Multiple power supplies 12/24
497
    clearlynotstef
    I'm currently revamping my beloved delta, which is currently powered by a meanwell type 12v power supply. Considering going to 24v. All of my accessories are 12v and some of them I rather like, my hotend and part fans for instance. I personally have not loved my experiences with buck convertors but understand that is an option. For the fans, they're pwm on the (-) side, right? Even the thermostatic always on fan? I could keep my 12v PSU giving + to all the fans and plug the (-) into the board right? Then I could just order 24v heater carts or buck convertors on the heater (ssr mains bed)? Is it even worth the trouble?
    undefined 1 Reply Last reply 12 May 2020, 13:54 Reply Quote 0
      gtj0 @clearlynotstef
      @clearlynotstef I think for fans and other low power devices using a buck converter is fine. Everything is switched on the negative side. You could then replace them with 24v equivalents whenever you want. I wouldn't run heaters through a converter though. You'd be much better off replacing those with 24v ones.
        Danal
        Exactly what @gtj0 said.
        Swap 12V PSU to 24V, add buck for fans that feeds the + to the fans, and the fan - is to the duet to be switched... and replace hot end heaters with 24V.
        What about your bed?
        undefined 1 Reply Last reply 12 May 2020, 18:02 Reply Quote 0
          clearlynotstef @Danal
          @Danal Bed is 120v on SR. Is there a reason to use a buck converter when I already will have a spare 12v power supply? Couldn't I just add a 24v to the duet for motors, and connect the + fans to the current 12v power supply for power directly? then just the ground to the board for pwm/switching?
          undefined 1 Reply Last reply 12 May 2020, 18:29 Reply Quote 0
            @clearlynotstef Sure. You're the one that mentioned the converters. 🙂
              Danal
              While I believe that would work... inexpensive power supplies are notoriously weird about their ground (internally). May or may not be tied to earth ground, may or may not be a true zero potential, etc.
              Personally, I'd be MUCH more comfortable with the converters on the fans.
                clearlynotstef
                Alright so let's say I go buck converters for the fans then, new carts for the hotend heaters, bed is SSR so nothing there, and by the time I'm done there will likely be 7 nema 17s, one of which is a little baby pancake on the extruder. 360 watt should do?
                  Danal
                  How many hot ends on at once?
                  undefined 1 Reply Last reply 13 May 2020, 15:14 Reply Quote 0
                    https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V for buck converter example.
                    https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply for some guidance on wattage requirements.
                      @Danal Just one, swappable smart effectors, one with a .4 v6 and the other with a volcano with a .8 (and a bigger heater).
                        logriso
                        Hi there.
                        i did what 's written in the article posted from @Phaedrux ...the only difference is that my 12V p.s. is coming from a dedicated 12v power supply. (i don't this this is matter)
                        I followed the instruction but my fan doesn't work. it works only when i connect internal 5V by jumper. (obviously less then full speed).
                        anyone has an ideas?
                        thanks
                          Danal
                          There are 3 options in that article. Which one did you use?
                          And can you post photos of the wiring of the buck converter?
                            logriso
                            @Danal , I used the article only to have the information for connection of 12V in the middle pin of voltage selection for fan. (V_FAN_A) b438e99f-a902-4075-a6e7-560ed87bf87a-image.png
                            I didn't used a buck convertor, but a power supply already used to other equipment.
                            I connected the DC 12V+ from power supply following the indication of attached picture.
                            My 12V p.s. is directly supplied from 220 V .
                            I dont think that the 12 V to supply the fan has to be derivated from the duet board....but i'm not sure....
                            the result is that my fan doesn't work in this configuration.
                            Bye
                              Danal
                              What you show for the converter should work. Assuming the screw was adjusted so it outputs 12V
                              Edit: Board wiring looks correct.
                              Double check that converter is outputting 12V
                              4 out of 14
