 2:
               G1 X7.344 Y7.508 E0.06547
              G1 X6.523 Y8.329 E0.05469
              G1 X6.526 Y8.329 E0.00013
              G1 X7.303 Y8.327 E0.0366
              G1 X7.938 Y7.692 E0.04229
              G1 X8.319 Y7.312 E0.02538
              G1 X8.446 Y7.185 E0.00845
              ; trigger retract
              G10
              ; Blending Fan to Cool (21.9% blend)
              ; Blended Fan at 11%
              ; 'Destring/Wipe/Jump Path', 0.0 [feed mm/s], 20.0 [head mm/s]
              ; head speed 20.000000, filament speed 0.000000, preload 0.000000
              ; Prepare for End-Of-Layer
              ; time estimate: pre = 66.853355, post = 66.451721
              ; Dwell time remaining = -46.451717
              ; Post-layer lift
              G1 X8.446 Y7.185 Z0.4 E0 F3000
              ; END_LAYER_OBJECT z=0.200
              ; *** Every 1 Layers ***
              M25
              M400
              ; *** Estimate all extruders at 15.9 [s], Slowing 0.776x to 20.0 [s] ***
              ; BEGIN_LAYER_OBJECT z=0.400 z_thickness=0.200
              ; Fan set to Cool value 50%
              ; 'Loop Path', 1.8 [feed mm/s], 38.8 [head mm/s]
              G1 X9.155 Y-7.346 Z0.4 E0 F7800
              ; trigger prime
              G11
              ; head speed 38.793945, filament speed 1.827376, preload 0.000000
              G1 X9.155 Y-7.153 E0.00908 F2327.6
              G1 X9.155 Y-6.575 E0.02723
              G1 X9.155 Y-5.612 E0.04538
              G1 X9.155 Y-4.263 E0.06354
              G1 X9.155 Y-2.529 E0.08169
              G1 X9.155 Y-0.409 E0.09985
              G1 X9.155 Y4.986 E0.25415
              G1 X9.155 Y9.155 E0.19635
              G1 X-4.417 Y9.155 E0.63929
              G1 X-9.155 Y9.155 E0.22317
              ; Prepare for Perimeter
              G1 X-9.155 Y-9.155 E0.86246
              Pause.g
              M83					; relative extruder moves
              G1 E-3 F2000		; retract 3mm
              ;G91					; relative moves
              ;G1 Z20 F5000			; raise nozzle 20mm
              G90					; absolute moves
              G1 X-100 Y20 F10000		; move head out of the way of the print
              Resume.g
              ;G1 R1 Z2 F5000     ; move to 2mm above resume point
              G1 R1 F10000	; lower nozzle to resume point
              G1 E3 F1500     ; undo the retraction
              As you see I have commented out my z moves
              • Danalundefined
                Danal
                Thanks!
                Also.. If you pulled the script from github after Sat Apr 25 21:27:50 CDT, it no longer looks at Z. It looks at layers. Which works MUCH better.
                • Danalundefined
                  Danal
                  Aha!
                  M25 is not for pausing from within a file being printed. Please change these to M226.
                  • Adrian52undefined
                    Adrian52 @Danal
                    @Danal thanks very much - will give it a go.
                    • Adrian52undefined
                      Adrian52
                      Still getting the same behaviour with M226 in the gcode, with or without z move, using freshly pulled scripts.
                      • Danalundefined
                        Danal
                        Thanks for checking that, I will give this a look.
                        • Adrian52undefined
                          Adrian52
                          If you are using the raspberry pi camera, note that it has a default 5 second timeout. If you include -t 1 in the camera parameters, it works much more quickly. I have also started including -ex sports, which uses a fast shutter speed, and -mm matrix, which seems to give a better exposure; -n gives nopreview.
                          With the faster response, I now sometimes get more than one extra picture per layer - I got 547 for a 0.2 layer benchy, instead of 240.
                          • Danalundefined
                            Danal @Adrian52
                            @Adrian52 said in DuetLapse available for Alpha testing:
                            I will add those to the defaults
                            • Adrian52undefined
                              Adrian52
                              https://vimeo.com/415279225
                              Is an effort with pla. Used detect - pause, with M226 in the gcode at each layer change. The extra frames have to be deleted before running ffmpeg again
                              • arhiundefined
                                arhi
                                some, not so recent, rpi installation ...
                                root@octopi:~/DuetLapse# ./DuetLapse.py -h
                                Traceback (most recent call last):
                                  File "./DuetLapse.py", line 21, in <module>
                                    import DuetWebAPI as DWA
                                  File "/root/DuetLapse/DuetWebAPI.py", line 27
                                    URL=(f'{self._base_url}'+'/rr_status?type=1')
                                SyntaxError: invalid syntax
                                root@octopi:~/DuetLapse# python3
                                python3     python3.5   python3.5m  python3m
                                root@octopi:~/DuetLapse# python3 DuetLapse.py -h
                                  File "DuetLapse.py", line 21, in <module>
                                after rpi-update
                                root@octopi:~/DuetLapse# python3 --version
                                Python 3.5.3
                                root@octopi:~/DuetLapse# python3 ./DuetLapse.py -h
                                • arhiundefined
                                  arhi
                                  hm and just in case wget messed something up .. git clone of both repos
                                  root@octopi:~/DuetLapse/DuetLapse# PYTHONPATH=/root/DuetLapse/DuetWebAPI python3 DuetLapse.py  -h
                                    File "/root/DuetLapse/DuetWebAPI/DuetWebAPI.py", line 27
                                  I don't get it, I don't see that this line changed since forever?!
                                  looks like F-Strings are in from 3.6 only raspbian on pi3b+ latest comes with 3.5.3 😞
                                  • Danalundefined
                                    Danal
                                    @arhi said in DuetLapse available for Alpha testing:
                                    @arhi Very interesting, I don't get that, and that line is not a syntax error. Hmmm... Let me think of a way to pin this down.
                                    • arhiundefined
                                      arhi @Danal
                                      @Danal said in DuetLapse available for Alpha testing:
                                      F-strings are 3.6 python from what I read online, and stretch has max python 3.5.3 ... I'm now going to move to buster and see if it uses newer python
                                      • Danalundefined
                                        Danal @arhi
                                        Excellent detective work. I had no idea f was that recent.
                                        • arhiundefined
                                          arhi @Danal
                                          @Danal I don't use python at all so I don't have anything but what's normally there with the distro... so, troubles with buster too it comes with newer python but again
                                          root@octopi:~/DuetLapse/DuetLapse# apt-get install python3-numpy python-numpy
                                          Reading package lists... Done
                                          Building dependency tree
                                          Reading state information... Done
                                          python-numpy is already the newest version (1:1.16.2-1).
                                          python3-numpy is already the newest version (1:1.16.2-1).
                                          root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -h
                                          Python Library Module 'numpy' is required.
                                          Obtain via 'sudo python3 -m pip install numpy'
                                          root@octopi:~/DuetLapse/DuetLapse# python3 -m pip install numpy
                                          Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                                          Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.18.4)
                                          root@octopi:~/DuetLapse/DuetLapse# pip3 install numpy
                                          root@octopi:~/DuetLapse/DuetLapse# python3 --version
                                          Python 3.7.3
                                          root@octopi:~# python3
                                          Python 3.7.3 (default, Dec 20 2019, 18:57:59)
                                          [GCC 8.3.0] on linux
                                          Type "help", "copyright", "credits" or "license" for more information.
                                          >>> import subprocess
                                          >>> import sys
                                          >>> import argparse
                                          >>> import time
                                          >>> import numpy as np
                                            File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 24, in <module>
                                              from . import multiarray
                                            File "/usr/local/lib/python3.7/dist-packages/numpy/core/multiarray.py", line 14, in <module>
                                              from . import overrides
                                            File "/usr/local/lib/python3.7/dist-packages/numpy/core/overrides.py", line 7, in <module>
                                              from numpy.core._multiarray_umath import (
                                          ImportError: libf77blas.so.3: cannot open shared object file: No such file or directory
                                          During handling of the above exception, another exception occurred:
                                            File "<stdin>", line 1, in <module>
                                            File "/usr/local/lib/python3.7/dist-packages/numpy/__init__.py", line 142, in <module>
                                              from . import core
                                            File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 50, in <module>
                                              raise ImportError(msg)
                                          ImportError:
                                          IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
                                          Importing the numpy C-extensions failed. This error can happen for
                                          many reasons, often due to issues with your setup or how NumPy was
                                          installed.
                                          We have compiled some common reasons and troubleshooting tips at:
                                              https://numpy.org/devdocs/user/troubleshooting-importerror.html
                                          Please note and check the following:
                                            * The Python version is: Python3.7 from "/usr/bin/python3"
                                            * The NumPy version is: "1.18.4"
                                          and make sure that they are the versions you expect.
                                          Please carefully study the documentation linked above for further help.
                                          Original error was: libf77blas.so.3: cannot open shared object file: No such file or directory
                                          I love how consistent APT system is 😞
                                          • arhiundefined
                                            arhi
                                            apt-get install libatlas-base-dev
                                            solved the numpy error
