extruder doesnt have any torque ( Cant move anything)
432
    joehsmash @Phaedrux
    @Phaedrux i will run through these in a couple hours, tbh i used the reprap config tool and that's what she spit out.
    The only things i added/changed were directly related to the problems ive been having.
    Ie z motors individually controlled etc.
    Thanks for your input
      joehsmash @jay_s_uk
      @jay_s_uk also thanks for your input as well
        joehsmash @Phaedrux
        @Phaedrux just out of curiosity i ran the m98 pconfig.g and it came back with this
        5/15/2020, 1:30:30 AM: Connected to 192.168.1.44
        5/15/2020, 1:35:20 AM: M98 PCONFIG.G: HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        Error: GCodes: Attempt to read a GCode unsigned array that is too long: M350 X16 Y16 Z16 E16:16 I1
        Error: GCodes: Attempt to read a GCode float array that is too long: M92 X80.00 Y80.00 Z800.00 E723.38:800.00
        Error: GCodes: Attempt to read a GCode float array that is too long: M566 X1020.00 Y1020.00 Z24.00 E300.00:24.00
        Error: GCodes: Attempt to read a GCode float array that is too long: M203 X6000.00 Y6000.00 Z180.00 E1200.00:180.00
        Error: GCodes: Attempt to read a GCode float array that is too long: M201 X9000.00 Y9000.00 Z100.00 E10000.00:100.00
        Error: GCodes: Attempt to read a GCode float array that is too long: M906 X935 Y935 Z935 E1100:935 I30
        undefined 1 Reply Last reply 15 May 2020, 07:41 Reply Quote 0
          deckingman @joehsmash
          @joehsmash I think it should be M98 P"config.g" (in inverted commas). I don't think it matters with earlier firmware but in later versions it's mandatory (not sure when in changed).
          undefined 1 Reply Last reply 15 May 2020, 07:43 Reply Quote 0
            joehsmash
            after changes, m98 provides me with this
            5/15/2020, 1:40:21 AM:
            FTP is disabled
            TELNET is disabled
              joehsmash @deckingman
              @deckingman tried to run as you suggested
              5/15/2020, 1:42:30 AM: M98 P CONFIG.G: Warning: Macro file CONFIG.G not found.
              5/15/2020, 1:42:52 AM: M98 P "config.g": Warning: Macro file "config.g" not found.
              undefined 1 Reply Last reply 15 May 2020, 08:56 Reply Quote 0
                joehsmash @Phaedrux
                @Phaedrux that was it!
                swapped it all out like you suggested and BAM.
                stepper is so strong it wants to rip my finger off!
                  @joehsmash said in extruder doesnt have any torque ( Cant move anything):
                  I guess your problem is now sorted so it doesn't really matter, but that's odd. Maybe I read something wrong here https://duet3d.dozuki.com/Wiki/Gcode#Section_M98_Call_Macro_Subprogram
                  undefined undefined 2 Replies Last reply 15 May 2020, 11:19 Reply Quote 0
                    Dougal1957 @deckingman
                    @deckingman spaces after the P would maybe cause that error!
                      Phaedrux Moderator @deckingman
                      @deckingman said in extruder doesnt have any torque ( Cant move anything):
                      I think the difference is that he's still on RRF2.
                      @Dougal1957 said in extruder doesnt have any torque ( Cant move anything):
                      That could be.
                      Glad that worked.
                      13 out of 13
