    Help with M669 etc
    1.5k
    • luckyflyerundefined
      luckyflyer @Nuramori
      @Nuramori said in Help with M669 etc:
      It sounds like what you want, is how I have mine running, which is a BLV cube (CoreXY variant). It has the y endstop at the left rear. 0,0 is still at the front left. Does this match your intent? If so I can share my config.g file.
      So when you home does you h.e. move to the left front? I would like for my h.e. to home to the left rear, if yours does that then yes I would like to see your config.g.
      • Nuramoriundefined
        Nuramori
        When I perform homing on the axis’, the x homes to the left edge, the y homes to the rear where the endstop is.
        • Nuramoriundefined
          Nuramori
          Here's my config.g file. I am using a toolboard, so there's a bit more than usual complexity I suppose, but I think where you're going to find what you're looking for is the section for "ENDSTOPS", where the y endstop is defined by the maximum position rather than the min. 0 on the y axis is then defined by the combination of the maxima y position and set distance to zero (in my case, 320). To reiterate, my x endstop is located on the left edge, and my y endstop is located at the left rear.
          ; Configuration file for Duet3 (firmware version 3.01 RC11)
          ; --------------- Pin/connection Mapping Legend -------------------
          ; 0.out0      - Bed heater
          ; 0.out1
          ; 0.out2
          ; 0.out3
          ; 0.out4      - Radiator cooling fan - WC heatsink
          ; 0.out5
          ; 0.out6
          ; 0.out7
          ; 0.out8
          ; 0.out9      - Duet board cooling fan
          ; 0.out4.tach - Radiator cooling fan rpm wire - WC heatsink
          ; 0.out5.tach
          ; 0.out6.tach
          ; 0.io0.in
          ; 0.io1.in    - Emergency stop switch
          ; 0.io2.in    - Y max active low endstop switch
          ; 0.io3.in
          ; 0.io4.in
          ; 0.io5.in
          ; 0.io6.in
          ; 0.io7.in
          ; 0.io8.in
          ; 0.io0.out
          ; 0.io1.out
          ; 0.io2.out
          ; 0.io3.out
          ; 0.io4.out
          ; 0.io5.out
          ; 0.io6.out
          ; 0.io7.out
          ; 0.io8.out
          ; 0.servo, out10 (only on v0.5, not on v0.6)
          ; 0.pson
          ; 0.spi.cs0
          ; 0.spi.cs1
          ; 0.spi.cs2
          ; 0.spi.cs3
          ; 0.temp0      - Bed Thermistor
          ; 0.temp1
          ; 0.temp2
          ; 0.temp3      - Coolant Temp Sensor
          ; 0.mcu-temp   - MCU sensor
          ;----------Toolboard 1 (CAN ID#20)
          ; 20.out0      - Hotend Heater
          ; 20.out1
          ; 20.out2      - Parts cooler on printhead
          ; 20.out1.tach
          ; 20.out2.tach
          ; 20.io0.in    - Z probe type to bltouch current - Piezo future
          ; 20.io1.in    - X min active low endstop switch
          ; 20.io0.out   - GPIO port 0 on toolboard io0, servo mode - BLTouch Z-Probe
          ; 20.temp0     - Extruder Thermistor
          ; 20.temp1
          ; 20.button0
          ; 20.button1
          G4 P2000                          ; Hold your Horses.
          G90                               ; send absolute coordinates...
          M83                               ; ...but relative extruder moves
          G21                               ; Set units to Millimeters
          M550 P"DUET3"                     ; set printer name
          M575 P1 S1 B57600                 ; Set things up for the PanelDue
          M584 X0.3 Y0.2 Z0.0:0.1:0.4 E20.0 ; set drive mapping to each axis
          M669 K1                           ; Select CoreXY mode - New format
          M552 S1                           ; enable network
          ; M552 P192.168.3.120             ; Static IP Address
          M586 P0 S1                        ; enable HTTP
          M586 P1 S0                        ; disable FTP
          M586 P2 S0                        ; disable Telnet
          M569 P0.0 S0                      ; physical drive 0 goes backwards - Z Axis Left (1)
          M569 P0.1 S0                      ; physical drive 1 goes backwards - Z Axis Right Back (2)
          M569 P0.2 S0 D3                   ; physical drive 2 goes backwards - Y Axis, activate Stealthchop
          M569 P0.3 S0 D3                   ; physical drive 3 goes backwards - X Axis, activate Stealthchop
          M569 P0.4 S0                      ; physical drive 4 goes backwards - Z Axis Right Front (3)
          M569 P20.0 S1 D3                  ; physical drive 5 goes forwards - Extruder 1
          ; Set up three Z-axis location
          M671 X-42.5:390.9:390.9 Y172.5:291.5:49.5 S5 ; leadscrews at 1 - left, 2 - rear right and 3 - front right
          M92 X199.27 Y199.27 Z397.23 E2700          ; set steps per mm
          M350 X16 Y16 Z16 E16 I1                    ; configure micro-stepping with interpolation
          M566 X800.00 Y800.00 Z400.00 E240.00       ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z2500.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X6000.00 Y6000.00 Z800.00 E800.00     ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800 I30            ; set motor currents (mA) and motor idle factor in percent*100
          M84 S30                                    ; Set idle timeout
          M208 X0 Y0 Z0 S1                           ; set axis minima
          M208 X320 Y320 Z350 S0                     ; set axis maxima
          M574 X1 S1 P"20.io1.in"                    ; X min active high endstop switch
          M574 Y2 S1 P"0.io2.in"                     ; Y max active high endstop switch
          ; Z-Probe - BLTouch - *CURRENT*
          M574 Z1 S2                                 ; set endstops controlled by probe
          M558 P9 C"^20.io0.in" H5 F2000 T12000      ; set Z probe type to bltouch and the dive height + speeds (bltouch NEEDS pullup)
          ; G31 P100 X28.5 Y-5 Z2.65                 ; set Z probe trigger value, offset and trigger height - 0.25MM NOZZLE
          G31 P100 X-29.99 Y1.04 Z0.55               ; set Z probe trigger value, offset and trigger height - 0.40MM NOZZLE
          ; Z-Probe - PIEZO - *FUTURE*
          ; M574 Z1 S2                               ; set endstops controlled by probe
          ; M558 P8 C"20.io0.in" H10 F2000 T20000    ; set Z probe type to PIEZO and the dive height + speeds
          ; G31 P100 X0 Y0 Z-0.1                     ; set Z probe trigger value, offset and trigger height
          G30                                        ; Probe Z
          ; Configure Heaters and Sensors
          M308 S0 P"0.temp0" Y"thermistor" T100000 B3950          ; Configure bed temperature sensor
          M950 H0 C"0.out0" T0                                    ; Define heater 0 (bed heater) - bed_heat pin and Temp Sensor 0
          M143 H0 S120 A2                                         ; set temperature limit for heater 0 to 120c
          M140 H0                                                 ; Map heated bed to heater 0
          M308 S1 P"20.temp0" Y"thermistor" T100000 B3950         ; Configure extruder 1 temperature sensor
          M950 H1 C"20.out0" T1                                   ; Define heater 1 (hot-end E0) to use the "20.out0" pin and Temp Sensor 1
          M143 H1 S265 A2                                         ; set temperature limit for heater 1 to 265C
          M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board"           ; Configure MCU sensor
          M308 S3 P"temp3" Y"thermistor" T10000 B3988 A"Coolant"  ; Configure coolant sensor
          ; Configure Fans
          M950 F0 C"20.out2" Q100                 ; Define Fan_0 for use - Parts Cooler on Printhead - 4010 fan
          M950 F1 C"!0.out4+^0.out4.tach" Q25000  ; Define Fan_1 for use - Radiator cooling - WC heatsink. - PWM fan
          M950 F2 C"0.out9" Q25000                ; Define Fan_2 for use - Duet board cooling fan
          M950 S0 C"20.io0.out"                   ; Define GPIO port 0 on IO0, servo mode - BLTouch Z-Probe - *CURRENT*
          M950 J0 C"^!0.io1.in"                   ; Input 0 uses 0.io1.in pin, pullup enabled
          M106 P0 S0                          ; set fan 0. Parts Cooler on Printhead
          M106 P1 T25:40 H2                   ; Set fan 1. Manages Radiator fan for water-cooled loop.
          M106 P2 T35:45 H2                   ; Set fan 2. Manages Duet board fan.
          ;Set PID values
          M307 H0 A289.6 C634.8 D0.9 V23.3 B0 ; disable bang-bang mode for the bed heater and set PWM limit
          M307 H1 A561.8 C236.5 D5.8 V23.3 B0 ; disable bang-bang mode for the extruder heater and set PWM limit
          ; Pressure Advance
          M572 D0 S0.3                        ; Set pressure advance to offset elasticity
          M563 P0 S"Extruder 1" D0 H1 F0      ; define tool 0. Fan 0 operates with an active hot-end
          G10 P0 X0 Y0 Z0 R0 S0               ; set tool 0 axis offsets active and standby temperatures to 0C
          ; Emergency Stop
          M574 S1 P"^!0.io1.in"               ; Define Emergency endstop - emergency stop switch condition
          M581 P0 S1 T0                       ; Define action to be taken with activation of emergency stop switch
          T0                                  ; select first tool
            luckyflyer
            Thanks I appreciate that.
              luckyflyer
              Getting late here, I'll check it out tomorrow.
              Nuramoriundefined 1 Reply Last reply Reply Quote 0
              • Nuramoriundefined
                Nuramori @luckyflyer
                @luckyflyer said in Help with M669 etc:
                Sure. Pay special attention in mine the value of the y endstop configuration. It’s a “Y2” not Y1 as in yours. That is telling the duet that the y endstop is a MAX position for the Cartesian coordinate layout. It will still HOME at the endstop at the back - I think you’re mistaking homing as also being 0,0, but it doesn’t have to be.
                  The above configuration works except that the prints are mirrored. I then tried with drive 0 going to the right motor and drive 1 going to the left and putting the y endstop at the front of the printer. It now homes at left front and the prints are normal, not mirrored. However I prefer home to be left rear. I'm pretty sure that this can be configured with the right combination of M669, M569 and M574. I have tried several combinations but have not got it to work. Can someone help me out with this?
                  You need to swap the X and Y motor connections over, either physically (as you already tried) or in the M584 command, so that Ymin is towards you and Ymax is away from you. Then change your M574 Y command and homey.g file to home to max Y instead of min Y. Also change homeall.g to home Y to max.
                  luckyflyerundefined 1 Reply Last reply Reply Quote 0
                    luckyflyer @dc42
                    But is it possible to have Ymin away from the back and Ymax towards the front, that is what I want.
                    Also Xmin to my left and max going right.
                    This
                    *----------------->X
                    V
                    Y
                    Instead of this
                    Y
                    *---------------->X
                    Or is this not possible because of a software limitation?
                      luckyflyer
                      The instructions say this,
                      When an axis is homed to a low end (minimum) homing switch, the axis is assumed to be at the lower position limit. When it is homed to a high end (maximum) homing switch, it is assumed to be at the upper position limit. Therefore, changing the position limits in the M208 command will move the origin.
                      I want origin 0.0 to be left rear which would mean that a + movement on the X axes would move the head to the printers left, to the user standing in front of the printer, his right. Also with a + Y command the head would move toward the front of the printer, toward the user.
                      My motor mapping is Driver 0 = right rear motor = Y, Driver 1= left rear =X, I have changed this from default with M584.
                      So is my logic flawed on the above points? If not then we proceed to setting the motor directions to achieve the above goal. This is where I start to have problems. I can get 1 axes to go in the correct direction but not the other, change motor direction and the axes change is reversed.
                        luckyflyer
                        Been playing with this all day but it's the classic 1 step forward 2 steps back. here is where I'm at . Note mapping changes from above post.
                        M669 K1 ; select CoreXY mode
                        M569 P0.2 S0 ; physical drive 0.2 goes backwards
                        M569 P0.3 S0 ; physical drive 0.3 goes backwards
                        M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping, driver 0 = X driver 1 = Y driver 2 = Z driver 3 = Extruder
                        The X motor is left rear, Y motor = Right.
                        M208 X0 Y0 Z-.2 S1 ; set axis minima
                        M208 X310 Y310 Z325 S0 ; set axis maxima
                        M574 X1 S1 P"!io1.in" ; configure active-low endstop for low end on X via pin io1.in
                        M574 Y1 S1 P"!io2.in" ; configure active-low endstop for high end on Y via pin io2.in
                        M574 Z1 S1 P"io3.in"
                        My Y end stop is at printer rear (preferred location)
                        All of the homes work correctly, using - (negative) movement numbers. All motor movements are correct as per this guide https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
                        All console movements are correct.
                        But it is still mirrored.
                        • Nuramoriundefined
                          Nuramori
                          I’d change your y endstop from y1 to y2
                          • OwenDundefined
                            OwenD
                            I'll ask the dumb question...
                            There's no chance that your slicer is mirroring the model?
                              luckyflyer
                              Ok, when I change Y1 to Y2 everything still homes correctly but when I go to console and give Y a positive 1 MM move (endstop is triggered) nothing happens. If I give Y a negative 1 MM move even though the endstop is triggered Y moves in the Negative direction. That is not right. It's like it thinks that the 0 origin is at the front of the printer.
                              Later I took this to the next level and loaded a print. The print executed until the gantry was commanded to move forward. Same symptom as above, no movement, endstop activated.
                                luckyflyer @OwenD
                                @OwenD said in Help with M669 etc:
                                I'm running s3d and have unchecked flip Y build table axes (I'm aware that there are 2 possible places in S3d that control this feature depending on settings) it had no effect, but I'll try it again just to be sure, I'm fighting a cold and at times a little loopy.
                                  luckyflyer
                                  Flipping Y build table axes in s3d makes no change in the print no matter the setting. It's like the firmware is suppressing the change.
                                  • Danalundefined
                                    Danal @luckyflyer
                                    Compare the gcode files produced.
                                      luckyflyer
                                      dc42 , I have trouble visualizing this statement in my minds eye "The important thing is that viewed from above, +Y is 90deg anticlockwise from +X. Can someone rephrase this or better yet, for us weak minded draw a picture, thanks.
                                        luckyflyer
                                        Got to take about 1 hour break, Downs syndrome son requires we play games on Saturday night.
                                          luckyflyer @Danal
                                          @Danal said in Help with M669 etc:
                                          Thats a good idea.
                                            A Former User @luckyflyer
                                            https://en.wikipedia.org/wiki/Cartesian_coordinate_system#Three_dimensions
                                            and a bit further down https://en.wikipedia.org/wiki/Cartesian_coordinate_system#In_three_dimensions
