    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    21.8k
    • Adrian52undefined
      Adrian52
      If you are using the raspberry pi camera, note that it has a default 5 second timeout. If you include -t 1 in the camera parameters, it works much more quickly. I have also started including -ex sports, which uses a fast shutter speed, and -mm matrix, which seems to give a better exposure; -n gives nopreview.
      With the faster response, I now sometimes get more than one extra picture per layer - I got 547 for a 0.2 layer benchy, instead of 240.
      • Danalundefined
        Danal @Adrian52
        @Adrian52 said in DuetLapse available for Alpha testing:
        I will add those to the defaults
        • Adrian52undefined
          Adrian52
          https://vimeo.com/415279225
          Is an effort with pla. Used detect - pause, with M226 in the gcode at each layer change. The extra frames have to be deleted before running ffmpeg again
          • arhiundefined
            arhi
            some, not so recent, rpi installation ...
            root@octopi:~/DuetLapse# ./DuetLapse.py -h
            Traceback (most recent call last):
              File "./DuetLapse.py", line 21, in <module>
                import DuetWebAPI as DWA
              File "/root/DuetLapse/DuetWebAPI.py", line 27
                URL=(f'{self._base_url}'+'/rr_status?type=1')
            SyntaxError: invalid syntax
            root@octopi:~/DuetLapse# python3
            python3     python3.5   python3.5m  python3m
            root@octopi:~/DuetLapse# python3 DuetLapse.py -h
              File "DuetLapse.py", line 21, in <module>
            after rpi-update
            root@octopi:~/DuetLapse# python3 --version
            Python 3.5.3
            root@octopi:~/DuetLapse# python3 ./DuetLapse.py -h
            • arhiundefined
              arhi
              hm and just in case wget messed something up .. git clone of both repos
              root@octopi:~/DuetLapse/DuetLapse# PYTHONPATH=/root/DuetLapse/DuetWebAPI python3 DuetLapse.py  -h
                File "/root/DuetLapse/DuetWebAPI/DuetWebAPI.py", line 27
              I don't get it, I don't see that this line changed since forever?!
              looks like F-Strings are in from 3.6 only raspbian on pi3b+ latest comes with 3.5.3 😞
              • Danalundefined
                Danal
                @arhi said in DuetLapse available for Alpha testing:
                @arhi Very interesting, I don't get that, and that line is not a syntax error. Hmmm... Let me think of a way to pin this down.
                • arhiundefined
                  arhi @Danal
                  @Danal said in DuetLapse available for Alpha testing:
                  F-strings are 3.6 python from what I read online, and stretch has max python 3.5.3 ... I'm now going to move to buster and see if it uses newer python
                  • Danalundefined
                    Danal @arhi
                    Excellent detective work. I had no idea f was that recent.
                    • arhiundefined
                      arhi @Danal
                      @Danal I don't use python at all so I don't have anything but what's normally there with the distro... so, troubles with buster too it comes with newer python but again
                      root@octopi:~/DuetLapse/DuetLapse# apt-get install python3-numpy python-numpy
                      Reading package lists... Done
                      Building dependency tree
                      Reading state information... Done
                      python-numpy is already the newest version (1:1.16.2-1).
                      python3-numpy is already the newest version (1:1.16.2-1).
                      root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -h
                      Python Library Module 'numpy' is required.
                      Obtain via 'sudo python3 -m pip install numpy'
                      root@octopi:~/DuetLapse/DuetLapse# python3 -m pip install numpy
                      Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                      Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.18.4)
                      root@octopi:~/DuetLapse/DuetLapse# pip3 install numpy
                      root@octopi:~/DuetLapse/DuetLapse# python3 --version
                      Python 3.7.3
                      root@octopi:~# python3
                      Python 3.7.3 (default, Dec 20 2019, 18:57:59)
                      [GCC 8.3.0] on linux
                      Type "help", "copyright", "credits" or "license" for more information.
                      >>> import subprocess
                      >>> import sys
                      >>> import argparse
                      >>> import time
                      >>> import numpy as np
                        File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 24, in <module>
                          from . import multiarray
                        File "/usr/local/lib/python3.7/dist-packages/numpy/core/multiarray.py", line 14, in <module>
                          from . import overrides
                        File "/usr/local/lib/python3.7/dist-packages/numpy/core/overrides.py", line 7, in <module>
                          from numpy.core._multiarray_umath import (
                      ImportError: libf77blas.so.3: cannot open shared object file: No such file or directory
                      During handling of the above exception, another exception occurred:
                        File "<stdin>", line 1, in <module>
                        File "/usr/local/lib/python3.7/dist-packages/numpy/__init__.py", line 142, in <module>
                          from . import core
                        File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 50, in <module>
                          raise ImportError(msg)
                      ImportError:
                      IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
                      Importing the numpy C-extensions failed. This error can happen for
                      many reasons, often due to issues with your setup or how NumPy was
                      installed.
                      We have compiled some common reasons and troubleshooting tips at:
                          https://numpy.org/devdocs/user/troubleshooting-importerror.html
                      Please note and check the following:
                        * The Python version is: Python3.7 from "/usr/bin/python3"
                        * The NumPy version is: "1.18.4"
                      and make sure that they are the versions you expect.
                      Please carefully study the documentation linked above for further help.
                      Original error was: libf77blas.so.3: cannot open shared object file: No such file or directory
                      I love how consistent APT system is 😞
                      • arhiundefined
                        arhi
                        apt-get install libatlas-base-dev
                        solved the numpy error
                        • arhiundefined
                          arhi
                          one hint, I don't know python but might be cool to add argument to DuetLapse to point to DuetWebAPI library?
                          I added directly to code
                          diff --git a/DuetLapse.py b/DuetLapse.py
                          index eee4a51..5119d61 100755
                          --- a/DuetLapse.py
                          +++ b/DuetLapse.py
                          @@ -17,6 +17,9 @@ import subprocess
                           import sys
                           import argparse
                           import time
                          +sys.path.insert(1, "../DuetWebAPI/");
                           try:
                           except ImportError:
                          but would be cool to read that from the argument line 🙂 so we can normally git pull changes and not need to copy stuff over each other 😄 especially as python is ignoring symlinks
                          • arhiundefined
                            arhi
                            @Danal you tested this with 3.01RC12? and DWC 2.1.7?
                            root@octopi:~/DuetLapse/DuetLapse# cd ../DuetWebAPI/
                            root@octopi:~/DuetLapse/DuetWebAPI# git pull
                            Already up to date.
                            root@octopi:~/DuetLapse/DuetWebAPI# cd -
                            /root/DuetLapse/DuetLapse
                            root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -duet ender5.local.lan -camera usb -detect layer -pause no
                            Attempting to connect to printer at ender5.local.lan
                            http://ender5.local.lan  does not appear to be a RRF2 or RRF3 printer
                            Device at ender5.local.lan either did not respond or is not a Duet V2 or V3 printer.
                            root@octopi:~/DuetLapse/DuetLapse# fping ender5.local.lan
                            ender5.local.lan is alive
                            root@octopi:~/DuetLapse/DuetLapse# telnet ender5.local.lan
                            Trying 192.168.89.246...
                            Connected to ender5.local.lan.
                            Escape character is '^]'.
                            M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC12 running on Duet Ethernet 1.02 or later
                            telnet> c
                            Connection closed.
                            • arhiundefined
                              arhi
                              this last part was on me - works ok now 🙂
                              • arhiundefined
                                arhi
                                @Danal I don't know python so this should probbly be done better by somehow defining parameter to onePhoto() not mandatory, or if there's already a global with this info but this works awesome for me so if you like you integrate 😄
                                root@octopi:~/DuetLapse/DuetLapse# git diff
                                old mode 100755
                                new mode 100644
                                index eee4a51..1539257
                                --- a/DuetLapse.py
                                +++ b/DuetLapse.py
                                 import sys
                                 import argparse
                                 import time
                                 try:
                                 except ImportError:
                                @@ -204,11 +207,15 @@ def unPause():
                                         printer.gCode('M24')
                                         alreadyPaused = False
                                -def onePhoto():
                                +def onePhoto(zl):
                                     global frame
                                     frame += 1
                                     s="{0:08d}".format(int(np.around(frame)))
                                -    fn = '/tmp/DuetLapse/IMG'+s+'.jpeg'
                                +    if (zl > -1):
                                +      zlayer="{0:8d}".format(int(zl))
                                +      fn = '--title "Layer '+zlayer+'" /tmp/DuetLapse/IMG'+s+'.jpeg'
                                +    else:
                                +      fn = ' /tmp/DuetLapse/IMG'+s+'.jpeg'
                                     if ('usb' in camera):
                                         if (camparms == ''):
                                @@ -226,6 +233,7 @@ def onePhoto():
                                         else:
                                             cmd = 'wget '+camparms+' -O '+fn+' "'+weburl+'" '
                                +    print(cmd)
                                     subprocess.call(cmd, shell=True)
                                     global timePriorPhoto
                                     timePriorPhoto = time.time()
                                @@ -240,20 +248,20 @@ def oneInterval():
                                             # Z changed, take a picture.
                                             checkForcePause()
                                             print('Capturing frame {0:5d} at X{1:4.2f} Y{2:4.2f} Z{3:4.2f} Layer {4:d}'.format(int(np.around(frame)),printer.getCoords()['X'],printer.getCoords()['Y'],printer.getCoords()['Z'],zn))
                                -            onePhoto()
                                +            onePhoto(zn)
                                         zo = zn
                                     elap = (time.time() - timePriorPhoto)
                                     if ((seconds) and (seconds < elap)):
                                         checkForcePause()
                                         print('Capturing frame {0:5d} after {1:4.2f} seconds elapsed.'.format(int(np.around(frame)),elap))
                                -        onePhoto()
                                +        onePhoto( -1 )
                                     if ('pause' in detect):
                                         if ('paused' in printer.getStatus()):
                                             global alreadyPaused
                                             alreadyPaused = True
                                             print('Pause Detected, capturing frame {0:5d}'.format(int(np.around(frame)),elap))
                                -            onePhoto()
                                +            onePhoto( -1)
                                         unPause()
                                 def postProcess():
                                (print(cmd) was just me debuging, that's not needed)
                                • Danalundefined
                                  Danal
                                  Python honors symlinks, that is exactly how I'm keeping one central copy of DuetWebAPI and not copying it around to each DuetLapse, TAMV, etc, etc. as I develop this stuff. If you want it not in the current directory, and/or don't want to use symlinks, then properly put it in Python's path please.
                                  By the way, git clone will NOT update things, 'wget' has all kinds of edge cases, I haven't found a really bullet proof way to distribute scripts from github (besides set up a package server. Which I am reluctant to do, and even that requires entries in /etc directories on user endpoints).
                                  Anyway, symlinks work fine, I'm curious why yours don't.
                                  ln -s ../DuetWebAPI/DuetWebAPI.py DuetWebAPI.py right?
                                  Screenshot to get colors:
                                  arhiundefined 1 Reply Last reply Reply Quote 1
                                  • arhiundefined
                                    arhi @Danal
                                    kill me if I know why but it didn't work .. I'll try again later but this work as is now so ...
                                    Need to try that again, when I did with PYTHONPATH=/root/DuetLapse/DuetWebAPI python3 DuetLapse.py it was finding api ok but failed something else, but maybe now that I fixed the other thing that will work, will try 🙂
                                    of course, git pull does ( git checkout or stash first if files are modified 😄 like they are now)
                                    git clone
                                    git pull
                                    git checkout/stash
                                    works awesome, the only issue I need to handle is this path for libs so it knows how to find api, will retest this but even as is it's not a biggy
                                    hahaha retested the symthing now, it works, the %^$#*&^#
                                    PYTHONPATH=/root/DuetLapse/DuetWebAPI python3 DuetLapse.py -h works too, I'll use this way .. the problem was obviously the numpy or whatever is that thing called...
                                    anyhow, these are irrelevant parts of that diff 🙂 .. what about that change in the onePhoto() ? makes sense?
                                    • arhiundefined
                                      arhi
                                      • Danalundefined
                                        Danal @arhi
                                        Don't you just love things like that!
                                        anyhow, these are irrelevant parts of that diff .. what about that change in the onePhoto() ? makes sense?
                                        Makes perfect sense, I just need time to look at it... probably next day or two.
                                        • arhiundefined
                                          arhi @Danal
                                          I'm not 40 any more, doing things between 3 and 5am obviously need to be doublechecked 😄 😄 😄
                                          • Danalundefined
                                            Danal @Adrian52
                                            Great program, but I still have not got it quite right. I am currently using. /DuetLapse - duet 192.168.1.16 -camera pi -detect pause, with M25 and M400 added to each layer in gcode (easy to do in kisslicer). The problem is that two frames are taken, one when the head is moved away by pause.g, the second a bit later, when the print has resumed. I also get an error message on the console 'm24: cannot print because no file is selected'. It looks as though the m24 is being sent twice.
                                            I have edited my pause.g so that there is no z shift.
                                            Just pushed changes to the detect pause logic that should eliminate this. It has been tested to ensure no syntax errors, but has not been run through a print.
                                            Adrian52undefined 1 Reply Last reply Reply Quote 0
