    CNC style Pendant
    Hardware wishlist
    28
    155
    18.9k
      I've just ordered a pendant similar to the one I linked to, and an Arduino Nano, so I should be able to help. I considered using an attiny but I don't think it has enough i/o pins.
      • arhiundefined
        arhi @dc42
        @dc42 btw, can paneldue usb port behave like master to ch430/ft323/similar usb2serial device? and receive commands from there (or just passtrough to duet)?
        A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
          A Former User @arhi
          @arhi said in CNC style Pendant:
          currently usb is only used for programming, specs for the ATSAM3S2 say device only, no (mini) host support like the bigger chips has
          • arhiundefined
            arhi @A Former User
            @bearer I have V3 with ATSAM4S4B, that's iirc cortex m4, but if the majority of the panel's out there are atsam3s2 than the approach is wrong 😞
              A Former User @arhi
              @arhi stil says "device" support, some of the bigger chips say device + mini host, so same same but different i guess. interesting there are different chips (i only looked at the bossa pictures in a forum thread, easier than going to find the actual paneldues)
                dc42 administrators @arhi
                No, it can only behave as a USB device. However, the v3 PanelDue boards have hardware connections for a rotary encoder and push button.
                • Danalundefined
                  Danal
                  I am not tracking something. If we had a pendant that had USB host, with what would that interact? The USB on the Duet itself?
                  arhiundefined 1 Reply Last reply Reply Quote 1
                  • arhiundefined
                    arhi @Danal
                    @Danal said in CNC style Pendant:
                    I asked 'cause I had an idea that if the panel can be USB host then el-cheapo usb2serial + any MCU with ADC can translate a bunch of tasters into gcode and send trough panel's "console" to duet (without them sharing serial port) ...
                    I am working on some stand-alone wifi pendant but it's going super slow 'cause I'm pressed with bread and butter work and looks like it will not be working with SBC "upgraded" machines + I'm really making this the way I need it so dunno how universal it will be if I ever actually make it.
                    • arhiundefined
                      arhi @dc42
                      @dc42 said in CNC style Pendant:
                      the usb2serial idea out the window 😄
                      I have V3 PRC clone that I got as a gift, no other screens at all on my duet boards, I kinda prefer to use web to the touchscreen so never bothered to order some, and that one does not come with the rotary encoder+push button connector (I assume it would be Vdd, Vss, A, B, P pins).
                        I've written the Arduino Nano code for the pendant-to-PanelDue-port interface. Now I need to wait for the pendant and Nano to arrive so that I can test them.
                        A Former User? arhiundefined 2 Replies Last reply Reply Quote 0
                          A Former User @dc42
                          @dc42 presumably this would work with any encoder? I.e. i have at least some 400/600/1200 PPR encoders in the bin and a selection of switches to mimic the quasi-schematic published with the pendant (but I guess the pendant has detents on the encoder to help with accurate positioning)
                            Yes it should work with any encoder that has A and B quadrature outputs.
                              For anyone interested in this, the pendant I have ordered looks like this:
                              It costs £55 here in UK shipped from Germany, or a little less direct from China. I have the Arduino Nano code ready to use when it arrives. I'm happy to share the code before then if anyone wants it, but of course it is untested.
                              FelixHundefined 1 Reply Last reply Reply Quote 0
                              • FelixHundefined
                                FelixH @dc42
                                @dc42 I can believe this is happening. Three questions, if you've got the time: could you share the link for that pendant? also, will it be compatible with the Duet 2 WiFi? and finally, is there going to be some kind or article where the build is described?
                                I have some Arduinos at home, a Duet driven CNC (Workbee) and I have now plenty of time with the corona stuff going on, so I could definitely work on that...
                                Greetings
                                  A Former User @FelixH
                                  @FelixH said in CNC style Pendant:
                                  For other Duet users, what's needed is a a board based on a small MCU to convert the signals from something like this https://www.ebay.co.uk/itm/EU-Send-4-Axis-MPG-CNC-Machine-Controller-Handwenheel-Pendant-w-Emergency-Stop/273588909379
                                  • FelixHundefined
                                    FelixH @A Former User
                                    @bearer oh, thanks! I missed that!
                                      dc42 administrators @FelixH
                                      Greetings
                                      It will use the PanelDue port, so it will be compatible with all Duets that can but don't have a PanelDue connected. When I have it working (maybe even before), I'll publish the details on github.
                                      • FelixHundefined
                                        FelixH
                                        Oh, I see. It is either the pendant or the display... well, that's a bummer. The display it's quite useful to start jobs and many other things... Anyway, I'll keep an eye on it
                                        • JoergS5undefined
                                          JoergS5 @FelixH
                                          @FelixH If you need PanelDue also, you could consider a solution similar to SMUff https://github.com/technik-gegg/SMuFF-Ifc where an ESP32 is between and allows two devices using the interface.
                                          • FelixHundefined
                                            FelixH @JoergS5
                                            @JoergS5 that's a neat project! However, I will quote Rocket Racoon on this one... "I go for the simple things"... would it be possible to just attach a switch on the UTXD0 and URXD0 pins and flip the switch to the input device you need?. It's not like I need to use them both simultaneously, I think... I guess the answer is no, but still it would be the simplest thing to do
