    extruder doesnt have any torque ( Cant move anything)
    433
    • joehsmashundefined
      joehsmash
      Pre Duet everything worked fine i swear lol
      ive been slowly sifting through issues from when i ported everything over to the Duet,
      my new problem came when i went to calibrate my extruder.
      i went to post a G1 E100 F60 and my extruder motor just sits there and wiggles the gear a little, like theres all of a sudden not enough torque to move the filament.
      i thought maybe it was an amperage problem so i increased it from 935mA to 1100mA which made zero difference. i also tried to lower it to 800mA and it also made no difference. i have checked the leads and they are solid and everything is plugged in the correct orientation.
      if i let the extruder just free with no filament in it will turn just fine, how ever ANY resistance on the gear and it will stop.
      i just decided to do an extruder test, ive got a couple new steppers here and this issue persists through to the new steppers. which rules out a faulty stepper.
      here is my config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 00:13:10 GMT-0600 (Mountain Daylight Time)
      M550 P"JoehBo3D" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
      M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping without interpolation
      M92 X80.00 Y80.00 Z800.00 E723.38:800.00 ; set steps per mm
      M566 X1020.00 Y1020.00 Z24.00 E300.00:24.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:180.00 ; set maximum speeds (mm/min)
      M201 X9000.00 Y9000.00 Z100.00 E10000.00:100.00 ; set accelerations (mm/s^2)
      M906 X935 Y935 Z935 E1100:935 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X228 Y254 Z203 S0 ; set axis maxima
      M558 P1 H3 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P600 X-24 Y-2 Z0.148 ; set Z probe trigger value, offset and trigger height
      M557 X-10:180 Y0:195 S20 ; define mesh grid
      M305 P1 T100000 B4388 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H1:1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M501
        jay_s_uk
        One thing to note is your M584 maps 2 drivers to Z and 1 to E but the remainder of your commands have 1 Z driver and 2 E drivers.
        You need to work through your drives section and standardise
        e.g.
        should be
        M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping without interpolation
        M92 X80.00 Y80.00 Z800.00:800.00 E723.38 ; set steps per mm
        note the Z and E changes.
        Note sure what affect this will have to your current issue though
        joehsmashundefined 1 Reply Last reply Reply Quote 0
          @joehsmash said in extruder doesnt have any torque ( Cant move anything):
          Definitely clean up the double extruder values, but the Z axis doesn't need to be doubled since the values for a single motion axis must be identical anyway. It's only extruders that can be different.
          You also have some spaces inserted in your commands after the :. Not sure if that would be ignored by the firmware or if it's causing an issue.
          You can send M98 Pconfig.g in the console to re-run the config.g and you may catch some error messages that wouldn't otherwise be shown at boot up.
          For the motor current, try setting the current to 60-85% of the rated max for the motor.
          Here's how I would clean up your drives block
          M671 X-20:220 Y0:0 S0.5; leadscrews at left (connected to Z) and right (connected to E1) of X axis
          M350 X16 Y16 Z16 E16 I1; configure microstepping without interpolation
          M92 X80 Y80 Z800 E723 ; set steps per mm
          M566 X1020 Y1020 Z60 E3000 ; set maximum instantaneous speed changes (mm / min)
          M203 X6000 Y6000 Z400 E8000 ; set maximum speeds (mm / min)
          M201 X9000 Y9000 Z200 E3000 ; set accelerations (mm / s ^ 2)
          M906 X935 Y935 Z935 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
          I also made some changes for your extruder and z axis speed, accel and jerk values.
          joehsmashundefined 3 Replies Last reply Reply Quote 0
            joehsmash @Phaedrux
            @Phaedrux i will run through these in a couple hours, tbh i used the reprap config tool and that's what she spit out.
            The only things i added/changed were directly related to the problems ive been having.
            Ie z motors individually controlled etc.
            Thanks for your input
              joehsmash @jay_s_uk
              @jay_s_uk also thanks for your input as well
                joehsmash @Phaedrux
                @Phaedrux just out of curiosity i ran the m98 pconfig.g and it came back with this
                5/15/2020, 1:30:30 AM: Connected to 192.168.1.44
                5/15/2020, 1:35:20 AM: M98 PCONFIG.G: HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                Error: GCodes: Attempt to read a GCode unsigned array that is too long: M350 X16 Y16 Z16 E16:16 I1
                Error: GCodes: Attempt to read a GCode float array that is too long: M92 X80.00 Y80.00 Z800.00 E723.38:800.00
                Error: GCodes: Attempt to read a GCode float array that is too long: M566 X1020.00 Y1020.00 Z24.00 E300.00:24.00
                Error: GCodes: Attempt to read a GCode float array that is too long: M203 X6000.00 Y6000.00 Z180.00 E1200.00:180.00
                Error: GCodes: Attempt to read a GCode float array that is too long: M201 X9000.00 Y9000.00 Z100.00 E10000.00:100.00
                Error: GCodes: Attempt to read a GCode float array that is too long: M906 X935 Y935 Z935 E1100:935 I30
                  deckingman @joehsmash
                  @joehsmash I think it should be M98 P"config.g" (in inverted commas). I don't think it matters with earlier firmware but in later versions it's mandatory (not sure when in changed).
                    joehsmash
                    after changes, m98 provides me with this
                    5/15/2020, 1:40:21 AM:
                    FTP is disabled
                    TELNET is disabled
                      joehsmash @deckingman
                      @deckingman tried to run as you suggested
                      5/15/2020, 1:42:30 AM: M98 P CONFIG.G: Warning: Macro file CONFIG.G not found.
                      5/15/2020, 1:42:52 AM: M98 P "config.g": Warning: Macro file "config.g" not found.
                        joehsmash @Phaedrux
                        @Phaedrux that was it!
                        swapped it all out like you suggested and BAM.
                        stepper is so strong it wants to rip my finger off!
                          I guess your problem is now sorted so it doesn't really matter, but that's odd. Maybe I read something wrong here https://duet3d.dozuki.com/Wiki/Gcode#Section_M98_Call_Macro_Subprogram
                          Dougal1957undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          • Dougal1957undefined
                            Dougal1957 @deckingman
                            @deckingman spaces after the P would maybe cause that error!
                              Phaedrux Moderator @deckingman
                              @deckingman said in extruder doesnt have any torque ( Cant move anything):
                              I think the difference is that he's still on RRF2.
                              @Dougal1957 said in extruder doesnt have any torque ( Cant move anything):
                              That could be.
                              Glad that worked.
