    CNC style Pendant
    Hardware wishlist
    28
    155
    19.4k
    • Danalundefined
      Danal @dc42
      @dc42 said in CNC style Pendant:
      For those using Duet 3 + SBC there are plenty of USB-connected CNC pendants available, and I expect someone will write a DSF plugin for them soon.
      For other Duet users, what's needed is a a board based on a small MCU to convert the signals from something like this https://www.ebay.co.uk/itm/EU-Send-4-Axis-MPG-CNC-Machine-Controller-Handwenheel-Pendant-w-Emergency-Stop/273588909379 to serial commands to feed to the PanelDue port. We've had it in mind to design one for some time, but we haven't found time to do it yet.
      If anyone is interested in using a v3 PanelDue controller board for this, I can help with the firmware, because the PanelDue firmware already has most of the necessary functions. Alternatively, an Arduino Nano probably has enough pins.
      For a one off, and even limited production or DIY runs, I leaned toward Arudino Pro Mini or Adafruit Trinket in the past. At this time ESP32s are purchasable through normal retail channels for $5 each, and even less if you are willing to wait. Overkill to the Nth degree, but actually cheaper...
      Of course, some flavor of AtTiny if produced in any quantity.
      I may take a cut at a "DIY" based on a hardwired pendant, and an ESP32. I'll order the pendant today.
      • Danalundefined
        Danal
        Now I remember why I never order one. The are $60 to $70 (wired, not USB) on Amazon, or $30 on Aliexpress with $30 shipping and a six week wait.
        Bit the bullet. It will be here mid next week.
          I've just ordered a pendant similar to the one I linked to, and an Arduino Nano, so I should be able to help. I considered using an attiny but I don't think it has enough i/o pins.
          • arhiundefined
            arhi @dc42
            @dc42 btw, can paneldue usb port behave like master to ch430/ft323/similar usb2serial device? and receive commands from there (or just passtrough to duet)?
            A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
              A Former User @arhi
              @arhi said in CNC style Pendant:
              currently usb is only used for programming, specs for the ATSAM3S2 say device only, no (mini) host support like the bigger chips has
              • arhiundefined
                arhi @A Former User
                @bearer I have V3 with ATSAM4S4B, that's iirc cortex m4, but if the majority of the panel's out there are atsam3s2 than the approach is wrong 😞
                  A Former User @arhi
                  @arhi stil says "device" support, some of the bigger chips say device + mini host, so same same but different i guess. interesting there are different chips (i only looked at the bossa pictures in a forum thread, easier than going to find the actual paneldues)
                    dc42 administrators @arhi
                    No, it can only behave as a USB device. However, the v3 PanelDue boards have hardware connections for a rotary encoder and push button.
                    • Danalundefined
                      Danal
                      I am not tracking something. If we had a pendant that had USB host, with what would that interact? The USB on the Duet itself?
                      arhiundefined 1 Reply Last reply Reply Quote 1
                      • arhiundefined
                        arhi @Danal
                        @Danal said in CNC style Pendant:
                        I asked 'cause I had an idea that if the panel can be USB host then el-cheapo usb2serial + any MCU with ADC can translate a bunch of tasters into gcode and send trough panel's "console" to duet (without them sharing serial port) ...
                        I am working on some stand-alone wifi pendant but it's going super slow 'cause I'm pressed with bread and butter work and looks like it will not be working with SBC "upgraded" machines + I'm really making this the way I need it so dunno how universal it will be if I ever actually make it.
                        • arhiundefined
                          arhi @dc42
                          the usb2serial idea out the window 😄
                          I have V3 PRC clone that I got as a gift, no other screens at all on my duet boards, I kinda prefer to use web to the touchscreen so never bothered to order some, and that one does not come with the rotary encoder+push button connector (I assume it would be Vdd, Vss, A, B, P pins).
                            I've written the Arduino Nano code for the pendant-to-PanelDue-port interface. Now I need to wait for the pendant and Nano to arrive so that I can test them.
                            A Former User? arhiundefined 2 Replies Last reply Reply Quote 0
                              A Former User @dc42
                              @dc42 presumably this would work with any encoder? I.e. i have at least some 400/600/1200 PPR encoders in the bin and a selection of switches to mimic the quasi-schematic published with the pendant (but I guess the pendant has detents on the encoder to help with accurate positioning)
                                Yes it should work with any encoder that has A and B quadrature outputs.
                                  For anyone interested in this, the pendant I have ordered looks like this:
                                  It costs £55 here in UK shipped from Germany, or a little less direct from China. I have the Arduino Nano code ready to use when it arrives. I'm happy to share the code before then if anyone wants it, but of course it is untested.
                                  FelixHundefined 1 Reply Last reply Reply Quote 0
                                  • FelixHundefined
                                    FelixH @dc42
                                    @dc42 I can believe this is happening. Three questions, if you've got the time: could you share the link for that pendant? also, will it be compatible with the Duet 2 WiFi? and finally, is there going to be some kind or article where the build is described?
                                    I have some Arduinos at home, a Duet driven CNC (Workbee) and I have now plenty of time with the corona stuff going on, so I could definitely work on that...
                                    Greetings
                                      A Former User @FelixH
                                      @FelixH said in CNC style Pendant:
                                      • FelixHundefined
                                        FelixH @A Former User
                                        @bearer oh, thanks! I missed that!
                                          dc42 administrators @FelixH
                                          Greetings
                                          It will use the PanelDue port, so it will be compatible with all Duets that can but don't have a PanelDue connected. When I have it working (maybe even before), I'll publish the details on github.
                                          • FelixHundefined
                                            FelixH
                                            Oh, I see. It is either the pendant or the display... well, that's a bummer. The display it's quite useful to start jobs and many other things... Anyway, I'll keep an eye on it
