    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    24.4k
    • Adrian52undefined
      Adrian52 @Danal
      @Danal Thanks. This is the gcode transition from layer 1 to 2:
       G1 X7.344 Y7.508 E0.06547
      G1 X6.523 Y8.329 E0.05469
      G1 X6.526 Y8.329 E0.00013
      G1 X7.303 Y8.327 E0.0366
      G1 X7.938 Y7.692 E0.04229
      G1 X8.319 Y7.312 E0.02538
      G1 X8.446 Y7.185 E0.00845
      ; trigger retract
      G10
      ; Blending Fan to Cool (21.9% blend)
      ; Blended Fan at 11%
      ; 'Destring/Wipe/Jump Path', 0.0 [feed mm/s], 20.0 [head mm/s]
      ; head speed 20.000000, filament speed 0.000000, preload 0.000000
      ; Prepare for End-Of-Layer
      ; time estimate: pre = 66.853355, post = 66.451721
      ; Dwell time remaining = -46.451717
      ; Post-layer lift
      G1 X8.446 Y7.185 Z0.4 E0 F3000
      ; END_LAYER_OBJECT z=0.200
      ; *** Every 1 Layers ***
      M25
      M400
      ; *** Estimate all extruders at 15.9 [s], Slowing 0.776x to 20.0 [s] ***
      ; BEGIN_LAYER_OBJECT z=0.400 z_thickness=0.200
      ; Fan set to Cool value 50%
      ; 'Loop Path', 1.8 [feed mm/s], 38.8 [head mm/s]
      G1 X9.155 Y-7.346 Z0.4 E0 F7800
      ; trigger prime
      G11
      ; head speed 38.793945, filament speed 1.827376, preload 0.000000
      G1 X9.155 Y-7.153 E0.00908 F2327.6
      G1 X9.155 Y-6.575 E0.02723
      G1 X9.155 Y-5.612 E0.04538
      G1 X9.155 Y-4.263 E0.06354
      G1 X9.155 Y-2.529 E0.08169
      G1 X9.155 Y-0.409 E0.09985
      G1 X9.155 Y4.986 E0.25415
      G1 X9.155 Y9.155 E0.19635
      G1 X-4.417 Y9.155 E0.63929
      G1 X-9.155 Y9.155 E0.22317
      ; Prepare for Perimeter
      G1 X-9.155 Y-9.155 E0.86246
      Pause.g
      M83					; relative extruder moves
      G1 E-3 F2000		; retract 3mm
      ;G91					; relative moves
      ;G1 Z20 F5000			; raise nozzle 20mm
      G90					; absolute moves
      G1 X-100 Y20 F10000		; move head out of the way of the print
      Resume.g
      ;G1 R1 Z2 F5000     ; move to 2mm above resume point
      G1 R1 F10000	; lower nozzle to resume point
      G1 E3 F1500     ; undo the retraction
      As you see I have commented out my z moves
      • Danalundefined
        Danal
        Thanks!
        Also.. If you pulled the script from github after Sat Apr 25 21:27:50 CDT, it no longer looks at Z. It looks at layers. Which works MUCH better.
        • Danalundefined
          Danal
          Aha!
          M25 is not for pausing from within a file being printed. Please change these to M226.
          Adrian52undefined 1 Reply Last reply Reply Quote 0
          • Adrian52undefined
            Adrian52 @Danal
            @Danal thanks very much - will give it a go.
            • Adrian52undefined
              Adrian52
              Still getting the same behaviour with M226 in the gcode, with or without z move, using freshly pulled scripts.
              • Danalundefined
                Danal
                Thanks for checking that, I will give this a look.
                • Adrian52undefined
                  Adrian52
                  If you are using the raspberry pi camera, note that it has a default 5 second timeout. If you include -t 1 in the camera parameters, it works much more quickly. I have also started including -ex sports, which uses a fast shutter speed, and -mm matrix, which seems to give a better exposure; -n gives nopreview.
                  With the faster response, I now sometimes get more than one extra picture per layer - I got 547 for a 0.2 layer benchy, instead of 240.
                  • Danalundefined
                    Danal @Adrian52
                    @Adrian52 said in DuetLapse available for Alpha testing:
                    I will add those to the defaults
                    • Adrian52undefined
                      Adrian52
                      https://vimeo.com/415279225
                      Is an effort with pla. Used detect - pause, with M226 in the gcode at each layer change. The extra frames have to be deleted before running ffmpeg again
                      • arhiundefined
                        arhi
                        some, not so recent, rpi installation ...
                        root@octopi:~/DuetLapse# ./DuetLapse.py -h
                        Traceback (most recent call last):
                          File "./DuetLapse.py", line 21, in <module>
                            import DuetWebAPI as DWA
                          File "/root/DuetLapse/DuetWebAPI.py", line 27
                            URL=(f'{self._base_url}'+'/rr_status?type=1')
                        SyntaxError: invalid syntax
                        root@octopi:~/DuetLapse# python3
                        python3     python3.5   python3.5m  python3m
                        root@octopi:~/DuetLapse# python3 DuetLapse.py -h
                          File "DuetLapse.py", line 21, in <module>
                        after rpi-update
                        root@octopi:~/DuetLapse# python3 --version
                        Python 3.5.3
                        root@octopi:~/DuetLapse# python3 ./DuetLapse.py -h
                        • arhiundefined
                          arhi
                          hm and just in case wget messed something up .. git clone of both repos
                          root@octopi:~/DuetLapse/DuetLapse# PYTHONPATH=/root/DuetLapse/DuetWebAPI python3 DuetLapse.py  -h
                            File "/root/DuetLapse/DuetWebAPI/DuetWebAPI.py", line 27
                          I don't get it, I don't see that this line changed since forever?!
                          looks like F-Strings are in from 3.6 only raspbian on pi3b+ latest comes with 3.5.3 😞
                          • Danalundefined
                            Danal
                            @arhi said in DuetLapse available for Alpha testing:
                            @arhi Very interesting, I don't get that, and that line is not a syntax error. Hmmm... Let me think of a way to pin this down.
                            • arhiundefined
                              arhi @Danal
                              @Danal said in DuetLapse available for Alpha testing:
                              F-strings are 3.6 python from what I read online, and stretch has max python 3.5.3 ... I'm now going to move to buster and see if it uses newer python
                              • Danalundefined
                                Danal @arhi
                                Excellent detective work. I had no idea f was that recent.
                                • arhiundefined
                                  arhi @Danal
                                  @Danal I don't use python at all so I don't have anything but what's normally there with the distro... so, troubles with buster too it comes with newer python but again
                                  root@octopi:~/DuetLapse/DuetLapse# apt-get install python3-numpy python-numpy
                                  Reading package lists... Done
                                  Building dependency tree
                                  Reading state information... Done
                                  python-numpy is already the newest version (1:1.16.2-1).
                                  python3-numpy is already the newest version (1:1.16.2-1).
                                  root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -h
                                  Python Library Module 'numpy' is required.
                                  Obtain via 'sudo python3 -m pip install numpy'
                                  root@octopi:~/DuetLapse/DuetLapse# python3 -m pip install numpy
                                  Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                                  Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.18.4)
                                  root@octopi:~/DuetLapse/DuetLapse# pip3 install numpy
                                  root@octopi:~/DuetLapse/DuetLapse# python3 --version
                                  Python 3.7.3
                                  root@octopi:~# python3
                                  Python 3.7.3 (default, Dec 20 2019, 18:57:59)
                                  [GCC 8.3.0] on linux
                                  Type "help", "copyright", "credits" or "license" for more information.
                                  >>> import subprocess
                                  >>> import sys
                                  >>> import argparse
                                  >>> import time
                                  >>> import numpy as np
                                    File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 24, in <module>
                                      from . import multiarray
                                    File "/usr/local/lib/python3.7/dist-packages/numpy/core/multiarray.py", line 14, in <module>
                                      from . import overrides
                                    File "/usr/local/lib/python3.7/dist-packages/numpy/core/overrides.py", line 7, in <module>
                                      from numpy.core._multiarray_umath import (
                                  ImportError: libf77blas.so.3: cannot open shared object file: No such file or directory
                                  During handling of the above exception, another exception occurred:
                                    File "<stdin>", line 1, in <module>
                                    File "/usr/local/lib/python3.7/dist-packages/numpy/__init__.py", line 142, in <module>
                                      from . import core
                                    File "/usr/local/lib/python3.7/dist-packages/numpy/core/__init__.py", line 50, in <module>
                                      raise ImportError(msg)
                                  ImportError:
                                  IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
                                  Importing the numpy C-extensions failed. This error can happen for
                                  many reasons, often due to issues with your setup or how NumPy was
                                  installed.
                                  We have compiled some common reasons and troubleshooting tips at:
                                      https://numpy.org/devdocs/user/troubleshooting-importerror.html
                                  Please note and check the following:
                                    * The Python version is: Python3.7 from "/usr/bin/python3"
                                    * The NumPy version is: "1.18.4"
                                  and make sure that they are the versions you expect.
                                  Please carefully study the documentation linked above for further help.
                                  Original error was: libf77blas.so.3: cannot open shared object file: No such file or directory
                                  I love how consistent APT system is 😞
                                  • arhiundefined
                                    arhi
                                    apt-get install libatlas-base-dev
                                    solved the numpy error
                                    • arhiundefined
                                      arhi
                                      one hint, I don't know python but might be cool to add argument to DuetLapse to point to DuetWebAPI library?
                                      I added directly to code
                                      diff --git a/DuetLapse.py b/DuetLapse.py
                                      index eee4a51..5119d61 100755
                                      --- a/DuetLapse.py
                                      +++ b/DuetLapse.py
                                      @@ -17,6 +17,9 @@ import subprocess
                                       import sys
                                       import argparse
                                       import time
                                      +sys.path.insert(1, "../DuetWebAPI/");
                                       try:
                                       except ImportError:
                                      but would be cool to read that from the argument line 🙂 so we can normally git pull changes and not need to copy stuff over each other 😄 especially as python is ignoring symlinks
                                      • arhiundefined
                                        arhi
                                        @Danal you tested this with 3.01RC12? and DWC 2.1.7?
                                        root@octopi:~/DuetLapse/DuetLapse# cd ../DuetWebAPI/
                                        root@octopi:~/DuetLapse/DuetWebAPI# git pull
                                        Already up to date.
                                        root@octopi:~/DuetLapse/DuetWebAPI# cd -
                                        /root/DuetLapse/DuetLapse
                                        root@octopi:~/DuetLapse/DuetLapse# python3 DuetLapse.py -duet ender5.local.lan -camera usb -detect layer -pause no
                                        Attempting to connect to printer at ender5.local.lan
                                        http://ender5.local.lan  does not appear to be a RRF2 or RRF3 printer
                                        Device at ender5.local.lan either did not respond or is not a Duet V2 or V3 printer.
                                        root@octopi:~/DuetLapse/DuetLapse# fping ender5.local.lan
                                        ender5.local.lan is alive
                                        root@octopi:~/DuetLapse/DuetLapse# telnet ender5.local.lan
                                        Trying 192.168.89.246...
                                        Connected to ender5.local.lan.
                                        Escape character is '^]'.
                                        M122
                                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC12 running on Duet Ethernet 1.02 or later
                                        telnet> c
                                        Connection closed.
                                        • arhiundefined
                                          arhi
                                          this last part was on me - works ok now 🙂
                                          • arhiundefined
                                            arhi
                                            @Danal I don't know python so this should probbly be done better by somehow defining parameter to onePhoto() not mandatory, or if there's already a global with this info but this works awesome for me so if you like you integrate 😄
                                            root@octopi:~/DuetLapse/DuetLapse# git diff
                                            old mode 100755
                                            new mode 100644
                                            index eee4a51..1539257
                                            --- a/DuetLapse.py
                                            +++ b/DuetLapse.py
                                             import sys
                                             import argparse
                                             import time
                                             try:
                                             except ImportError:
                                            @@ -204,11 +207,15 @@ def unPause():
                                                     printer.gCode('M24')
                                                     alreadyPaused = False
                                            -def onePhoto():
                                            +def onePhoto(zl):
                                                 global frame
                                                 frame += 1
                                                 s="{0:08d}".format(int(np.around(frame)))
                                            -    fn = '/tmp/DuetLapse/IMG'+s+'.jpeg'
                                            +    if (zl > -1):
                                            +      zlayer="{0:8d}".format(int(zl))
                                            +      fn = '--title "Layer '+zlayer+'" /tmp/DuetLapse/IMG'+s+'.jpeg'
                                            +    else:
                                            +      fn = ' /tmp/DuetLapse/IMG'+s+'.jpeg'
                                                 if ('usb' in camera):
                                                     if (camparms == ''):
                                            @@ -226,6 +233,7 @@ def onePhoto():
                                                     else:
                                                         cmd = 'wget '+camparms+' -O '+fn+' "'+weburl+'" '
                                            +    print(cmd)
                                                 subprocess.call(cmd, shell=True)
                                                 global timePriorPhoto
                                                 timePriorPhoto = time.time()
                                            @@ -240,20 +248,20 @@ def oneInterval():
                                                         # Z changed, take a picture.
                                                         checkForcePause()
                                                         print('Capturing frame {0:5d} at X{1:4.2f} Y{2:4.2f} Z{3:4.2f} Layer {4:d}'.format(int(np.around(frame)),printer.getCoords()['X'],printer.getCoords()['Y'],printer.getCoords()['Z'],zn))
                                            -            onePhoto()
                                            +            onePhoto(zn)
                                                     zo = zn
                                                 elap = (time.time() - timePriorPhoto)
                                                 if ((seconds) and (seconds < elap)):
                                                     checkForcePause()
                                                     print('Capturing frame {0:5d} after {1:4.2f} seconds elapsed.'.format(int(np.around(frame)),elap))
                                            -        onePhoto()
                                            +        onePhoto( -1 )
                                                 if ('pause' in detect):
                                                     if ('paused' in printer.getStatus()):
                                                         global alreadyPaused
                                                         alreadyPaused = True
                                                         print('Pause Detected, capturing frame {0:5d}'.format(int(np.around(frame)),elap))
                                            -            onePhoto()
                                            +            onePhoto( -1)
                                                     unPause()
                                             def postProcess():
                                            (print(cmd) was just me debuging, that's not needed)
