Duet2 Wifi new a little problem.
@Boull I think you need to update the firmware on your new Duet. The config.g file you linked to is for RepRapFirmware 3, but the Duet is probably using RepRapFirmware 2. Send M115 to the Duet and post the reply.
This is not a warranty issue, it's a configuration issue.
@droftarts said in Duet2 Wifi new a little problem.:
RepRapFirmware 2
@droftarts oK 12:06:31M115
With the original card this reponce and the same with my card, why RepRapFirmware 3 on the original card if it does not work with?
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-01-03b3
12:06:16Connection established!
12:06:16Page Load complete!I am sending you another video tonight because I have seen soldering done badly and places that the insulation on the card is like discoloring in several places.
@Boull I’m sending you another video tonight because I’ve seen soldering done wrong and places that the insulation on the card is like discoloring in many places. sorry.
@Boull Did you watch my video?
Can you post the config.g you're trying to use?
And just to confirm, both of the boards in your video are running RRF v3.0?
@Boull Yes, I watched your video. And downloaded the zip file you said you were using. This is the config.g that was in it, that is for RepRapFirmware 3:
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Apr 10 2020 09:42:47 GMT-0400 (heure d’été de l’Est) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Ender-D3-Loco" ; set printer name M918 P1 E4 F2000000 ; configure direct-connect display ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes backwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 E128 I0 ; configure microstepping without interpolation M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E741.00 ; set steps per mm M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X235 Y235 Z260 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters ;M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp ;M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 ;M143 H0 S110 ; set temperature limit for heater 0 to 110C ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit ;M140 H0 ; map heated bed to heater 0 ;M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp ;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 ;M143 H1 S275 ; set temperature limit for heater 1 to 275C ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ;dom M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit M305 P0 T107600 B4138 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 T104300 B4138 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
Give me the link for RepRapFirmware 2 plz
@Boull this is the latest https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
Another video showing where the panel's faults are. If this is not proof of manufacturing defects I do not understand. This card is new. Thank you. https://www.youtube.com/watch?v=NfM8fuSDoCw
Yes that definitely looks like a loose solder joint on the screw terminal. Would you be able to provide a close up photo of that as well as both sides of the board? The video is very low resolution and often blurry. A photo would be appreciated.
Please contact Spool3D and refer them to this thread as approval for a warranty replacement.
Sorry for the inconvenience and thank you for your patience.
@Phaedrux Haaa !! Thank you sir, I did not want to have a bad adventure with Duet because I want to buy 2 others for future projects. Thank you very much and I am contacting Spool3D thank you and have a good evening !!
![alt text]I place the videos in private.
