    Newbie Seeking Help
    1.0k
    • turbo3000undefined
      turbo3000
      Is it correct?
        jay_s_uk
        That looks correct.
        Your config files should be part of the sys folder and not in their own separate directory.
        Can you get an output of M122 and M115? That can be done through YAT
          I suggest you check that the files in /www are accessible on the Duet. To do this, send the following command from YAT:
          M20 P"/www"
            turbo3000
            @dc42 said in Newbie Seeking Help:
            M20 P"/www"
            Thanks guys but im stumoed on this one.
              turbo3000
              So i have /www separate & /sys separate.
              The /config/sys & /config/www directory & files, i was just trying to see if that would solve the problem.
                turbo3000
                This post is deleted!
                  turbo3000
                  It does remember my SSID, just not my IP address.
                  Do i need to port forward? i have an Asus GT-AC5300 router.
                    turbo3000
                    This is interesting. Does this mean i can't see my /sys files?
                    If so why?
                    • Danalundefined
                      Danal
                      They should not be sub-directories of /config.
                        jay_s_uk
                        It does imply that.
                        I would suggest copying everything off the SD card and formatting it with the SD card formatter https://www.sdcard.org/downloads/formatter/
                        I would also suggest only copying across the /sys and /www folders.
                          turbo3000
                          Thankyou. I have deleted those other files. Checked /sys folder again.
                          But still no DWC !!!!
                          PaulHewundefined 1 Reply Last reply Reply Quote 0
                          • PaulHewundefined
                            PaulHew @turbo3000
                            @turbo3000 I would go back to basics. Please post your config.g just incase.....
                            M588 "*"
                            M587 with only the S & P parameters, so it gets the address from the router as opposed to being defined, just incase........................
                            Get DWC working first then progress from that.
                            So M20 "/www" does not show anything? It did on your post @ 16:40.:confused:
                            Regards,
                            Paul
                              turbo3000
                              ; Configuration file for Duet WiFi (firmware version 2.00)
                              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri May 01 2020 01:28:58 GMT+1000 (Australian Eastern Standard Time)
                              M550 P"My Printer" ; set printer name
                              M667 S1 ; select CoreXY mode
                              M552 S1 ; enable network
                              ;M552 P192.168.1.120
                              ;M554 P192.168.1.255
                              ;M553 P225.255.255.0
                              M586 P0 S1 ; enable HTTP
                              M586 P1 S0 ; disable FTP
                              M586 P2 S0 ; disable Telnet
                              M569 P2 S0 ; physical drive 2 goes backwards
                              M92 X80.00 Y80.00 Z4000.00 E98.00 ; set steps per mm
                              M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
                              M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                              M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X330 Y330 Z400 S0 ; set axis maxima
                              M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
                              M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
                              G31 P600 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
                              M106 P2 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                Which browser are you using?
                                Does it work any better if you enter this in the address bar:
                                http://192.168.1.120/index.html
                                PS - firmware version 2.0 is rather old!
                                  turbo3000
                                  i got something !!!!
                                    I think the reason may be that the version of Duet Web Control you are using is much later than the version of the main firmware. Firmware 2.0 was designed to work with a much older version of DWC.
                                    I suggest you upgrade to firmware 2.05.1. Download Duet2CombinedFirmware from https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1 and copy it into /sys on the SD card. Put the card back in the Duet, start the Duet, and send M997 from YAT. After 30 seconds, reconnect form YAT and send M115 to see if the update was successful.
                                      turbo3000
                                      M115
                                      Ok the firmware update worked perfectly, however, this problem remains!
                                        turbo3000
                                        should i force the static IP in the config.h file?
                                        • Danalundefined
                                          Danal
                                          Now is the time to follow this:
                                          https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                                          You will already be at about step 6, with what you've done.
                                            When you type in just the IP address in the browser, what message does it report now? You may need to clear the browser cache.
