    Extruder temperature problème
    615
      Sudden drops like that could indicate intermittent connection in the wiring. Have you taken apart your harness and inspected the cables and tested continuity?
      • JuLundefined
        JuL
        I did inspect the cable and nothing seems to be wrong. This phenomen arrive also when the printer doesn't move. Sould I test it whit ohmmetre?
        • JuLundefined
          JuL
          If it is intermittent connexion, the temperature should go to infinite value, and not drops down, isn't it?
          • mendenmhundefined
            mendenmh
            Is it possible the sensor itself is loose? The wiring could be intermittent, but usually that results in reading extremely low temperatures, and much more erratic behavior. If the thermistor is in intermittent thermal contact, it could cause small jumps like this.
            • JuLundefined
              JuL
              Cable seems to be ok, and thermistor is not loose (it is the cylindrical e3d v6 sensor)
              • PuterProundefined
                PuterPro
                @JuL said in Extruder temperature problème:
                I'd hook up an ohm meter at the Duet end and work your way up the cable flexing it at every point to be sure. I'd do the same for the heater wiring. I just caught one this way a couple weeks ago.
                • JuLundefined
                  JuL
                  I'll try asap.thx
                  • JuLundefined
                    JuL
                    So, I tried hook up ohm meter on thermistor cable (board side) after my extruder reach 200°C, resistance rise linearly and suddenly drop too. I did the same without the cable (thermistor side), exact same result. I think my thermistor is dead. (please, ask if you don't understand my poor english 😉 )
                    tech-ratonundefined 1 Reply Last reply Reply Quote 0
                    • tech-ratonundefined
                      tech-raton @JuL
                      @JuL
                      I had the same problem last week
                      The problem was in the e3d connector. I replaced it and the temperature was back to normal.
                      • JuLundefined
                        JuL
                        I removed the connectors and soldered, exact same problem. I will now wait untill E3D open and send a new one
                        • JuLundefined
                          JuL
                          I received the new thermistor. Everything seem's to be ok now. Thanks to everyone who tried to help me!
                          • JuLundefined
                            JuL
                            How can I mark this post as "solved"?
                              A Former User @JuL
                              https://forum.duet3d.com/topic/7773/forum-feature-mark-as-question-solved
                              JuLundefined 1 Reply Last reply Reply Quote 0
                              • JuLundefined
                                JuL @A Former User
                                @bearer 👍
